GoogleNestTeam
Community Manager (Admin)
Update 3/20/25
Update 3/17/25:
Update 3/14/25:
Update 3/13/25:
Update 3/11/25:
Hi all,
Thank you.
Thank you for your patience.
GoogleNestTeam
16,146 REPLIES 16,146
jaquelinemaria1
Meu Chromecast não quer configurar me ajudem
Es um problema a nivel mundial, as pessoas do Google estan trabalhando para resolver. Eu tamben tenho mesmo problema.
Aeronx
Hello I've been facing annoying issue, which is my Google Chromecast is unable to be authenticated through Google home even after performing several factory resets, hoping that it may solve the issue but sadly it did not, I really need help
There has been an issue with a bug affecting chromecast 2nd generation worldwide. They said don't do factory reset, they are working to resolve the issue with a patch that will be installed automatically since your chromecast is connected to a wifi
Mahe47
I have already given factory reset and waiting to resolve the issue by Google team...
JimmyBly
Just checked and one is back on line. Not sure when it happened as it was Monday when I first had the certificate problem and just looked now.
Other two are grayed out an I have not touched them. Only thing I did to the one working was reboot it prior to finding out about the certificate problem.
I may reboot the one of the offline ones and see if that triggers some kind of update and leave the other to see if it gets pushed.
Will update.
I rebooted one and after a few minutes it's online. Looks like you need to remove the usb power for a few seconds and plug it back in.
Good luck, going to reboot my last one.
FYI I did not reset any of my devices.
Stelica
 Hello! I understand that your chromecast is working? It says it's an old version and is offline. Can you give me details if it works?
funriz
J'ai 1 pixel8 et du jour au lendemain mon Chromecast 2eme Gen. A planté..ouf! Je suis rassuré, j'étais prêt a en acheter 1 nouveau car je pensais le miens mort..patience les amies
Tcass35
Purchased on Amazon about a year ago, when I try to install the device is found but then the message says could not authenticate, and hence will not connect to wifi. I believe the product is from Japan. Can you please help. Thanks Tony Cassidy, #
I have a pic of bar codes
I had issues as well with a thermostat bought from Amazon.  it is really hit or miss with Amazon and google Nest.  I am curious to know the outcome of this.  Have you tried to call google Nest support?
Jjjjjj72
If i had  the wold laergest didlo, i would showe it googlea ass. Fy
Fy fy fy fy fyyyy
Francqar
I still can’t connect and I haven’t done the factory reset. I just deleted from my devices but now I can’t get it back because it is not connecting. Google should address this priority. It is very annoying.
mustafa22022
Can't casting with google home after updated application
Lilianlemos
O meu parou de funcionar e pensei que restaurando voltaria ao normal agora não consigo finalizar a configuração. Preciso utilizar o serviço.
Alex_Lima
My second chromecast is working now thanks to johnnyzero2
felipe_goulart
Unfortunately, I did the factory reset before reading this advice.
What can I do now? Could you let me know the solution by email?  #
Thank you a lot.
Felipe
Jjjjjj72
Omg. Week from the error you sead dont reset? Are you in sane? Fy fy fy  idiots
Fy fy fy fy fy chromecast fy fy
Anonymous
Not applicable
Has anyone noticed any improvement yet?
Gracem
What if you already purchased another device?
Hassle2010
So Google finally posted that there's an issue and the advice not to reset comes in after the event. Typical of all technology companies! You guys never raise your hands and come clean whenever there's an problem. You just wait it out until everyone is shouting. Unbelievable!!! Not happy at all!!!
Mik4
Sigue sin funcionar. Ya van 4 días!!! Y entonces???
Jelly2
Who else bought a roku?
Mi suegro compró,  ahora tiene problemas con los controles remotos.... 😢
Deb83
This is ridiculous. If you can't fix the issue,a refund should be made so we can get different ones. It's been going on a week. I have 2 Chromecast and can't even use them.
Treehorn
My Chromecast Audio is now working.  I did have to power cycle.  Its my favorite Google product.
Teticba
No one has managed to get an update to revive our Chromecast; they've simply broken the only thing that worked. Shame on you.
Sujitsah29
I'm also experiencing issues with my Chromecast (2nd generation) not connecting to the Google Home app on my mobile. Do you have an estimated timeline for when this issue will be resolved?
Read the pinned status information at the top of this page.
Mik4
Creo que voy a dar de baja todos los servicios de Google. Correo, drive, navegador. Esto del Chromecast es vergonzoso
