02-09-2024 02:52 PM
Having a hard time finding this part. I am needing a replacement for the battery cover key. Where can I find one? I've looked everywhere it seems
02-11-2024 09:45 AM
Hey Pimpcharisma,
Thanks for reaching out to the Community. I'd be happy to take a look into this for you.
While there isn’t a spare part replacement for the Nest x Yale Lock battery cover key, you can instead insert a thumbtack into the hole on top of the battery compartment and press down firmly to open it.
Here’s a handy guide on how to check and change your Nest × Yale Lock's batteries.
All the best,
Lance
