GoogleNestTeam
Community Manager (Admin)
Update 3/20/25
Update 3/17/25:
Update 3/14/25:
Update 3/13/25:
Update 3/11/25:
Hi all,
Thank you.
Thank you for your patience.
GoogleNestTeam
16,146 REPLIES 16,146
SrinivasT
Can anyone publish here, if you get fix for the problem?
espavi
Yo os tengo delante y os pego 4 guantazos bien dados. Hace dias que la cagasteis pero bien cagada y seguimos sin poder usar NUESTRO producto. Si sois unos incompetentes, no culpeis a los que probamos a resetear el dispositivo de fabrica porque es lo más NORMAL hacerlo. Haced las cosas bien de una vez y dejad de excusaros con tonterias o devolved el dinero a TODOS los que no podemos usar nuestro Chromecast, que para algo lo compramos.
Laura19
Buongiorno, purtroppo ho ripristinato le impostazioni di fabbrica. Cosa faccio ora?
non disperare, l'ho fatto anche io allora sposta la data del telefono indietro manualmente al 10 marzo. Poi riapri home fai aggiungi dispositivo e vedrai che con pazienza ritorna tutto a posto e segui passo passo l'aggiornamento e le istruzioni che ti dà ciao
Lous31
J'ai rétabli les paramètres d'usine.
Merci de me donner les instructions.
Alsie
I removed the device and now cannot connect to WiFi. I didn't know about the problem  - now I do, my device isn't connected to WiFi so how can it get an update?
Kalleho
Every thing is now ok. I made reset on my Chromecast before I new about this problem. I set my phone to earlier date 03.03.2025 and made contact with Chromecast and could make set up as normal and after that brought back phone date as normal. I let tv and cc stay on and after about 4 hours the update were installed.
Anonymous
Not applicable
I had reset the chromecast to factory settings. Google Home could no longer find the chromecast. I set my phone to March 8. Then added the chromecast again with Home. The chromecast automatically updated. After the update everything works properly again : ) Set the phone back to the current date
pvivp123
I am able to cast it today in my TV.  Thx for fixing it urgently. It was a great relief for many of our friends who bought Google Chromecast 8-10yrs ago. Other we would have to buy 99£ Google TV set up box.
Ouaha
Bjr
Merci de m informer du correctif par email #
k_kirilov
I made a factory reset of the device (ChromeCast 2nd gen), please send me an instruction how to update the certificate and setup the device - #
Sameerel
Hey guys, it's been so many days, when is the fix rolling out? I factory reset my device.  This is frustrating..please provide a quick patch.
mapiboom
I did a factory reset as suggested by many troubleshooting support pages. I hope you are able to provide a fix asap for customers who did a factory reset.
Fehmida
A week later and still no resolution from google. Was promised a call back from google, not holding my breath.
Smoothius
I made a factory reset, because this is normally the first solution the support team is asking for. And I didn’t know, the problem is Google itself.
So right now I have a useless device, because adding to the wifi network isn’t possible anymore and so I can’t finish the installation process and upgrade the firmware. Please offer the solution.
L71
Setting an earlier date on my iPhone helped me with the factory reset issue.
johnnygiovannie
What if I have followed your guide and recent my audio chrome?
TamTy22
Thank you for all your hard work back up n working 🙏 🤲
Anonymous
Not applicable
Chromecast updated but I can't cast? In googlehome it is showing with same picture on phone as tv but saying offline and won't allow me screen share either. Any advice?
Radhakrishna
Solved: if you have already done factory reset.
I was able to update latest firmware by changing mobile date time prior to Mar 9 and tried to setup again using Home app from mobile. It was able to identify latest update and installed automatically
Thank you I'll try
Carldisa
Unfortunately I reset the devi essere and non it is impossibile anello configuration
I reset the device and I am not alle torri riconvertire it
Sorriy t9 is a nightmare I tried to reconnect the devi essere after the reset without effect except an error message
Jootje69
Probleem oplossen !
* zet de datum op het apparaat waarop je Google-Home-app teruggaat naar 1 maart
*ga vervolgens naar de Google-Home-app
* zoek en verbind je chromecast
* zet datum van je apparaat terug naar huidige datum
PROBLEEM OPGELOST.
jw1985
Fixed mine this morning after following the reset steps posted by others here. Set my phone to 4th March and then added again in Home app.
Kapa
There is a solution!!
When I set up the Chromecast device from another mobile device or tablet and changed the date back to March 9th, the Chromecast restarted successfully and updated correctly. After returning to the actual date, everything is  working perfectly.
LSJ2025
But you came up with the warning not to reset to factory settings first the day after the expiry of the certificates - how do you assist those of us, who intentionally made the reset in an attempt to correct the problem?
lillis73
Set your mobile date to 1 march, start the Google Home app and add it ti your wifi again. Then it should get the new update.
trob1
I tried this, it brought me further along (i actually got to the point where it gave me the code and things were looking good), but just at the last point, it still will not connect to chromecast...
Heven
Bonjour j’ai réinitialiser mon appareil en usine pouvez-vous m’aider merci
