04-03-2022 04:09 PM
I own two nest Connect units. I mistakenly thought I needed two units because I have two Nest +Yale locks. However, my two locks are located very closely together. I figure I only need a single nest connect now. If I unplug my nest connect, how long will the backup battery last? If I allow it to die, would I be able to plug the connector back into wall and recharge the batteries in order to use it once again in the future? Thanks!
04-04-2022 07:29 PM
Hi Garvo,
Thanks for reaching out. Though I'm not familiar with the Nest Connect's backup battery, you can plug it on your power outlet whenever you want to use it.
You can check this article about FAQs about Nest Connect for more info.
Steve
04-08-2022 07:57 AM
04-21-2022 10:32 AM
Just checking in to see if you still need assistance with this issue. We'll leave this topic open for another 24 hrs in case there are any follow up questions or comments. Please let me know if you need further assistance.
04-22-2022 10:34 AM
Hey Folks.
