Hub Max + Nest Hello Doorbell?
RyanBaxter1019
I am trying to connect my Hub Max to my Nest Hello Doorbell so that I get a notification and/or sound (preferably sound) when someone rings the doorbell. Is that even possible? I haven’t found any answers online, and I don’t currently have a chime box I can hook the circular “fob” to. Any ideas?
@RyanBaxter1019
In the Google Nest app, select the doorbell, select Settings, then select Visitor Announcements and turn it on.
If your Nest Hub Max is in the same "home"/"structure" as your Nest Hello Doorbell, you should get visitor announcements.
7 REPLIES 7
@RyanBaxter1019
Turn on "Visitor announcements" in the settings for your doorbell in the Google Home app (for Google Nest Doorbell [Battery]} or the Google Nest app (for Google Nest Hello Doorbell).
I have the Hello Doorbell (wired), so I'm in the Nest App. It is up to date. Here's what I'm seeing:
Settings>Notifications>Products (Doorbell)>
  • Notification Type
  • When to send
  • People
  • Packages
  • All Other Motion
  • Sound
None of those options give me the ability to link someone ringing the doorbell to my Hub, nor any other options in the settings section.
Having just set up the Hub Max, I'm safe to assume it is also up to date. The Hub Max still does not have any notifications nor sound when someone rings the doorbell... Appreciate the direction, but I'm still stuck!
@RyanBaxter1019
Jeran
Hey there RyanBaxter1019,
I know this response is long overdue, but did you have any more questions or need any additional help?
Just checking up,
Jeran
Hey RyanBaxter1019,
I wanted to check in and see if you are still in need of any help with your device? Please let me know, as I would be happy to assist, and answer any questions you may have.
Muddi
Hey RyanBaxter1019,
Just bumping in to make sure that you've seen our responses. I'll be locking this thread if we won't hear back from you again in 24 hrs. Feel free to create a new one if you have more questions or have other concerns in the future.
Muddi
Hey RyanBaxter1019,
