GoogleNestTeam
Community Manager (Admin)
Update 3/20/25
Update 3/17/25:
Update 3/14/25:
Update 3/13/25:
Update 3/11/25:
Hi all,
Thank you.
Thank you for your patience.
GoogleNestTeam
16,159 REPLIES 16,159
Anonymous
Not applicable
When setting the date on your Android device to 8th of march or earlier you can setup the device. It will update and after you can set your date back to normal. Everything will work as before.
I don't think my android device allows me to change the date and time
I already did factory reset. When this issue will be fixed?
When are you going to sort the issue out?
And how are you going to go about compensating your customers for this grevious error - as I'm sure you'll agree that your customer service has been distinctly lacking along with your communication skills!?
It’s been a week from atleast I got to know about it.. when will this get resolved??
Io ho eseguito il ripristino alle condizioni di fabbrica, Chromecast non funziona come mi posso comportare?è previsto che ci diamo una soluzione in tempi brevi?
chrome not connected to my phone
Adhjjjjjjjjjjkkkkkjjjjjkk
I just tried re-adding my Chromecast Audio via my Google Home  on my Pixel 7 phone and I still get the "We couldn't authenticate your Chromecast Audio" message. I probably did factory reset my device when the problem occured, before Google posted their initial message not to do so. Now I'm waiting for a fix...
You have to wait for Google to fix it. They already fixed my regular Chromecast. I was able to add my Chromecast audio back to my home devices by changing the date on my phone to before 3/7 but it won't work until Google updates the certificate. Should be this week.
I factory reset before even knowing about the firmware problem, so I hope there's a way out of it soon, I use my chromecast religiously. I think if there's no fix for factory reset devices then an upgrade should be offered atleast...
Para correção da redefinição de fábrica, basta alterar o dia no smartphone para 8-março, e fazer novamente o procedimento de redefinição de fábrica.  Após concluir, voltar o dia para automático no smartphone.   Entendo que engana o dia que expirou o maldito certificado em 9-março.
Please try to fix this asap. I never expected this much delay for a fix from Google product.
Anonymous
Not applicable
Hello! I like to get an update, cause i’m one of the people who resetted my device and i am not able to reinstall for over a week now… i would be very pleased if we get to know about the status of the Problem!
kind regards, Marloes
I reseted mine too but I follow the procedures and it's running now.
Fahadii024
How long will this go on for? Even now when trying anything and everything to (re)set up chromecast the FIRST thing the help page says is a factory reset!!! I refuse to buy another device because my current chromecast should not be at end of life…come on Google where is the solution to get back online! It’s been 7 days without connection now
Hi guys, have you fixed the issue for those who had reset it?????
I'm having problems with my Google Chromecast
Ya funciona, todo correcto, menos mal que no lo restableci. Gracias
I didn't know and I re-setup my device, what can I do, just to wait?
We "continue to check the Community page here for updates and next steps" and no news... Are you really trying?
Buongiorno,avendo ripristinato le impostazioni di fabbrica del mio chromecast non riesco più a connettermi. Come posso fare???
vlagger
Ho risolto forzando la data dello smartphone a prima dell'otto marzo, poi si riconfigura, fa l'update automatico e torna a funzionare.
ustedes desarrollan inteligencia artificial?
pobre de nosotros
Just fixed now. I did factory reset and did't work without possibilty to teconfigure it.
I forced date on the smartphone to first of march, after that I was able to reconfigure it with app home. Now (after the update) is still working fine.
Lo restablecí de fábrica antes de ver esto siguiendo los pasos que se me recomendaba en la app. Qué tengo que hacer ahora?
I think most people in this thread after a few attempts will have factory reset their device. Please advise on how to fix one the fix is available. Thanks.
im from the philippines... still not working.. i hard reset the the device .. i cannot connect now
Try to update your device date to 1st March and then connect chromecast and follow the procedures.mine is working.
Fahadii024
Hello, i’ve done a reset factory on the troubleshooting. But it steel don’t work.
the chromcast Connect to the Wifi but dont work with my iPhone 🤷🏽‍♀️
Fahadii024
Many thanks 🙏, my CC is back to normal functioning. I hope you take necessary precautions to avoid any future problems. Thank you again.
Stroh300
How??
Mine still does not work
Try to change date of your device before connecting to chromecast.change date to 1st March 2025 and then connect to Chromecast
It will update and will connect your Chromecast.as mine is running perfectly.
Fahadii024
Tenho 2 aparelhos e reconfigurei de fábrica. Por favor postem como resolver.
Anonymous
Not applicable
Yep still got a problem as factory reset the Chromecast device, annoyingly .Any time frame idea on the fix week's ,months?
Try to update your device date to 1st March 2025 and then connect chromecast and follow the setup.it will be run as I did and it is running on my side.
Fahadii024
My iPhone won’t let me do it
