07-19-2023 07:50 AM
I, like so many, could get my Nest/Yale lock to work because it failed to connect to the app. The nest connect worked fine but not the lock. I tried everything. The solution ended up being to connect your phone, nest connect and lock all to the same HOTSPOT from another device. The security of a regular wifi network blocks the lock from connecting so you have to use a HOTSPOT on all 3 devices. Once it is added to your app, you can turn off the hotspot. The lock will then appear to be offline on the app. The next step is to update wifi settings on the nest connect through the app. Once that is done and now connected to your regular wifi at your home, you will then need to "restart" your lock by removing the batteries, wait 2 minutes and put batteries back in. It will then all be online on your home wifi. Your welcome!!! This took me about 8 hours to figure out after no help from the installer, google or my internet provider.
07-19-2023 09:23 AM
Hello cfrazzle,
I know how it feels when something isn’t working the way it should. This certainly hasn't been easy for you, but thanks for sharing your resolution in the Community. As we've got our resolution here, I'm going to mark this thread as resolved. I'll be locking this thread if we don't hear back from you in 24 hours. Should that happen, feel free to create a new one if you have more questions or other concerns in the future.
Alex
07-19-2023 07:41 PM
What caused this issue? I also have the same problem.
08-07-2023 07:15 PM
@cfrazzle, thanks for sharing your experience and steps to help you resolve the issue in our Community. Reach out if you have any questions in the future.
@Flabbergasted, there are multiple factors that can lead to an error when pairing a Nest device. Some of them are listed below.
Have you had a chance to try the steps above? If yes, how did it go?
This handy guide may help: Troubleshoot connection errors during Nest × Yale Lock setup.
I appreciate your help, Alex.
Lance
08-10-2023 07:22 PM
Hello Flabbergasted,
Buzzing in — do you still need our help? Don't hesitate to reach back if you do.
Lance
