Update 3/20/25
Update 3/17/25:
Update 3/14/25:
Update 3/13/25:
Update 3/11/25:
Hi all,
Thank you.
Thank you for your patience.
03-20-2025 10:49 AM
03-09-2025 10:39 AM
Funny, I just started having issues with my Chromecast audio too.
Tried a reset of the device and now cannot add due to some authentication issue.
03-09-2025 10:37 AM
Same with my chromecast audio
03-09-2025 10:42 AM
They may have quietly ended support. Ridiculous.
03-09-2025 11:02 AM
Same here. The entire house is set up to stream to Chromecast audio devices. Tried resetting and updating Home as well - no luck, and now a reset device that can't authenticate?
Everything has worked fine for YEARS without any changes or adjustments. Hope is not a push to force people to buy Google speakers as Chromecast Audio was a perfect setup - no need to drop support when it simply works.
03-09-2025 11:05 AM
I am receiving this error on I believe a generation 1 Chromecast... If they're going to stop supporting a device. I hope that they replace it in some capacity or give us a discount on the next device.
03-09-2025 11:10 AM
I’m having the same problem. I restarted the chromecast, my router, updated the app, etc. and now it won’t connect at all. So frustrating!
03-09-2025 11:17 AM
I'm seeing a lot of this across the board right now. It looks like my Chromecast audio is also affected. Fingers crossed, that it's a mistake and they'll push out an update. My biggest fear is that they stopped supporting all these devices since they stopped making them.
03-09-2025 11:36 AM
Same here, started this morning with Chromecast could not authenticate if you try to set it up after removing and adding as suggested by previous posts when this happened 2 years ago
03-12-2025 12:02 PM
It looks like this is a certificate glitch and should be fixed but if it isn't fixed I guess I'm just going to go and get a Bluetooth dongle and suffer the slightly less fidelity.
03-09-2025 12:11 PM
My chromecast has been working for years, and now all of a sudden since around 5pm it stopped working. It keeps saying it can't authenticate
03-09-2025 12:14 PM
Same here
03-09-2025 12:28 PM
Same here
03-09-2025 12:15 PM
Same for me. Saw all my chromecast offline. Already done a reset of all chromecast. When I try to add them with google home it says they are untrested devices. Good job google! Please don't update anything..it is worst everytime!
03-09-2025 12:19 PM
Same here.
03-09-2025 12:19 PM
Mines just dome the same this morning too
03-09-2025 12:19 PM
Same for me...useless
03-09-2025 12:22 PM
I have the same problem, any possible solution?
03-09-2025 12:24 PM
A similar problem occurred a few years ago. It recommends reboots of pretty much everything. However, this didn't work for me.
03-09-2025 12:24 PM
Same here.. both devices.
03-09-2025 12:30 PM
Mismo problema. Espero alguien publique la solución. Ya probé todo
03-09-2025 12:35 PM
Me too
03-09-2025 12:39 PM
Same here
03-09-2025 12:43 PM - edited 03-09-2025 12:47 PM
Same here multiple devices. Except mine aren't gen 1. Mine doesn't say untrusted device. Mine says unable to authenticate device.
But the result is the same. No working Chromecast.
03-09-2025 12:31 PM
My Chromecast stopped casting, so I am going through all the ways to try to reconnect it. After unplugging/resetting/rebooting the device, deleting the Home and adding a new one, I am trying to setup the original device, but after Google Home finding and identifying the Chromecast, it fails repeatedly with the above message being displayed. It is a 3rd gen model (without the remote).
Has anyone discovered a fix for this? I did call Google support, but the call was disconnected due to a poor signal.
Any advice gratefully received,
Neil
03-09-2025 12:33 PM
The same 😤
03-09-2025 12:34 PM
Same for me 😬 no solution!
03-09-2025 12:35 PM
And another one...
03-09-2025 12:34 PM
Pareil ...
03-09-2025 12:34 PM
Same here, I have 2 and both are doing same
03-09-2025 12:34 PM
I am experiencing the exact same problems rigtig now
03-09-2025 12:35 PM
Estamos extamente com o mesmo problema. O nosso é cde 2° geração, será que desatualizou?
03-09-2025 12:37 PM
Same here. Try everything. So frustrating.
03-09-2025 12:37 PM
Same problem
03-09-2025 12:40 PM
Same here, with two 2nd gen 😢
03-09-2025 12:39 PM
Ok I have the same issue currently. Good to know it's not just mine.
03-09-2025 12:39 PM
Mesma coisa aqui. De repente parou de transmitir e nao conecta mais aparecendo a mesma mensagem
03-09-2025 12:40 PM
I have the same problem right now
03-09-2025 12:40 PM
Same Problem
03-09-2025 12:41 PM
Hope that they don't stop support the Chromecast Service without telling....🙄
03-09-2025 01:42 PM
Same. I was literally using my Chromecast Audio this morning to stream Spotify.
It looks like someone in the datacenter finally pulled the plug on Chromecast. I know they ended the product in 2019 and said they'd keep releasing updates until September 2025 but it looks like a TLS security certificate on the device finally expired or something and they didn't update it to a new one. Now we all throw them away because Google won't allow us to transition it to the OpenSource community and maintain it ourselves. What a waste.
