GoogleNestTeam
Community Manager (Admin)
Update 3/20/25
Update 3/17/25:
Update 3/14/25:
Update 3/13/25:
Update 3/11/25:
Hi all,
Thank you.
Thank you for your patience.
GoogleNestTeam
16,145 REPLIES 16,145
  1. In case the chromecast is factory reset, just change the phone Date time to before March 10th. And turn off automatic date time settings. ( I changed my phone date to 10th March 2024) Then try to add the chromecast.  It worked for me. Once chromecast is connected to wifi, it will update the recent fix released by Google.  Then all set. Thanks Google!
Waiting
Thank You
Please Fix the reseted Chromecast asap
But I already chosen option factory reset plz provide me the step since last 15 days i haven't using this
Anonymous
Not applicable
My 5 devices are all back working, so all good. Thanks!
Parou de funcionar
Any timeframe for the fix? It is quite inconvenient to existing chromecast users…
Pleased to say my CC Audio is working again today
The fix has started to roll out
I even had a text message from Google Nest to let me know
I want
Arnit
@Arnit wrote:
I want
How long will it take
Anonymous
Not applicable
E sobre a atualização para quem já fez a reinicialização no dispositivo?
Anonymous
Not applicable
Mudei a data, mas fica atualizando e não resolve.
Everything is working again!
Thank you.
Please ensure these devices continue to operate and consider reinstating the Chromecast line if devices, they are a valuable device.
Hi all. Firstly, thankyou development team at Google for looking into this. It is greatly appreciated!!
Seeing a partial fix here. E.G. even though I have factory reset my Chromecast Audio, I can reauthenticate it if I use WIFI and obviously to do that, I must be on the same 2.4G network. However, previously my Chromecast Audio Would work after factory reset when using it on ethernet with an ethernet adapter. That said, once the device is reauthenticated on WIFI you can plug it into a USB to ethernet adapter and it will again work on ethernet.
Current known issues:
Even when the device is reauthenticated and back on the network, you cannot change any of the audio settings on it such as choosing the “Full Dynamic Range” checkbox or turn the volume up. That is because Google Home says “these settings are currently unavailable”. This happens if you are using wireless or an ethernet adapter where as previously this did not matter and all settings were available if you are connected to the same network. You can for now workaround the volume issue by asking the Google assistant to set the volume to ten for the device in question.
Also, you cannot create or add the device to any current speaker groups that you may have and currently I am not able to create any speaker groups in the Google Home app.
Finally, a long standing issue is that if you are using Chromecast audio devices in a speaker group and you ask Google to stream something that is only available on YouTube, and you as and end user don't know that when making the request, it will fail. What should happen is the audio should be streamed to the speaker group in question because it is audio. I suspect that the reason this fails is because Google assumes that users may wish to watch the visual content of the video. However, as lots of music, podcasts etc are available on YouTube, the audio should be streamed anyway.
Kind regards, Phil Muir
DeMuirs
Update. Checked my Google Pixel 7 Pro for app updates on the Play Store. Then, rebooted phone and I can now change audio settings and add speaker groups in the Google Home app.
DeMuirs
Interesting. 2 of the 3 Chromecast Audio devices that I have here updated when connected to WIFI. The third one refused to connect and displayed the following error message:
We couldn’t Authenticate your Chromecast. If this happens then set the date on the device that you are using with Google Home before March 9th 2025. Then you will be able to get your Chromecast going again. Note: have since reset one of my Chromecast Audio devices and at this stage it is no longer possible to set-up one of these on ethernet after a factory reset. Hopefully Google may address this particular issue in the future.
We already found the problem 1 from 3 Chromecast
not working, the 1 due to We already factory reset it
and 2 Chromecast already fixed after update .
please help asap
Nach Werksreset am Handy das Datum vom 9.03. Einstelken, dann kann man Chromecast erneut installieren. Bei mir hat es so funktioniert. Danach ist das Datum am Handy wieder auf dem neuesten Stand, sonst geht es nicht.
Hi Nest Team, what’s the latest? I performed a factory reset and cannot connect… Hope we can resolve this asap! I can’t live without my Chromecast
Gisa25
Nach Werksreset am Handy das Datum auf 9.03. einstelken, dann kann man Chromecast wieder installieren. Bei mir hat es so funktioniert. Danach das Datum am Handy wieder auf aktuell, sonst geht es nicht.
IP2
Cambia la fecha en el móvil anterior a 9 de marzo. Configura el Chromecast. Así se conecta al wifi.
It’s back online! Thank you GoogleNestTeam
Thanks for the resolution, my three devices are back online (I hadn't done a reset).  Kudos.
My chromecast problem is solved..I hope it will be same for rest of the users..thanks google team👍❤️
I had my chromecast gen 2 factory reset: today I set my phone calendar to 03/03 and did the pairing through the google home app. Chromecast updated by itself and is running again
Will you send an email to inform us that everything is OK or do we have to look by ourselves for the info every day ?
I did the factory reset what I will do now ? 🥲🥲
Vamos ver se resolve logo, uso todos os dias...
Both my chrome cast audios are "offline" I haven't reset them other than a powering them off and on again. How will they receive the update if they are offline?
Já sabem que a maioria restaurou o aparelho, foi uma das primeiras coisas que fiz. Precisam resolver o mais rápido possível.
Io avevo ripristinato le impostazioni di fabbrica. Come posso avere una notifica nel momento in cui il problema viene risolto senza dover entrare nella Community?
I find it ironic that in the age of mass information and social media Google did not warn people in a more effective manner. All of us who reset our devices did what we were instructed to do in trouble shooting. We just reset the device and now this. Looks like it's time for Roku or Fire stick!
Do you know about how long it will be
Hello. Is there any news about those who have made the factory reset?
En tu móvil pon una fecha anterior a 9 de marzo. Así podrás configurar el Chromecast y conectarlo a la red wifi
Still not working
O prazo pra solução desse problema é até quando? Já tem dias que está com esse problema.
Ajuda nós aí por favor.
I updated google chrome, and changed mobile date (08/03/2025) google crhome has updated and now it's ok!!!
And those who have done the factory reset, how will we know what to do?
