GoogleNestTeam
Community Manager (Admin)
Update 3/20/25
Update 3/17/25:
Update 3/14/25:
Update 3/13/25:
Update 3/11/25:
Hi all,
Thank you.
Thank you for your patience.
GoogleNestTeam
16,160 REPLIES 16,160
I did a factory reset, so I continue having issues, waiting for your help please.
For iPhone users you can turn all your location services off which will allow you to change your date and time. I was able to update my firmware by doing that and changing the date like suggested by many users
When will a fix be released for people who did a factory reset?
CASTAÑON SORIANO HUGO
Still isn't working my Chromecast.
NESSUN AGGIORNAMENTO RICEVUTO....
Please can you update on a daily basis. How long are we going to have to wait for a fix for this issue?  I'm missing my music. Thanks
When can we expect the resolution still its not working it's so many days ofcourse we will perform factory reset as there was no message earlier when it was of
I suspect they're going to take the easiest way out: pull the plug on all of these devices.
As long as they give my money back...
届きませんでした
Sigue sin funcionar mi dispositivo!!!
O meu continua com erro pedindo para acessar ao painel ajuda .....como faço?
I reset my device and I can’t conect again with the network
Any news on 2nd gens gaining access?
Il mio chromecast continua a non funzionare.
MODIFICA LA FECHA AL 7 DE MARZO EN TU DISPOSITIVO E INICIA LA CONFIGURACIÓN HOME DESDE CERO. FUNCIONA. NO OLVIDES ODIAR A GOOGLE
I reset my Chromecast and now it is not connecting me to Chromecast.kindly let me know what to do now?I want to run my Chromecast device as soon as possible.
Fahadii024
Hoje é dia 15/03/2025 as 17:40
Segue a dica que consegui no fórum...
1- Altere a data do teu smartphone para 07/03
2- Reinicie seu Chromecast, apertando o botão ao lado do aparelho
3- Abra o App Google Home e faça a instalação de um novo dispositivo Chromecast
Após isso o Chromecast vai atualizar e só seguir as informações na tela do celular.
Espero ter ajudado, deu certo aqui.
Still not able to connect
Eu acabei redefinindo de fábrica o meu, e até o momento não consegui conectar
My Chromecast needs to be set up so it can connect to my wifi. Device Utility doesn't work on my Pixel 8 phone. Any workaround for this?
ElTacos
Manually changing the date of your pixel 8 (to march 7th) before retrying the setup with Google home is a working solution
Quem tem iPhone ou iPad e restou o aparelho, consegue conectar ele na internet, basta voltar a data para dia 8 de março por exemplo. E adicionar ao Google home, com isso ele vai baixar a atualização e voltar a funcionar.
Precisamos  da correção com urgência
Reiniciei em configurações de fábrica e não está validando, vem mensagem para contatar o suporte 💔😖🥹💐🙏🏻🙌🏻🤞🏻
I did do a factory reset on my generation 2 chromecast before I found out about the problems please advise what action I should take to resolve the problem
Still not working and I can't talk to an actual person. Very frustrating.
Ya recibio la actualizacion. Funcionando.
Anonymous
Not applicable
so one other people who did a factory reset going to get help?
Nn estou conseguindo configurar
Its been a week now and I still can't use my chromecast.
A bit disappointing that you didn't tell people not to factory reset as soon as it happened and not days later, when all the help articles say to do so.
I did factory reset prior and mine is still not working
I was able to get my Chromecast Audio device back operational by using a USB Ethernet adapter instead of a wifi setup. I had the issue and attempted a factory reset which caused me to be locked out of initializing my device again. The Ethernet adapter allows bypassing the WiFi authentication issue. I used the TVxStream USB Ethernet adapter on the Chromecast Audio to do this.
Hi Google,
No consigo reactivar mi Chromecast gen2, el cual fue reseteado de fábrica.  Este equipo yo lo compré en otro país y lo estuve utilizando de forma normal desde el 2014, pero desde el 09marzo el error que me sale es: 'ESTE EQUIPO FUE DISEÑADO PARA OTRO PAIS, ES POSIBLE QUE NO PUEDA ACTIVARLO' ...
¿significa que ya no podré usarlo???, por favor ayuda, SOS
I had reset my Chromecast. Eagerly awaiting the fix for this case.
I have factory reset the Chromecast NC2-6A5 device please role of a solution at the earliest.
I have Chromecast with Google TV and nothing working as yet.
まだ事象は改善されないのでしょうか
更新でき認証できました!
Iam still not able to reconfigure my chromecast audio
