GoogleNestTeam
Community Manager (Admin)
Update 3/20/25
Update 3/17/25:
Update 3/14/25:
Update 3/13/25:
Update 3/11/25:
Hi all,
Thank you.
Thank you for your patience.
GoogleNestTeam
16,155 REPLIES 16,155
Vishal5
I have already done factory reset following your troubleshooting suggestions and now it's not connecting to wifi. Please provide the fix asap and update us. Thanks
Marana
Wanneer is dit eindelijk op gelost ?
Wij betalen wel voor bepaalde diensten maar kunnen er niets kijken ,wat voor ons een schade is.
Hoop op een heel snelle oplossing die geen dagen of weken nog gaan duren
Groeten
Anita21
Flipante que deje de funcionar y así lleva días sin solución. Voy a exigir la devolución integra del producto porque esto me parece demasiado.
dale2306
Mine's working!  Just for those who reset to factory like I did I set the date on my tablet to manual and made it the 1st of March.  Then I could get into it with the Home app and connect it to the network.  And it updated and I have it back.  Go ahead and try it.
Mimipuco
We've been experiencing this issue for a week now and haven't received any response. Initially, no one mentioned that we shouldn't restart the device, so we did it. Unfortunately, the problem persists.
It's quite frustrating to be in this situation for so long without any clear solution or update. Could you please provide us with some assistance as soon as possible?
Thank you.
ALinNYC
same here-goojjle S--ks
Duds3966
Hi.
I have done the factory reset and made sure in app permissions are on.
Still no luck ,
Christopherprem
I am not sure it’s not working from couple of days even after multiple reset and Sutup it’s not working properly can you try to fix it at the earliest
Anonymous
Not applicable
I had reset the chromecast to factory settings. Google Home could no longer find the chromecast. I set my phone to March 8. Then added the chromecast again with Home. The chromecast automatically updated. After the update everything works properly again : ) Set the phone back to the current date
Thank You. How do I set my Android Samsung galaxy phone date back? Senior here....not tech savy
Thanks for your help. If I set my phone current date again, is it work stope again?
Gen 3 was fixed yesterday
Robin23
Since yesterday my chromecast, I believe 4th generation, suddenly did not connect to my internet. After factory reset and several tries it connected but on Google Home it keeps trying signing in to chromescast to my google account.
We have another one in the bedroom but 2nd generation and it cannot connect to internet.
Karbar63
Why is it taking so long to get these issues fixed. I can't help but wonder if Googles new tv streamer ($99!) am seeing Google promoting has anything to do with 1,000 of us who owns a Chromecast device and never had any problems with still can't stream . It's been around a week now that mine stopped working and the only message I see states that they are working on it. So how many of you that are waiting have decided to just go out and buy a new device? If I do go buy a new device it sure won't be anything Google! Google, you're a big disappointment! 🥴
ceebeetree
For two days my Chromecast gen 3 has decided it no longer can be found. Getting to recognise it in the google home app on my iPad but cannot connect to it. It has been working just fine all this time, nothing has changed, but I just cannot connect. I have followed the help instructions several times, rebooted, reloaded, reset, but still no luck. Any suggestions? Thanks.
Anonymous
Not applicable
manojberia79
Has the casing issue resolved for Chromecast 2nd generation??
parimiti
finally got updates and device started.
Duds3966
Not sure what you mean
LezliLeston
I tried to reset and now it doesn’t connect at all I would like more Information on an update when there is one please I use this daily and too poor to replace for a newer option
Linesh
Ok. Let us know
Eliz0fraser
Mine is working again. Thank you for getting it up and going again.
Anonymous
Not applicable
 Hello, I'm trying to reconnect my LG wk7 google home speaker, (I should point out that 5 minutes ago, I did a factory reset of the LG speaker). When I launch google home, it recognizes the LG speaker, then the sound is heard in the speaker, then the wifi connection is established, then the speaker lights turn off while the configuration process in google home is not finished, it is at the stage of choosing services, youtube..., then at the time of finalization, there is an error message that tells me that the finalization has failed.
souvik89
Thank you Google for resolving the fix. From today 15 Mar 25 my Chromecast device started working. However I haven't done the factory reset.
Deirdre1
Did factory setting got code to match still can’t find tv from iPad what now
Pat_
Everything back to work here. 4 Audios have been updated. Now checking for the other two that haven't been online for a longer time.
Btw, whenever you decide to to reintroduce the Chromecast Audio, I'm sure demand will be high.
Youel
I have already done factory reset my Chromecast
Javicorton
¡Funciona! Cambias la fecha a un día anterior (yo he puesto día 5) actualiza en Google home el chromecast, luego IMPORTANTE volver a poner el día actual y ya funciona. ¡Muchas gracias!
Lukabri_2
Eu não consigo conectar o Chromecast no meu celular
manishk006
When will we get the update as I performed factory reset.... Ideally, factory reset should not face this issue, but it broke the product and no update from google last from 3days...
Hello my chromecast is now working!
Try changing the date of your phone into March 1, 2025 then set up the chromecast in your google home app like you normally do. After you set it up change it back to the right date and time.
Hope this helps 🙂
TamTy22
So today is the 15 march have you fixed the problem yet especially after thousands of us did a factory reset come on !
manishk006
No, Problem is not fixed and hope G team will provide the solution if user like me performed factory reset
SamanthaCamisin
Our chromecast is now working, thanks google!
Did you perform factory reset earlier?
Anonymous
Not applicable
Fix it please, i cannot watch television without the chromecast……
VissJo
Mooi optijd, fabrieksinstellingen sinds woensdagavond hersteld.. Maar goed, het zal wel weer opgelost worden.
Anonymous
Not applicable
Ik had de chromecast gereset naar fabrieksinstellingen. Google Home vond de chromecast niet meer.
Heb mijn telefoon naar 8 maart gezet. Vervolgens met Home de chromecast weer toegevoegd. De chromecast ging daardoor automatisch updaten. Na de update werkt alles weer naar behoren : )
Telefoon weer teruggezet naar de huidige datum
Arma11
Io ho eseguito il ripristino informazioni di fabbrica e non funziona ancora vi prego di aiutarmi  a risolvere il problema
Hierocles
Ciao Arma11, io pure avevo resettato, ma ieri sera ho seguito le info su questo form: dissocia Chromecast, setta il cell al 7 marzo, ricollega Chromecast, non vedrai nulla, ma riporta il cell alla data odierna, e vedrai che si collega.
