GoogleNestTeam
Community Manager (Admin)
Update 3/20/25
Update 3/17/25:
Update 3/14/25:
Update 3/13/25:
Update 3/11/25:
Hi all,
Thank you.
Thank you for your patience.
GoogleNestTeam
16,151 REPLIES 16,151
Daniela3
Ho già ripristinato le istituzioni di fabbrica adesso cosa bisogna aspettare? Tra quanto tornerà a funzionare?
Double_22002
If you have done a factory reset on your chromecast, just set your date and time on your phone to 8th March 2025 and complete setup and then put your phone back to normal time 🙂
Oops I read this after I posted. Thank you.
Kris1212
Is there a way if this happens again to be notified via email of this issue so we know not to factory reset. Unfortunately I made this mistake.
Yes I've made the same mistake now I can't get it tox connect to the internet
Jenny7
Vi har inte fått nått mail. Vi fabriksåterställde våran innan ni gick ut med information om att man inte ska göra det
Antje
It works again!!!! Im from Germany...I did a reset (Chromecast 2) and nothing works anymore...so i put the date of my mobilephone  ( Android) to the 05.03.2025 and i could conected my Chromecast. Of course i put the date Back correctly...But it said since this morning, not the same Wifi...Now, all works.
Anonymous
Not applicable
We are past the next few days as your msg is 5 days old - when will the product start working again
br
mINE JUST RESET AND RESTARTED AND NOW IT WORKS AGAIN...tHANKS gOOGLE
Read the pinned status update at the top of this page. Google started rolling out a firmware update fix yesterday.
Buscolady
Okay... if not fixed by Monday,  I'm going to go with Roku.
Google started rolling at a firmware update fix yesterday. Read the status update pinned at the top of this page.
If you've already done a factory reset, you'll need to do this procedure in order to receive the update. Easy fix:
https://www.googlenestcommunity.com/t5/Streaming/Regarding-an-issue-with-Chromecast-2nd-gen-and-Chro
Ganesh99
It's obvious person facing not connecting issue had done factory reset initially.After not resolving issue they tried to check support which had put warning not to factory reset device.
I need to ask you when will we getting update for device which got factory reset.And it's very much obvious to raset device before check Google nest forum.ty
Bas3
The Chromecast-update just came though!
It will update automatically...
At least, in The Netherlands!
Rodge
Now my Chromecasts are online in the Home app again (went offline 9th of March). Still can't cast to them!?
I can tell my Google Assistant on other devices to turn the TVs on and off so they are indeed online and connected.
Anonymous
Not applicable
"It has been nearly a week since the issue occurred, and we have yet to receive any updates. This lack of communication is unacceptable, especially since we still do not have an estimated resolution date. We require immediate clarification on the status of the issue and a concrete timeline for resolution."
Did you read the update status pinned at the top of this page? Google started rolling out a firmware update fix yesterday.
Raabn
Already reset Chromecast, took you like 5 days to send an email that said do not reset, and reddit was faster than you..
Apambalbo_45
Ainda não consigo configurar, vejam isso rápido
Franci84
Quanto tempo ancora ci vorrà per risolvere un problema così.?
Impossibile tutti questi giorni per aggiornare un vostro servizio.
Elisa2
Io ho ripristinato il cromecast purtroppo e non funziona ancora nulla
OneandOnly2025
***Follow the link, it has worked for me everyone. You do need to set the date back on your mobile device. Read the instructions.   Wait and be patient. Chrome cast will automatically do a reboot. I hope these pics help. 🙂
https://www.googlenestcommunity.com/t5/Streaming/Regarding-an-issue-with-Chromecast-2nd-gen-and-Chro...
Muito obrigada segui oq vc falou deu certo.
SEMPER
Quando isso vai acontecer, já estou a mais de uma semana esperando resolverem esse problema...
Ivanzarandona
Cuando se soluciona el problema de chromecast, la comprr pra poder utilizarlo, si ya no va a funcionar pues les pido el rembolso del efectivo o me xen otro producto, licenciado ivan zarandona voy a ir a profeco para iniciar una queja buen día
Cente
Algunos libros deberían leer los mánagers de Google.
¿Con esta ineficiencia están generando inteligencia artificial?
Estamos perdidos...
Anonymous
Not applicable
I did a factory restart before reading this post as that is part of the normal troubleshooting process.
Can you please confirm what I am supposed to do now to get this to work?
Shame on Google, this is effecting so many users and its very concerning it is taking this long for a solution.
Anonymous
Not applicable
Just set your phone back prior to March 8, you'll have to go into settings and manually set the date prior to this past Sunday, then go into Google home and reset up the Chromecast device and once the Chromecast device is connected to the Internet at that point you can go ahead and put the date back current on your phone. Now if you just unplug your Chromecast device and plug it back in it should reboot and will likely take the update to fix it.
I can't believe that Google hasn't pinned this information to the top of this page, for all the thousands of folks who have done a factory reset.
In any case, it's an easy fix. Just do this:
Chriiiiiis
If you already reset the device and can not set up the Chromecast, just change your mobile phone date a year back (24) and then art up the device with Google home
Rob242
Yes!! It's finally working. I followed the instructions of changing your phone 1 day before the problem started. So I set my date to March 8th on the phone and then opened the Google home app. Followed the instructions and started to update. After the setup it started to cast again. Make sure to set your date back to automatic on your phone after setting up. Thank you to all the people on this forum for your help. And thank you Google for the updates. Take care everyone
sanrubmartin
Es viernes 2.38 pm en Argentina, aún no puedo usar mi Chromecast 2, pese a leer que han resuelto el tema. No reinicié dispositivo
Supposedly this is being done as a phased rollout, so it could be several days before the firmware update fix hits everyone's Chromecast. Patience.
Hola!! Yo soy de Argentina y acabo de enchufar mi chromecast y ya se actualizo y funciona!!! Yo no lo habia reiniciado.
DirtyBiker
When are you going to fix my Chromecast?
