04-29-2023 09:42 AM
I have a Nest Hub Max
If I monitor the camera, the audio is very, very low. This is NEW.
I used to be able to hear sounds easily if I monitored the camera. Yesterday, the sound was extremely low. I thought it was off, but if I put my ear to the speaker on my phone, I could hear faint sounds.
I checked all settings and even did a factory reset of the Hub Max. Still almost zero sound. I tried this on both my phone (Adnroid) and iPAD (IOS). It was the same on both.
If I say "Hey Google..." the Hub hears me.
Any advice is appreciated.
06-05-2023 09:15 PM
I understand that experiencing audio issues when streaming the Nest Hub Max camera can be frustrating, especially since it plays an important role in your daily life. Please know that we value your feedback and are working diligently to address this issue. Our team is currently investigating the matter, and I will provide updates on any progress or findings. Thank you for your patience and understanding as we strive to provide you with the best possible experience.
Muddi
04-29-2023 10:18 PM
Same here
I get a buzzing static sound also
many input would appreciate it
04-30-2023 05:19 AM
I do NOT have buzzing.
I just basically have no volume when watching the affected camera.
I removed, reset, and reinstalled the camera. No improvement.
04-30-2023 02:47 PM
I still have no change. Reset wifi - cameras - hub and nothing still same
04-30-2023 11:18 AM
I am having the same issue. I’ve also tired everything and have had no results. I’m getting frustrated.
04-30-2023 01:46 PM
I'm having the exact same issue and it just started in the past few days.
04-30-2023 02:27 PM
Same here, and only on my Hub Max. My cameras seem fine.
I don't think it is a hardware issue because if I go into the room with the "Hey Google..." command, it hears me fine.
It is when I view the stream there is basically no volume.
When I get a chance I will call support.
05-03-2023 09:55 PM
I can tell they did an update around 2 AM Saturday. If I go back and look at my video it’s working fine and then it goes offline for 30 seconds to a minute and then comes back on and the audio won’t work. Appears to have been caused by an update.
06-08-2023 04:18 AM
I have The same issue and I started to be frustrated because I can’t hear anything
05-01-2023 03:49 AM
I have the same problem with my hub max. When on live stream i can barely hear anything from it. Need help also
05-01-2023 09:31 AM
EXACT same problem over here! started a couple days ago. before, the sound from the google hub max was the most sensitive and now i can barely hear a thing. EXTREMELY frustrating
05-26-2023 05:51 PM
I have the same issue. At first I thought the mic is completely off. But then I can hear a faint sound from the recordings or live view. It's barely there. So annoying
05-01-2023 10:37 AM
We are having the same issue with our Google Hub. Its so aggravating we cant hear anything. Hope someone has a fix for this!
05-01-2023 11:28 AM - edited 05-01-2023 11:31 AM
just spent 1.5 hours via chat support and after everything, they're escalating to a higher level of support. i narrowed down the audio going faint sometime between last thursday night and friday morning
05-06-2023 07:53 AM
i did the same they just replied with nothing they can do, unit is out of warranty and need to purchase another.....weird how so many people are having issues
05-06-2023 09:22 AM
I get an email from them about each day asking more questions or asking me to try things. Some of the questions show they don't know their products, even though, this is supposedly the senior support team, such as adjust the mic sensitivity using the slider bar..... Which doesn't exist for the Hub Max. You can do it for the cams but not the Hub Max
05-06-2023 09:49 AM
That's because as usual it's probably a support team that's overseas being paid next to nothing going through an ABC support script and when that doesn't work it says solution is replacement.
05-01-2023 07:03 PM
Same issue here as everyone else. Can barely hear anything when I try to listen. Mine also went out between Thursday night and Friday Morning
05-01-2023 07:16 PM
Same, Inoticed this issue about a week A week ago. Rebooted, factory tested, so can't fix this problem.
