Chromecast doesn’t connect to wifi
Layna
Cet appareil Chromecast a été fabriqué pour un autre pays ; il est donc possible qu'il ne soit pas compatible avec votre réseau Wi-Fi
peut-être configuré, mais il est impossible de communiquer avec lui à partir de votre iPhone.
2 REPLIES 2
olguinpls
If you had unfortunately factory reset your Chromecast during this issue, go to your phone Date&Time settings and turn off automatic date set, manually change the date to March 7, 2025. Now try to set up the Chromecast again and it should work again.
Ari3
Yes, that's what I did after factory reset. Now my Chromecast has received updates and working as before. Of course you need to keep your caster powered after setting it up to correct WiFi.
