03-09-2026 07:10 PM
Yale lock won’t connect to nest connect. Have. Reset both devices multiple times. Am able to program nest connect every time. Get error code every time. Help!!!
03-12-2026 07:29 PM
Hi @Rweiche1,
Thank you for reaching out to the Google Nest Community. I’m sorry to hear that your Yale lock isn’t connecting to your Nest Connect and you’re receiving an error code during the setup process. I know that this is not the expected experience. I appreciate your troubleshooting efforts by resetting both devices multiple times. No worries, I’m happy to assist you.
To get started, here are some questions for you:
I’ll be waiting for your response.
Daniel
03-13-2026 06:12 AM
Hi
error code:T0 twenty six. Forty sixty (app won’t let me type the numbers)
nest Yale lock. Approx 2 years old
approx 7’ from the connect to the lock
2.4 ghz Comcast Internet
this lock worked for 2 years. Stopped working last Thursday. Replaced batteries. Did a hard reset on the lock, cleared the connect. Started the connection process from scratch probably 3-4 times. The connect will reconnect right away, but I get the error code when I try and connect the Yale lock to the connect.
03-13-2026 04:55 PM
Hi @Rweiche1,
Thanks for your response and for providing those specific details about the distance between your Nest Connect and your Nest x Yale Lock and for confirming that you’re using a 2.4 GHz network. I also see that your Nest x Yale Lock stopped working last Thursday after two years of service, and that you've already attempted to replace the batteries, perform a hard reset, and clear the Nest Connect and that you’re receiving the error code T026 (4060).
To gather more information, I have a few more questions:
In the meantime, you can try the following steps:
I also recommend you move your Wi-Fi router closer to the Nest Connect and Nest x Yale Lock during the setup process and verify that you’re entering the correct Wi-Fi password.
Daniel