05-01-2023 07:23 PM
Only change I made recently is I went from monthly nest aware account to yearly and changed Groom event monitoring to 24/7 monitoring
05-02-2023 04:40 AM
I too am now experiencing this after making NO changes to My Nest Hub Max. Device has been powere cycled. I used to be able to hear birds OUTSIDE across a 20ft room with the window open. Now i cant hear anything.
System Firmware 10.20221207.2.109
Cast Firmware 1.68.353511
05-02-2023 04:43 AM
I have the exact same issue when viewing live stream. The mic is actually picking up sound but it is very faint.
05-02-2023 05:33 AM
Exactly the same problem here. Started sometime between 7:30pm Thursday April 27th and 7:30am Friday April 28th.
05-03-2023 07:40 PM - edited 05-03-2023 08:11 PM
Hey everyone,
My apologies for the late response. I know how challenging it is when your device is not working the way it should. Let's get to the bottom of this.
It would help a lot if you could share a video showing the issue on your Nest Hub Max, so we can take a deeper look.
Muddi
05-04-2023 04:29 AM
The issue seemed to begin 4/27 or 4/28 i can't recall exactly as i tried a few different things including deleting video history to remedy the issue.
I have tried via chrome web browser on a physical computer, vm installation, phone speaker, and bluetooth to the same effect.
Normally stream via Pixel 7
05-04-2023 04:30 AM
System firmware version: 10.20221207.2.109
Cast firmware: 1.68.353511
Sometime between Thursday 4/27 7:30pm and Friday 4/28 7:30am
iphone 12 pro max. iPhone 11 Pro. Pc desktop. iMac desktop. ALL devices.
05-04-2023 04:43 AM - edited 05-04-2023 04:44 AM
Just saw these questions, so answering again with more detail:
05-04-2023 06:43 AM - edited 05-04-2023 06:43 AM
My responses to your questions are basically the same as everyone else. However there is one thing I'd like to add: viewing playback in my browser has the exact same issue from a PC if that's any help
05-04-2023 01:41 PM - edited 05-04-2023 01:43 PM
Also, I deleted the Hub from my home, factory reset the hub, then added it back in. Still almost zero volume from the microphone when monitoring the stream
05-04-2023 02:25 PM
Can you go grab a hub max and see for yourself ?
05-04-2023 10:32 PM
Same issue for me, except mine is brand new out of the box, only set it up yesterday and having issues as soon as I tested it. I thought I may have a faulty one but after reading on here it seems like a firmware update has caused the issue. Is there any ETA on when another update will be pushed to resolve the issue?
05-25-2023 08:47 AM
06-01-2023 12:12 PM
Muddi,
As you may recall from having reported this on another page, I've had this exact problem for a couple months already, the factory reboot didn't help, I've submitted a form, and still no fix.
05-02-2023 07:27 AM
Same issue here. I have multiple Home Hub Max's, regular nest cameras and door bells. The Microphone issue only affected the Home Hub Maxs'
The issue started after an overnight firmware push to the Home Hub Max's. One updated Thursday night into Friday morning 4/28 the second one updated Friday into Saturday 4/29.
Sound is muffled and does not pick up room audio very well anymore.
If someone has a fix please share.
05-03-2023 09:57 PM
Same.
05-02-2023 09:03 AM
I guess it is good to know I'm not alone with this issue.
I'm disappointed there is no Google response.... I thought maybe they would have an alert about this as they researched.
I did a web query and as far as I can tell, this is the only thread discussing the topic.
I did get an email today asking me if the issue is resolved. I guess the Google AI is not quite as good as they may think.
05-02-2023 10:57 AM
Exact same issue. Used to hear a pin drop. Now it’s as if the volume is at 1
05-02-2023 12:17 PM
05-02-2023 12:21 PM
Hopefully this isn't the direction they are taking. I like this product (when the mic works) and use the non camera version for locations not sitting for camera like bedroom
05-02-2023 02:20 PM
Google kills all kinds of projects off, this offers several subscription based features. Nest, and sleep/Google fit integration so I don't foresee them killing it soon.
I suspect a firmware update has done us in and hopefully they'll resolve it quickly
