Chromecast remote has water in it
Green_jose1
Hey what do I do when there is water in my Chromecast remote?
TomLaw1967
If it's really water... then take the batteries out and let it dry! Have your batteries leaked?
And hope it didn't get fried trying to use it while waterlogged!  If all else fails you can either use your phone as a remote or buy a new remote as well.
Alex_S
Thanks for the help, @Ashepherdson, @TomLaw1967.
@Green_jose1, can you tell us more about what happened on your Chromecast Voice Remote?
Alex
Hey @Alex_S  My remote model type is: G9N9N and my problem has been solved but thanks you for try to help though.
Kimy
Hi Green_jose1,
That’s awesome! I’m glad that this has been sorted out. I’ll mark this as completed, and I’ll close this thread after 24 hours. Feel free to create a new one if you have concerns in the future.
Kimy
