GoogleNestTeam
Community Manager (Admin)
Update 3/20/25
Update 3/17/25:
Update 3/14/25:
Update 3/13/25:
Update 3/11/25:
Hi all,
Thank you.
Thank you for your patience.
GoogleNestTeam
16,137 REPLIES 16,137
È scandaloso.
I already factory reset my Chromecast. Please help me. What I have to do?
So when will this be fixed for those of us who followed the usual Google reset!!!!
Any update on this? I purchased a Chromecast gen 2 and cannot set it up.
When do you expect to solve the issue? In our case we did a factory reset. Nothing is working. Can you communicate a clear timeline? Thank you
How are we going to know if you fix the problem?
So we do another factory reset or what? Email says it's good to go, and i just tried to connect it again and it still doesn't work
How much longer is this issue going to last? It’s been 2 weeks!!!
It still doesn't work! I reset the settings. You'r company as stupide
Changed date The Smartphone for 03/01/25, Reset Chromecast. The equipament automatic atualization. Uhuuuu this OK....congratulations....TKS
Has there been a fix for those who did a factory reset?
After reset and following instructions including setting date back to Mar1st than adding the chromecast device, connection happened (yay), chromecast was automatically updated and everything is working, thank you so much to whomever posted this fix 😊
Do not factory restart
Problem SOLVED:
1. Uninstall Google Home app
2. Install again  Google Home
3. Change date and hour to your mobile phone to march 10th 10:00
4. Set-up again Chromecast (receive update)
5. Change you device date in automatic mode.
Chromecast is ready to stream
B*LLSHI!!!
Muchas gracias por todos los comentarios. El mío ya funciona. He seguido los pasos que han sugerido muchos usuarios:
1. Desconectar la fecha automática del teléfono desde ajustes.
2. Configurar manualmente otra fecha anterior al domingo 9 de marzo de 2025, concretamente he puesto el 1 de marzo de 2025.
3. Configurar el dispositivo desde la aplicación Home.
4. Se ha instalado y los he conectado a la misma red wifi.
5. En un principio no reconocía el chromecast, pero al volver a configurar la fecha automática, lo ha reconocido y, ahora, funciona perfectamente.
Muchas gracias por los comentarios y la ayuda.
Espero que pueda servir de ayuda a otros usuarios.
Thanks for fixing my Chromecast 2nd gen and Chromecast Audio devices!
I’ve been without stereo in a space that is always using it. Super frustrating for these issues to prevail for such a long time. Please please please help!!!!!!!!
Continuo sem poder usar o Chromecast
PODEM ME AJUDAR
POR FAVOR
Logré configurarlo y funcionó por un hora y luego se desvinculo solo. Ahora estoy a l espera que me den una solución. La aplicación no puede conectar con el dispositivo. Espero noticias a la brevedad.
Very effectively
I did a factory reset, per the Trouble Shooting documents, and now it's two weeks that I don't have service.
  • Does nest need wifi to work
Man can we get a little more feedback? It’s been over a week now.
Pentru cei care am dat resetare la chromecast când remediați problema?
Still not working
Definitely a huge inconvenience! Upgraded to the the Apple TV have not had any issues and is a lot quicker. Super disappointed!
Desde o dia 9 meu Chromecast não funciona,estou sem tv ,ou vcs solucionan ou vou procurar meus jurídicos estou sendo lesada,pois n posso ver tv,quero solução urgente
1234567891012
Any updates on this yet?? Unfortunately I'm one of the ones who factory reset...
Hallo,
Je smartphone datum op 8/3 zetten.
Je chromecast volledig opnieuw installeren. Je zult zien dat hij een relevant woord heeft. Ondertussen mag je de datum terug naar huidige datum veranderen. Rustig wachten tot hij volledig geupdate is is terug. Kan snel maar ook een dag van 2 overgaan. Bij mij 2 dagen dacht ik. Ikzelf had ook fabrieksrecet gedaan. Door deze methode werkt hij terug perfect
Johan België
Well google disappointed frustrated is just the beginning of how this issue has affected so many of your customers.  I don't think he response have patience is acceptable or the time frame to fix the issue . When someone relies on the device to stream tv how could this time period be reasonable.  I'm sure I'm one of many that purchased googles latest tv streamer at a cost of 3 times a chromecast plus a hdmi cord required not included for another 20$ so total purchase price of 150$ plus tax or sit around having patience but no way to watch television except via cell phone . So I'm sure the boost in sales of google latest product is a huge upside in this mess and perhaps made it not high importance to find the solution for a old model of their streaming devices . Huge turn off for any future products that I will NOT be purchasing after really being left with no choice with a non functional streaming device and very little info provided by google and a very slow response to get it fixed . Google needs to do better . As I'm certain the inconvenience frustration and like nyself purchasing another streamer at 4 times what I paid for my chromecast is just unacceptable and googke will do nothing to compensate for so many people left with no way to stream tv out of blue for a significant amount of time !! This was very poorly handled and managed and be very interested in knowing how much money was made over forcing the hand of many to purchase a new device or just sit patiently till the unforseen future hoping the issue gets resolved!!!
J1103
Hallo,
Johan België
J1103
Hallo
Je smartphone datum op 8 maart zetten. Chromecast volledig opnieuw installeren of beginnen met zowel Google Home.
Chromecast woord terug betekenisvol. Ondertussen mag je de datum terug naar huidige datum veranderen Beetje geduld tot hij volledig geupdate is.
Kan snel maar ook een dag van 2 overgaan. Daarna kun je terug genieten van je chromecast en streamen
Johan België
Hi
I can see that a google Home version 3.30.1.6 is mentioned. But when I check for the latest version in google play butik I only see version 3.30.1.5
How come
All the best
Kurt
Hi Kurt
I see the same in the Play Store. Latest update was on 25th of february for 3.30.1.5
This is issu becomes really annoying, Google!
J1103
Hallo
Kan snel maar ook een dag van 2 overgaan. Daarna kun je terug genieten van je chromecast en streamen. Johan België
Hi , I factory reset my google nest stopped working last night and only today have I seen message about this , I will wait and keep trying and give it a few days if need be .
J1103
Hallo,
Johan België
How long
