GoogleNestTeam
Community Manager (Admin)
Update 3/20/25
Update 3/17/25:
Update 3/14/25:
Update 3/13/25:
Update 3/11/25:
Hi all,
Thank you.
Thank you for your patience.
GoogleNestTeam
16,160 REPLIES 16,160
Same here.
Também aconteceu o mesmo por aqui
All my 4 Chromecast doesnt work anymore?   Cannot be trusted anymore?? Why
 In the fuvking middel of a football match..😭
Same here in indonesia . After i factory reset it. Cannot connect
Same problem here
I tried to connect Chromecast this morning but didn't work. Restart again still doesn't work. It said I have authentic problem. I reset my Chromecast and now is unable to add in. And have authentic problem again. Use my pixel 8 and reinstall my Google home. Same issue. I am a little disappointed about this issue as I buy so many generation fo Chromecast and use them since the Chromecast coming out.
Same here. Stopped working all of a sudden and refuses to setup   even from scratch. "Can't authenticate your Chromecast".  What's happening???
As an aside, all my other google home automations are still
working. Just the chrome casts have disconnected.
If they really ended support on a Sunday evening without any notice, this is well out of order.
I got the same problem.
Did a factory reset and now it says it can authenticate my chromecast anymore
Same issue
From morning it shows not trusted device and request to update firmware. I did factory reset but it still does not work
I m from Belgium, it happens to me too with the same message. Any solution?
Same here. India
Same here, from Argentina
same here. it was casting perfectly fine the entire day, then i paused my show to do something for about 30 minutes, give or take, then it just wouldn’t connect again no matter how many times i restarted just about everything 😕
this quite literally just happened to me at 12:50p today. what in the world do we do - just install a newer model? it would be great if google would tell us what to do.
Same here in Sweden 😢
O mesmo aqui no Brasil
I am facing the same issue. I tried a factory reset and tried to add the device to my Google home but I am unable to do so now. It says the authentication is unsuccessful.
Me too. The Chromecast on my TV but my phone and the Google home app say it's 'offline'  unplugged turned everything off, back on again. Have Wi-Fi. Try to support call got cut off they will not allow me to call again. So frustrating! I keep thinking of something to do with daylight savings time. But that's unlikely. So, totally feel your pain!
Thank god i didnt buy the Google Car
Same here. Can't authenticate after factory reset. Seems to be happening to all 2nd gen Chromecast and audio devices.
Same issue, Belgium
Same here Denmark…☹️
Same issue, Austria
Same in NH, USA
Same issue, Brazil
The same in Poland
Cannot reconnect my Chromecast-2 in the Netherlands as well.
Factory reset of CC and my router.
Even removed the "Home" app, android reboot.
Nothing helps.
Must be an issue at google.
Gen2 chromecast. same issue. Can't configure after factory reset. Cannot authenticate error.
O mesmo acontecendo aqui.
Both of mine too grrrrrr!!!! Not happy!!!!
Same happened to me...
Same here in Canada. Started about an hour ago. Was having issues with casting so I reset to factory setting like I always do when I'm having casting problems. But this time it shows "cannot authenticate Chromecast". I have 2nd gen Chromecast.
Same here in Netherlands
I have the same problem here in Argentina. I have two Chromecast devices and both have the same problem. How do I fix them?
Same problem from Greece! Gen 2 devise
Ok, so 2nd and third Gen Chromecasts all have this problem. First Gen appears not to have this problem. Strange, must be an expired certificate in the firmware. So we'll be all waiting till Google pushes a firmware update, which can take months, if they even update it. Real crap, have to watch television on my phone for now 😑
Same here. Seems to me to be a service issues by Google.
Let's wait for them to answer us what's going on
