Change wifi network without remote control
Dave29
My google tv remote was damaged and I have been using google home app to control device. Can someone tell me how I synch google tv with phone app when I change wifi networks? I can't get to the settings to put it on thr same network.
David_K
Having already changed to a different Wi-Fi network, there's no way to do that without the physical remote control, so you would need to factory reset it using the physical button on the device. Once reset, you need the remote control to do setup in any case. Replacement remotes are available on the Google Store.
How to factory reset your Chromecast - Chromecast Help
Set up Chromecast with Google TV and Voice Remote - Chromecast Help
Voice Remote for Chromecast with Google TV - Google Store
