Update 3/20/25
Update 3/17/25:
Update 3/14/25:
Update 3/13/25:
Update 3/11/25:
Hi all,
Thank you.
Thank you for your patience.
03-20-2025 10:49 AM
03-14-2025 11:29 AM
Worked for me, thanks!!
03-14-2025 11:33 AM
What a great suggestion. I receives the message that updates would take very long and quit. But even without updates this trick enabled me to reinstall Home and make my Chromecast work again after a factory reset. Many thanks
03-14-2025 11:45 AM
THANK YOU! THANK YOU! THANK YOU!
It really worked. Yeaaah 🤗🤗
03-14-2025 12:23 PM
Me ha funcionado perfectamente.
Muchas gracias!!!
03-14-2025 12:32 PM
Thanks so much! That worked for me 🙏🏻
03-14-2025 01:04 PM
Thank you!!!!!
03-14-2025 01:28 PM
You absolute star! This worked for me, thank you so much!
03-14-2025 01:47 PM
Thank you. It worked perfectly for me. My life is complete.
03-14-2025 02:31 PM
Grazie,ho fatto così e finalmente il mio Chromecast è tornato a funzionare.
03-14-2025 02:37 PM
You're a genius. I had factory reset my Chromecast II. Followed your instructions to "dummy" the system into thinking it was March 1, got the Chromecast running, it downloaded the security certificate update and now it's working! Google owes you $$
03-14-2025 03:08 PM
This actually just worked for me! Thank you
03-14-2025 03:43 PM
It actually works.
03-14-2025 04:11 PM
Thank you, it helped me 😊🙏🏼 and tonight I shared your text on Facebook groups for Denmark, I think it can help many who have had to reset their caster.
Good Evening to you!
03-16-2025 07:24 AM
Wow, It's work like magic
03-14-2025 03:06 PM
Hi is the problem resolved as I still can't authenticate my Chromecast. I had done Factory reset.
03-14-2025 03:22 PM
Think I've factory reset as
I just keep getting this message
03-14-2025 03:31 PM
Da sind sie nicht der einzige habe genau das selbe Problem
03-14-2025 03:49 PM
Well you are keeping me from wasting my time trying. I was hoping for a fix by now?
03-14-2025 05:16 PM
There is a fix offered by user johnnyzero2
Do this fix
https://www.googlenestcommunity.com/t5/Streaming/Regarding-an-issue-with-Chromecast-2nd-gen-and-Chro
Leave your unit power up on your local Wi-fi network. It takes time for the google server to update the device
03-14-2025 05:11 PM
There is a fix offered by johnnyzero2
Do this fix
Leave your unit power up on your local Wi-fi network. It takes time for the google server to update the device.
03-14-2025 02:38 PM
No sé puede autenticar Chromecast. Estoy al tanto que ya muchos pudieron hacerlo. En cambio yo reinicié mi Chromecast de fábrica. Después, ya TARDE Google aconsejó no reiniciar.
Entonces pregunto los que lo hicimos no vamos a poder autenticar hasta cuando? Y que debemos hacer.
Si nuestro Chromecast no sirve más, que nos digan qué tenemos que hacer.
Muchos veo que mencionan a FIRE TV de Amazon, pues no lo sé con certeza.
Hay otro cómo ROKU TV .
TIENEN QUE DECIR ALGO Y CUÁL GENERACIÓN ES LA QUE IRÍA.
ESPERO RESPUESTA. DESDE YA MUCHAS GRACIAS.
03-14-2025 05:03 PM
03-15-2025 12:55 AM
DEMANDAR
03-14-2025 04:52 AM
Hvor lang tid går der inden gen.2 er oppe og køre igen jeg har haft nulstillet min desværre
03-14-2025 05:03 PM
03-14-2025 04:57 PM
Thank You, an Please Keep Me Updated. Again Thank You
03-14-2025 05:00 PM
Changing the date on my tablet to before the problem and re-installing my Chromecast Audio ( I performed a factory reset), fixed the problem. After fixing change the date back. Happy listening!
03-14-2025 05:38 AM
Please fix the chromecast as soon as possible, all my chromecast devices are not working yet.
03-14-2025 05:06 PM
Read the status updates pinned at the top of this page. Google started rolling out a firmware update fix yesterday.
If you've done a factory reset on any of your Chromecasts, you need to do this fix to allow them to receive the update:
03-14-2025 05:05 PM
As part of the recommended troubleshooting I am guessing I am not alone when I ‘reset’ the device - so now what? Will this be fixed? And when? This is very frustrating.
03-14-2025 05:08 PM
03-14-2025 05:10 PM
Ya va hacer una semana,que no anda y cuando dejo de funcionar no avisaron hasta mucho después ,una vergüenza
03-14-2025 05:28 PM
I am sorry this response is in English.
Do this fix
03-14-2025 05:12 PM
My son gave me his chromecast as he didn't need it anymore so he is getting the updates regarding the authentication issues and I'm not. How can I get the updates as my chromecast isn't working.
03-14-2025 05:15 PM - edited 03-14-2025 05:20 PM
Did you perform a factory reset on yours? If so, then you'll need to do this procedure to allow it to receive the update:
03-14-2025 05:19 PM
I performed a factory reset, but, i take my phone and change the date to 6 of march of 2025 and enter the app google home. I tried to configure the chromecast and I got it, becouse the app use my local date for configuration. You can make a specific application to give a fictitious date to the chromecast when configuring it.
03-14-2025 05:25 PM
I am sorry this response is in English, leave your unit on with your Wi-fi on, the google server will download the appropriate certificate, so your casting will work for all of your commercial apps.
03-14-2025 05:20 PM
Buenas noches por qué medio informan para aquellos que restauraron de fabrica ?
03-14-2025 05:24 PM
03-14-2025 05:23 PM
hola lamentablemente resetie el dispositivo, que debo hacer ahora?
