My Nest Hub alarm or timer sound isn’t going off.
Pauly_C
The sound isn’t going off, yet the display shows the alarm or timer is over. Yes, I have sound picked out and volume selected at specific level. I just got the device a few days ago, so it’s relativity new. Thank you in advanced with any help.
Pauly_C
Update: Okay, I did some research and reset my device. And now it works! Please disregard this forum. Hope this helps anyone reading in the future. THX!
2 REPLIES 2
Pauly_C
Alex_S
Hi Pauly_C,
We’re glad to hear that this has been sorted out. Thanks for sharing the solution you found. Should you need further assistance on Google Home, let us know.
Alex
