Update 3/20/25
Update 3/17/25:
Update 3/14/25:
Update 3/13/25:
Update 3/11/25:
Hi all,
Thank you.
Thank you for your patience.
03-20-2025 10:49 AM
03-09-2025 04:41 PM
O meu Chrome cast não quer mais conectar no meu wi-fi já fiz de tudo !
03-09-2025 04:41 PM
Same issue here...
03-09-2025 04:42 PM
Just adding another voice having the same issue
03-09-2025 04:45 PM
Seems like programmed obsolescence to me
03-09-2025 04:44 PM
Por aqui aconteceu a mesma coisa. Estava normal até o meio da tarde de hoje, desliguei a TV e quando fui ligar novamente no final do dia para conectar com o YouTube, apareceu que o dispositivo não era confiável e que poderia ser firmware desatualizado
O dispositivo Chromecast sumiu do Google Home, mas na TV aparece como se o Chromecast estivesse normal, mostrando imagens e até a hora e temperatura, como é de praxe. Fiz de tudo, tentei reiniciar o aparelho, tirei da tomada, até desinstalei e instalei o aplicativo Home, mesmo assim não consigo conectar meu celular com Chromecast e TV.
03-09-2025 04:45 PM
Same issue here
03-09-2025 04:45 PM
I'm also having the same problem and I'm in New Zealand so seems to be a global thing
03-09-2025 04:49 PM
USA, Ohio. EST, Daylight savings as of midnight. Did the time change break chromecast? Can no longer cast my screen or tab to Chromecast.
03-09-2025 04:49 PM
Same issue on 2 chromecast. Disappeared, reset, won't authenticate.
03-09-2025 04:51 PM
SOY DE ARGENTINA, PARECE QUE ES UN PROBLEMA QUE SURGIO HOY EN TODO EL MUNDO ESPERO QUE SE SOLUCIONE...!!!
03-09-2025 04:53 PM
same problem happening to me
03-09-2025 04:53 PM
Well, guess time to switch to Roku
03-09-2025 04:54 PM
I am extremely disappointed that it seems that Google has decided to brick my Chromecast device. It worked last night and this morning however about noon it was giving me an error message and after doing all the steps in the trouble shooting, nothing worked.. It showes up that it's ready to set up but Home won't connect. Have updated home, have reset Chromecast device.. nothing works. This seriously makes me second guess purchasing another Google device. Also when reaching out to support, I get a call only to be told I can't get help. SO seriously Google why? Now my only option is to buy Google Streamer ( which is only a few dollars less than a new TV), another brand of Streamer, or buy a New TV which I don't need. not happy
03-09-2025 04:54 PM
Juste happening to me on Canada. Try a reset but cannot add on;
" could not authenticate..."
03-09-2025 04:58 PM
ES UNA VERGÜENZA...!!!
03-09-2025 04:58 PM
same problem here
03-09-2025 05:00 PM
Similar issue.
Everything worked fine yesterday. Now we can't cast. Giving us a " Chromecast can't authenticate error". Have gone thru all troubleshooting. Have factory reset both Chromecast- no change.
Is it coincidental that there was a time change?
03-09-2025 05:01 PM
Same here. What's going on?!
03-09-2025 05:01 PM
Same for us. We have 3 chromecast. All will not work
03-09-2025 05:03 PM
Same issue here
03-09-2025 05:03 PM
My Chromecast is not connecting I don't know why I also performed a reset task ...
But at the end it says some errors occurring contact help center
03-09-2025 05:04 PM
Same issue than the other... Did all the trouble shooting and nothing...
03-09-2025 05:05 PM
Same here. It can not find the verification.
Tried everything. Followed all the steps. It is not wrong in Tv settings, not the cable and telephone settings.
It is once starting a few hours ago.
This morning everything was fine.
So frustrating.
03-09-2025 05:04 PM
same here, the chromecast was working yesterday, but not today, please google help resolve the issue.
03-09-2025 05:09 PM
I am having the same issue. This needs to be corrected immediately and how are we to know when updated?
03-09-2025 05:10 PM
Oh crap, so this is all over the world? One of mine did the same exact thing today and i´ve been trying to fix it to no avail. Did a factory reset and now when I try to set it up my phone says Google home finds it but cannot connect to that temporary wifi network the Chromecast makes. Just says it cannot authenticate it or something like that.
03-09-2025 05:12 PM
Seems there is an outage on the service https://9to5google.com/2025/03/09/chromecast-2nd-gen-audio/
03-09-2025 05:14 PM
2 x 2nd gen not working... I've tried everything, same message not authenticating... Aarrgghh!
03-09-2025 05:14 PM
Meu Chrome gen 2, estava funcionando perfeitamente, dei pause em um filme e ele simplesmente travou. Reiniciei o aparelho e ele não autentica, pede pra entrar em contato com o suporte. Gostaria de ajuda para uma atualização e para ele autenticar e eu conseguir configurar novamente.
03-09-2025 05:15 PM
Same issue here! Both chromecasts. Living room and bedroom.
03-09-2025 05:14 PM
Same here, It worked lat night (Canada EST) Google home Detect it, but we'll not authenticate it.And and I also got a firmware message to is google going to fix this
03-09-2025 05:15 PM
Gen 2
U.S.
Factory reset Chromecast, rebooted wifi & all other connecting devices. At least before the reset I had the nice picture & the time. Now it just says get the app I already have and then won't authenticate.
03-09-2025 05:19 PM
Same issue happening. I am very upset. I do not like the features of the newer Chromecast. I have one and it's so annoying because my kids can use the remote to access unrestricted YouTube and if there's a way to get around it I haven't found it. So I hid the remote for now, but I WAY prefer the older chromecast model, it is SUPERIOR...
But now just like everyone here, it is not working.
03-09-2025 05:20 PM
Problema de autenticação
03-09-2025 05:20 PM
Same here
03-09-2025 05:21 PM
Como uma empresa confiável pode deixar todos os clientes sem o serviço
Espero que volte a funcionar
03-09-2025 05:21 PM
Same problem here in Massachusetts. Looks like we are going on hour 7 now
03-09-2025 05:23 PM
If you change the date on your phone back 2 days, it will reconfigure but still not be found on the network. It will display time, weather and the pictures again on your TV though.
03-09-2025 05:25 PM
exact same issue here
03-09-2025 05:26 PM
Meu chromecast estava funcionando hoje normalmente, porém parou seu funcionamento de repente.
tentei fazer atualizações, reiniciar porém nada funcionou, perdi meu aparelho pois não consigo acessar para atualização.
Alguém poderia me ajudar?
