04-20-2025 10:13 PM - edited 05-01-2025 04:58 PM
RadioApp will not load on my Nest Hub Max. Other nest devices in the same household are fine.
Has been working fine, but stopped within the last week or so. Responds to my voice command "Play 3AW' but then the loading process freezes. Other radio services seem fine (iHeartradio) works on the Hub max, but RadioApp does not.
Contacted Google support via email ... the suggested the usual reboot and update solutions ... no change. Opened a chat to Google support, nothing additional to help, but they did suggest to open a Feedback on the issue through the Google home app. When enough people report the same issue, it gets the attention of the next level support people, who should be able to resolve the issue.
** UPDATE **
This is a Google issue ... probably a bug in a recent firmware upgrade that you have no control over.
If you are on firmware level 26.20250116.103.2201 you will probably have the problem.
It is a worldwide issue for Nest Hub devices. Google are aware and some users in the UK have recently reported their problem has been fixed. Hopefully just a matter of time before they roll the fix out to us in Australia ... keep checking.
** UPDATE 2 **
Working here in Melbourne on Friday 2nd May at 9:45am. Was not working at 6:45am.
Seems ok for 3AW , 2GB , 6PR , ABC , GoldFM , Smooth FM , Nova , KIIS ...
... but not for MMM , MMM Classic Rock , FOX FM , 3MP . That is all that I quickly tried.
Interesting is that my firmware level has not changed for my Nest Hub Max. This suggests that there might have been as issue in RadioApp that they are progressively fixing up.
We will probably never know the root cause of the problem, but let's hope they get ALL the stations back ASAP.
05-04-2025 10:06 AM
Thanks for the post. I'm having the same problem here in the US. Finally decided to Google it to see what was going on. I've been using Alexa to play my radio🤫. Hopefully it is fixed soon.
04-30-2025 04:30 PM
Until Monday, 28/04/2025, my Google Nest Hub could connect to RadioApp to play radio stations. When issuing the command the RadioAp is not working. Never had this trouble before. I have heard that there may be an issue with an update with Google. Can anyone assist. Regards JohnK
04-30-2025 07:39 PM
Hello John.
Take a look at this thread ...
https://www.googlenestcommunity.com/t5/Speakers-and-Displays/RadioApp-no-loading-on-Google-Nest-Hub-...
04-30-2025 09:00 PM
I have exactly the same issue. Radio app on my Google Nest not working since 27/4/2025. Have tried a reboot and a reset but to no avail.
05-01-2025 06:04 PM
It's working again!
05-01-2025 06:35 PM
Not for me its not !
05-01-2025 08:54 PM
I am having the same issue as are other family members. So far no response from google
05-04-2025 05:23 PM
I did 3 factory resets and same result. Audacy freezes on Nest Hub Max, but works on google smart clocks. All other stations work.
05-03-2025 06:08 PM
Mine is all fixed
05-04-2025 01:28 PM
A google issue all fixed in Sydney now after a week.
05-03-2025 08:39 PM
Mine is now working
05-04-2025 01:30 PM
Just have to be patient. Google problem takes time to fix but all working now after a week or more of no radio.
05-04-2025 04:42 PM
Hi John. I has the same issue. I emailed Radio App and they said it was a Google issue they were working on. In the past few days many ppl gave got radio app back working, including myself. If you are still experiencing trouble, send radio app an email as it seems everyone has it working again. Cheers
05-04-2025 11:25 AM
Still no radio apps working on Hub Max as a part of a routine in the United States as of today, 5/4/25. Only TuneIn works on command on the Hub Max. Audacy, iHeart Radio and TuneIn work on smaller devices on command.
05-04-2025 11:29 AM
IHeart Radio working fine on Nest Hub, however, Audacy and TuneIn will not play stations. TuneIn will play the initial commercial (gee thanks! 😂) …but no music after that.
05-06-2025 10:27 AM
Same with mine, no radio and TuneIn plays the initial commercial and that's all 🤣
05-06-2025 10:29 AM
😑ugh so annyoing. What are they doing about this? It's going in a month! 😫
05-06-2025 01:59 PM
No doubt it must be frustrating. If your both using Tune-In then I wonder if what ever RadioApp did Tune-In hasn't.
The strange thing about all of this is as far I can see no one has actually posted what the problem is. But, it is as I suspected, something to do with the way the commercial plays.
Have you tried a non-commercial station? Oddly in Australia, the non-commercial stations (that seemingly no one actually listens too by the weight of posts in this forum) were all still working.
