xnest door lock not fully retracting
Doug12
With door open lock does not retract even when door is open. Recently got low battery and replaced. I also did factory reset. Same issue. It appears to need a part replaced. Any help would be appreciated
DeboraJ
Hi @Doug12,
Thanks for reaching out to the community! I understand that you have been experiencing some inconveniences with your Nest x Yale Lock, specifically that the latch does not fully retract even when the door is open. I appreciate you taking the time to perform troubleshooting steps like replacing the batteries and performing a factory reset. Let me help you out with this!
Before we move forward, I need some information to provide you with the most accurate steps:
  • When exactly did this issue start occurring?
  • Does this behavior happen when you try to operate the lock manually (using the thumb turn), or does it only happen when using the app?
Once you provide this information, I will be more than happy to assist you!
Debora
