11-30-2021 06:25 PM
I am having a problem with my Chromecast. I can cast from my phone and my tablet just fine. I set it up a while ago. However, for the past few months I haven't been able to get into settings.
I use the Google Home app (which is updated to the latest version), tap on my device name, which opens up the page for my Chromecast, and shows that it's casting, I know for fact that it's connected to my home network (when it's not connected, my TV says "unable to reach [network name].") However, when I click on the gear icon in the upper right hand corner, it brings me to a page that says "Unable to connect" "There may be a connection issue".
I have updated all the Google apps I can, unplugged my Chromecast, restarted my router, plugged my Chromecast back in, waited for the light to turn white. I have done everything except changing the wifi band and factory reset.
If I factory reset and still can't get settings to work, then I won't be able to use my Chromecast at all. So I can't do that.
I can't change the wifi band because Xfinity won't let me change the band for *just* my Chromecast.
I need to know if these are the only two options to fix my problem. Or do I need a new Chromecast?
01-26-2022 02:05 PM
Sorry for the late response, but I wanted to drop in here to help.
I'm sure this issue can be confusing but I definitely wanted to stop by and see how I could help.
Just wanted to double check to see if you were still needing help on this? If so, what troubleshooting steps have you tried?
I look forward to hearing from you.
Garrett DS
01-31-2022 02:03 PM
Did you have any more questions or need any additional help?
Thank you,
Jeran
02-03-2022 02:19 PM
Just checking up,
Jeran
02-04-2022 02:31 PM
Hey there!
We haven't heard back from MoonChild02, and it's been a few days, so I'm locking the thread. As always, feel free to make a new thread if you have any more questions or concerns.
Thank you for your help, Garrett!
Jeran
