GoogleNestTeam
Community Manager (Admin)
Update 3/20/25
Update 3/17/25:
Update 3/14/25:
Update 3/13/25:
Update 3/11/25:
Hi all,
Thank you.
Thank you for your patience.
GoogleNestTeam
16,142 REPLIES 16,142
I set up my chrome cast to factory setting. Still not working, 3 days now, please fix it as soon as possible!
I never factory reset my Chromecast audio but did remove it from Google home devices and I can't reload that currently. I've two other Google Chromecast audios that are working fine now as I never touched them having thankfully been one of the lucky ones reading the post not to do the reset but I'd already moved the one Google Chromecast audio from the home app by deleting the device and it won't reset it back up. Or it's not recognising it so I'm hoping that's the fix that still needs to be rolled out.
For the rest of it thank you kindly for your help and thank you for restoring some of my audio devices I hope others are getting that resolved too and things are starting to work better for them soon.
Update successfully applied to 2 Chromecasts. Casting works again!
I performed a factory reset (they made an official statement the day after) but readed someone changed the date on his phone before march 10 and worked. Did the same thing and worked, it allowed me to connect to my wifi, install the device and after that (with patience) the download started and finished all. Works fine. Thanks to the user who share that in this forum, I know its not a proper solution but its a solution.
Inform
No problem with some of my Chromecast Audio even after factory reset. I just change my Iphone date to  1st of feb and installed it again! After this I just left it on and after a couple of hours they are up and running again!
I reset the system! I’m waiting por news reconsiderations.
See my earlier post. Cheers
Almost 10,000 have responded and still no results. This is very disappointing.
Finally it’s working.. (Chromecast 2nd Gen)
It ok now what happened??????
My factory reset Chromecast is now working. Mind you I did the setup with my date rolled back to the 7th and everything went well and it completed the setup, which it wasn't doing previously. Then set my date back to normal. Cast Netflix from my iPhone perfectly. I'm not sure that I needed to set my date back to setup. I suppose I should have tried that first. Might be worth a try.
Buongiorno a tutti, io ho risolto questo problema in modo piuttosto semplice. Premetto che dopo il malfunzionamento avevo resettato il dispositivo Chromecast e quindi non si collegava più alla rete wifi. Provvisoriamente è necessario avere un vecchio terminale (io avevo un vecchio tablet con android 7), ma successivamente non sarà più necessario e si potrà usare il proprio attuale smartphone o altro ed usare Chromecast come normalmente
Stone66
Come hai fatto?
Clab
Hai fatto un aggiornamento?
Working thank you Google from NZ
🥲 6 days later: it finally works again...
Várom a frissítést!!
Any update on the factory reset?
Just got my reset Chromecast to setup. I setup with my iPhone date set to the 7th and the setup went perfectly. Then set the date to proper date all all is good again.
Obrigado fiz o mesmo deu certo
I confirm my Chromecast audio is working again 🙂
I get no message at all, I cannot cast anything, e.g. Google TV, Prime, YouTube.  It just won't connect to Cromecast all, flashes and that's it?
It works now. Thank you!
I was one of those people that performed a factory reset, before I saw this post.
But I was able to reconnect the Chromecast to my WiFi, by changing the date on my phone back to February 28th. Then configure the chromecast via the Home app.
Ok I have got mine working. This what I did, it's Android only. I hope it helps.
1. Switch on the Chromecast connect to your TV
2. Put the Android phone date back to 7th March.
3. Switch on Bluetooth and the hotspot on the phone (my phone is my WiFi)
4. Open Google Home, add device
5. It should find the Chromecast and switch on WiFi if prompted
6. Assigned the WiFi name & password to the Chromecast.
7. It may take a couple of goes but it should eventually get the wallpaper up.
Now your back to where we where on Sunday evening. On the WiFi but no streaming.
8. Put the phone back to today date.
9. Leave the Chromecast switched on for 30mins.
10. Switch off the Chromecast, I left it off for an hour.
11. Switch the Chromecast back on and it should join the WiFi, then leave it. Mine started an update
12. Once the update was done, I force stopped Google Play Services app on the phone.
13. Open Google home on the phone and the Chromecast was there and I am back streaming.
I wish everyone luck
J_Clark
Yes, that pretty much summarizes it.
Just one thing on #10. In my case both Chromecasts received the fixed after I turned them off and on without waiting more than 10 secs.
Ma quanti giorni ci vogliamo per risolvere il problema????
Thank you for getting it done. My two CC units updated and all is fine again.
Finally sorted for me in the UK.
This may help others.
1 I did the routine to get them back connected to Google by setting the date on my phone to the 8th of March. Like around 99% of people I had already done a factory reset before seeing Google's rather lame and belated 'do not factory reset warning'.
2 I left both connected to a mains power source, NOT a USB port on the TV's which go dead when the TVs are off.
3 Kept resetting them, though NOT a full factory reset, just unplugging the power and plugging back in.
 4 Then on doing this tonight at about 7pm (GMT) first one then the other both updated, shut themselves down and applied the update.
All working fine....
Restaurei de fabrica , porque  fui informada pra fazer isso polra voltar a funcionar , estou muito chateada por estar sem funcionar , aparelho tem q ter vida útil  sem tempo determinado , qdo comprei ninguém disse ou veio alguma nota dizendo que era descartável , espero q a solução seja restaurada o mais rápido , é um crime contra o consumidor , perdi tempo s pra tentar fazer funcionar pq nem aviso havia q estava com problema no sistema  do Google , estou aguardando retorno e como fazer pra funcionar .
Anonymous
Not applicable
Está solucionado (chromecast audio). Gracias, a pesar de la espera
FIXED!
Today I have reconnected my device to internet by setting my phone on a date before March 9, 2025. Then closed the Home app.  Opened it again and set up the Chromecast V2.
Once it is set up and therefor connected with internet, you can turn your phone to automatic date again and simply wait for the google firmware-update, keeping the device on power and consequently connected with the internet!
And just now at 20:35 CET, strictly coincedentally while I was busy with an alternative device, my Chromecat V2 suddenly connected and is enabled to cast as it used to. Finally!
Nice day to you all!
Its working 🙂🙂🙂
Stone66
My reset factory nooooo !!!!
Ho risolto il problema cambiando data allo smartphone, ho messo 7 marzo 2025, ho ripristinato di nuovo e ho effettuato la configurazione. Funziona tutto bene.
Anonymous
Not applicable
Many-many-many thanks!!! 🙏 ❤️❤️❤️ It works again! ❤️❤️❤️❤️
I have two Chromecast Audio devices. I factory reset one before discovering this thread. After noticing my non-reset device reappeared, I decided to try reconnecting the other one. During setup, the phone repeatedly timed out when attempting to join the Chromecast's ad-hoc Wi-Fi network. However, manually connecting to that network allowed the setup process to complete smoothly.
Huge thanks to everyone involved in deploying this fix, you're amazing!
No estaba informado y cometí el error de tratar de configurar mi dispositivo Chromecast antes de que avisaran del error.
Motivo por el cuál lo reinicie.
Esperamos solución prontamente dado que sus prestaciones son muy necesarias para nuestro trabajo.
Desde ya gracias..
Bit late with this announcement. Already factory reset my chromecast audio. Even tested with a 2.4 wifi only ssid. Pitty only older devices have this issue, cause it feels like teasing so people buy newer devices.
Hope for a quick fix, cause my home office is now without music to keep my working spirrit uit.
Almost bought a SonosOne just cause I was done with chromecasts failing to connect. Its not the first time there are issues.
But I'll wait and see if this can be fixt in time.
