Update 3/20/25
Update 3/17/25:
Update 3/14/25:
Update 3/13/25:
Update 3/11/25:
Hi all,
Thank you.
Thank you for your patience.
03-20-2025 10:49 AM
03-17-2025 02:40 AM
Nice but like many others, I did a factory reset before seeing this ticket...
03-17-2025 03:04 AM
Unfortunately I did a factory reset, so my Chromecast is not working yet. Any update about this?
I tried several method also reported by other members, but I'm still blocked
03-17-2025 03:08 AM
Thank you! it is working now ...
It also corrected a bug in the Chromecast (2nd gen) that started in 2021 (I think), where the audio was fine, but the image was not casting ... so I had to use a splitter ... now I don't (fewer cables, fewer power sources).
Thanks!
03-17-2025 03:10 AM
when?
03-17-2025 03:41 AM
Non riesco ancora a installarlo dopo aver resettato il dispositivo
03-17-2025 04:07 AM
Leivi Santana
03-17-2025 04:58 AM
Había reiniciado antes de leer esto. Ahora como hago?
03-17-2025 05:28 AM
I still am unable to cast from my Laptop, although I am able to cast from my Pixel Pro 9. I never had the connections issue. I did do the Factory reset.
03-17-2025 05:38 AM
Disable auto date of your phone. Set the date to 7th of March. Add your Chromecast Audio as usual. Wait until it updates to the latest firmware.
At first it till not respond to "Under "Technical information," check for Cast firmware version: "X.XXX.XXXXX." If it's a display, check for Fuchsia Version: "X.XXXXXXXX.X.XXXXXXX." (See Chromecast and Google TV Streamer firmware versions and release notes - Streaming Help). Reboot the device and wait. It will update eventually.
Cheers.
03-17-2025 06:07 AM
Its easy to fix an factory reseted chromecast. Its only to back the date to before 9/3 for the phone you are uising to configur. Then it worked to configure and the chromcasts software was updated. Now it works just fine. Why doesn't Coogle inform about that?
03-17-2025 06:26 AM
Thanks for fixing my 2nd gen Chromecast - the update to the iOS app solved the problem including firmware update etc - had done the factory reset. 🙏
03-17-2025 06:34 AM
When will the fix available for the users who reset the device?
03-17-2025 06:57 AM
Do we know when the problem will be solved for the ones who factory reset there chromcast cos that is the first thing that was suggested when it stopped working? Otherwise I wouldn't have done a factory reset if that was the case.
03-17-2025 07:13 AM
Pls do it soon
03-17-2025 07:17 AM
03-17-2025 07:24 AM
I’ve factory reset my chromecast.. should wait to check ?
03-17-2025 07:37 AM
Any updates on a fix if you did a factory reset?
03-17-2025 08:18 AM
Unfortunately I did the reset ‘cause I thought that will solve the problem.
For now, I’m waiting the solution for us…
03-17-2025 08:21 AM
For me the issue was resolved after I changed the date on my phone to 7 March.
03-17-2025 08:34 AM
Lamentablemente, yo lo reinicié y aún sigue sin funcionar.
03-17-2025 08:48 AM
Please provide a solution for those of us who reset the product to factory mode. It's tiring to wait for the message to know when my product will be functional.
03-17-2025 09:15 AM
hi, my chromecast is bricked because of your bug. Since Saturday March 8th it has a fixed orange LED and the screen is completely black and it doesn't even appear to be connected to wifi. How will I receive the update???
You ruined a chromecast that was fully functional before your bug. I hold you completely responsible! I want compensation or solve the problem for me!!!!!
03-17-2025 09:31 AM
I do not understand how you google, can rollout something that is not properly tested and then we are waiting for a solution and not able to use the
chromecast! You should have rolled back the latest update until the FW were ok to be rolled!
03-17-2025 09:46 AM
Dear team,
I have a friend that might’ve rebooted their device during the troubleshooting process. When will the fix for that mistake be available, or if it is already, how does he debug the connection issue? Thanks!
03-17-2025 10:04 AM
Thank you
03-17-2025 10:20 AM
Please any news for the troubleshooting process for the factory reset
03-17-2025 10:39 AM
Mi dispositivo sigue sin funcionar... cuándo puedo tener disponible una solución? Gracias
03-17-2025 10:50 AM
POUVEZ VOUS ME DIRE QUAND LE PROBLEME SERA REGLER SUITE A LA REINITIALISATION DE MON CHROMECAST 2
03-17-2025 11:07 AM - edited 03-17-2025 11:08 AM
Apliqué reset de fábrica a mi chromecast 2a generation, me pueden enviar las instrucciones para actualizar el firmware por favor
03-17-2025 11:35 AM
Pour régler le problème de chromecast
La tablette ou le téléphone que vous utilisez avec Google home régler la date au 1er mars 2025
Ensuite réinitialiser la chromecast.
La logiquement elle devrait se reconnecter et vous devriez poursuivre l'installation.
Elle va faire une mise à jour bien la laisser faire
Une fois la mise à jour effectuée la chromecast refonctionne
Retourner dans les paramètres de votre téléphone ou de votre tablette et remettre la date actuelle
03-17-2025 11:40 AM
Great! After a reboot, my CC Audio updated the firmware, and now it's working again!
03-17-2025 11:50 AM
Hola. Lo había llevado a fábrica pero probé cambiando la fecha del movil a 5 de marzo, con Home fui a instalar nuevo dispositivo, reconoció, se actualizó y esta funcionando perfecto. Gracias.
03-17-2025 12:15 PM
Bonsoir,
Avez vous la solution pour les chromcast réinitialiser ?
Je n'arrive tjrs pas à la reconnecter
03-17-2025 12:16 PM
It’s been a week since the issue has started.
Please send me an update and info how to reset my Chrome cast.
03-17-2025 12:45 PM
Exactllyb.More thank a week
03-17-2025 12:41 PM
Metti il telefono con la data manuale ad i primi di marzo prima che scada il certificato, e poi fai aggiornamento, appena inizia aggiornamento puoi rimettere il cellulare ad orario automatico a me ha funzionato
03-17-2025 03:54 PM
Obrigado, pessoal,troquei a data para o dia 06,como foi falado e funcionou 🙏🙏🙏
03-17-2025 12:45 PM
How IS It going? When are we going to be able to use our Chromecast?
03-17-2025 12:48 PM
I do factory reset a week ago... What I do now
03-17-2025 12:54 PM
@GoogleNestTeam wrote:Hi everyone,
Chromecast (2nd gen): Firmware version 1.56.467165Chromecast Audio: Firmware version 1.56.467166
Hi team ! Thanks for the fix. I’m having issues with downloading the update on my chromecast… I unplugged it when I saw it wasn’t working and it wouldn’t appear on the Google home app anymore. And when I tried (like 8 times at least) to add the device, it fails when trying to connect to the internet (I followed the whole help guide). I thought the update would fix that but how could my chromecast update if it’s not connected to the internet nor to my Google Home app ?
