GoogleNestTeam
Community Manager (Admin)
Update 3/20/25
Update 3/17/25:
Update 3/14/25:
Update 3/13/25:
Update 3/11/25:
Hi all,
Thank you.
Thank you for your patience.
GoogleNestTeam
16,147 REPLIES 16,147
I reseted unfortuntly , i  I didnt get any warning regarding this issue,
It has been over 4 days since the issue occurred. It is surprising to see how long a company like Google is taking to solve a GLOBAL issue!
I factory reset already because that’s what your troubleshooting steps said to do. When will this be fixed?
Dear Google
I appreciate your request for an apology, but it has been several days since your company's product has failed and I have no chance of seeing platforms that I am paying for. I would like significant compensation for all that this glitch is generating. It could simply be subscriptions to Google products. I look forward to hearing from you
Regards
  • So the problem occurred over the weekend (let's be generous: March 😎
  • Umpteen thousands of people literally have no casting capability
  • The boards suggest that this is a Cert-related issue (which is literally a two-minute fix)
  • Yet, FOUR business days later, nothing.
If it's a cert, please repair it and ping to the community immediately. Please pay particular attention to the people that followed your previously posted instructions, and performed a factory reset.
VERY unlike Google to blow it this badly, and then appear lethargic on the fix.
Just sayin.
Until when it will be fix almost a week now
Well, it's already Thursday evening and still no solution.
I did factory reset as this was recommended when I was searching for solving the issue- there was no information at that time about the problem , neither warning do not reset.
Absolutely  not acceptable!!!
I did a factory reset on my unit and experienced the issue of not being able to re-install it from my phone. But after changing the date to 8th of March on my phone i was able to complete the installation (still cant stream on it though).
A work around that at least fix the issue of not being able to re-install the unit.
This actually worked for me so thank you very much.
And since the first course of action recommended whenever talking to support is to factory reset it, how many are out there with factory reset devices already
AnitaK
Yo también decidí hacerlo porque muchas veces es lo que recomiendan cuando hablas con soporte, ahora he leído que muchos por restablecerlos dejarán de funcionar y habrá que desecharlos
Hi. Do you know how long about.  It doesn't work since Sunday
Señores, ya se pasaron 1 semana del problema de conexión y todavía sigue sin una respuesta con una solución! Una nota de esclarecimento ya! Mas respeto con los usuarios
When will this he fixed?
Yo desinstale Google home y lo he vuelto a instalar pero no me detecta el Chromecast
Did not have the patience to wait for a fix to make my property work poperly again. Bought Apple TV 4K instead. Perfect. Love it. Should have switched long time ago.
Ok lets start a class action lawsuit!
what is the fix if I already factory reset them out of options? Have been waiting for days!
we are waiting...i cannot belive that Google is not capable to fix it quickly .Microsoft send the updates and is installed in one minute...
when is this fix , online?
My wife will not be patience, if she can't streaming.
I hope it will work very soon because we watch tv with this every day.... so for now we have to watch on our phone 😔
Please, fix it!!
When ur going to fix it's a week still nothing
Been down for 4 days- what the heck?!
Workaround that worked for me on my Chromecast Audio 😊
  1. Use an old mobile device, update Google Home and set the year to 2016.
  2. Disable automatic updates and forget all Wi-Fi networks to prevent automatic reconnection.
  3. Perform a factory reset on your Chromecast and set it up again in Google Home.
  4. As the final step, add the Wi-Fi network to the Chromecast.
  5. The Chromecast will during the process get the necessary updates.
Enjoy your music again! 🎶
I am having problems pairing my Google remote to my chromecase with Google TV app. Is that also related to this issue? I saw posts about pairing audio devices, but nothing about the standard google remote. Any help would ease my aching mind 🙂
Thank you.
初期化したものなのですが、修正は出来そうですか?
トラブル発生から、約1週間、そろそろ見切りを付けたいのですが
They have an idea of how much Will it take time?
Do you have any idea how long the solution will take?
Any solution yet?
Makg17
too little too late Google!  I already did a factory reset. Get this fixed!
trbeason
How will we know when a fix has been made for those of us who have already done a factory reset ( as that was recommended as a step to fix the problem).?
True they should push a Google home notification with the fix or when it's fixed
I'm assuming that they will update this thread. It will be a huge challenge to be able to make a certificate change on these devices. I have no idea how they are going to pull it off!
So do you think its likely they will just pull the plug on the chrome cast audio?
My thoughts exactly. The lack of communication is a major issue
lol you are on the communication thread! There are updates from Monday and yesterday! How is communication a major issue?? I'd lose my mind dealing with customers like y'all, these comments are bonkers
If there have been updates, why is it not fixed? What are the updates as I have not yet seen them!
This is barely a communication platform - less technical users would interact with niche forums such as this.
This issue should have never happened!