05-06-2025 04:47 PM
To deepen the confusion and mystery, I just tried an assortment of stations on Tunein. In Melbourne, for me, local and international stations all loaded just fine on Tunein. RadioApp also continues to be ok. At the moment I am unable to recreate the original problem with any stations or radio streaming apps.
05-05-2025 06:13 AM
Problem still exist , it's been happened for weeks
@toronto Canada 5th May
05-05-2025 01:46 PM
They fixed it all in Australia. Maybe working on it in segments. Assume its a Google issue they know about and probably trying to fix one country at a time?
05-05-2025 06:14 AM
All of a sudden cannot stream Audacy radio on my google hub. It freezes and eventually goes back to main screen
05-05-2025 08:24 AM
Same issue here With Audacy and iHeartRadio. I was able to add a workaround using TuneIn and also adding a CUSTOM command in my routine to start playing a certain radio station using TuneIn instead of using the RADIO command within the routine.
05-01-2025 03:17 AM
I have numerous Google devices but on my nest Radio app no longer works. It does work on one of the speakers tho. I've done a reboot and a reset didn't help. It always use to work.
05-05-2025 05:49 PM
I have the same issue. Is there somewhere I can go to look for updates? So annoying a it’s a community radio station and we rely on streaming number.
05-06-2025 11:41 AM
Thnx for your info. Cause I can't get mine to work since I got the new Google 9 pro XL last week. I just keep turning it on with the cast hoping it will correct itself lol...
05-06-2025 11:45 AM
I'm so glad to find out other people are having trouble. I'm tired of messing with it. And I'm not rebooting everything again. I bought all Google so it would work seamless. Hope I can figure it out.
05-06-2025 11:54 AM
I feel exactly the same way you do. I rebooted the nest, the home app, removed everything, reinstalled, nothing.
I am able to play other things like I❤️ radio (Iheart radio). Very frustrating not to know what, why and when this will be fixed.
05-07-2025 01:41 AM
Same issue here with Planet Rock app, they've been pushing to download the Rayo app so I figured I should probably get around to downloading that, but neither works. Do we have any update on anticipated time to resolve?
05-07-2025 09:36 AM
Joiniung the choir. I cannot get Audacy on my kitchen hub speaker but it works on two of my nest speakers. Tried all the trouble shooting to no avail. Started abot two weeks ago...
05-07-2025 05:44 PM
I want to listen to one station on iheartradio and it freezes after attempting to load, same thing happens with another station on audacity - my device that is glitching is a Google Nest Hub on firmware 26.20250116.103.2201
My google Nest wifi points which have speakers are just fine.
05-07-2025 06:06 PM
Behold, a miracle!! Decided to give the voice command another shot this morning just in case and RadioApp appears to be back to fully functioning here in Perth.
05-07-2025 06:38 PM
Nice! I try 2 x a day and still nothing. Maybe your miracle will come our way. 😀
05-08-2025 07:05 PM
TuneIn radio hasn't been working on my Google Nest for a week now. Whenever I give the command, it opens for about 5 seconds, then it just shows the TuneIn logo and nothing else happens...
05-12-2025 05:45 AM
Not working in Canada. It seems the app Seeker Radio will not play on Google Max. It will play on mini speakers.
05-12-2025 10:40 AM
All Radio stations I listen to are now playing on my Google Nest Display Mini since last Friday, May 9th, here in Miami, Florida. I checked my Google Home App and the firmware System firmware version from : 26.20250116.103.2201 to 26.20250116.103.2600. When I first experience the problem, I contacted Google Nest Support via Chat and open a case ticket that was passed on to System Engineers via Google Home App > Feedback (no reply). I was never contacted, so I cannot say Google Nest Support directly resolve the problem on my behalf or I was just lucky. I hope that this help all that are having this unfortunate technical problem with the RadioApp service.
05-13-2025 01:40 PM
I was just contacted by Google. Issue with audacy app jas been resolved and is now working fine.
05-13-2025 02:19 PM
Great! Thanks for letting me know. Did they contact you via email (other) based on your chat, email or other? It would be helpful if all Community Members posted their method of communication with Google Nest Support along with the problem and how it was resolved. Cheers.
05-13-2025 02:25 PM
Update for TuneIn in the US -- started working as of this morning Tuesday 5/13! I see that my Nest Hub Max has a new firmware from the old "2201" problem-firmware -- new "good" one is 26.20250116.103.2600.
05-13-2025 02:44 PM
Yes ! Mine is fixed to and as of today I also have the *good* firmware
