05-31-2022 01:36 AM
Hi I have been using my chromecast for last 2 years but from yesterday it’s like I am not able to cast any thing because cast icon is not reflecting , chromecast reset button is not doing anything and white stable light is reflecting
06-04-2022 06:20 PM
Hi Panjrath93,
Thanks for reaching out. Let's sort this out.
Quick questions: Is the Cast button missing in one app or multiple apps? What is the make and model of the device used to cast?
Try these steps:
Jennifer
06-04-2022 11:13 PM
Hi Jennifer,
1. I tried casting using Amazon prime box and that casting application like YouTube etc is working
2. my chromecast is only reflecting white solid light always ( even after pressing the reset button for 30-40 seconds the light did not change to any )
3. I tired factory reset but no diffence in the light ( solid white only)
06-05-2022 05:24 PM
Thanks for getting back to us. Have you tried the other suggested steps above? If yes, how was it? Also, please try to plug in the Chromecast into a different HDMI port on your TV. Plugging in your Chromecast in a different TV screen and do the factory reset there might also help.
Jennifer
06-05-2022 05:34 PM
Hi Jennifer ,
I have tried the above steps also , nothing is working .
My chromecast still shows a fixed white light with no casting icon on any app
can we connect or raise any ticket
06-05-2022 06:46 PM
Hi Panjrath93,
Yikes! Could you please try to disable and enable (toggle) automatic time zone setting and restart the mobile device? See the steps below:
For Android:
For iOS:
If the issue persists, please fill out this form and let me know once you are done.
Jennifer
06-08-2022 07:02 PM
It's me again. I want to make sure you're all good — how did the steps go? If it didn't resolve the issue, were you able to fill out the form?
Jennifer
06-10-2022 10:56 AM
Just checking up,
Jeran
