GoogleNestTeam
Community Manager (Admin)
Update 3/20/25
Update 3/17/25:
Update 3/14/25:
Update 3/13/25:
Update 3/11/25:
Hi all,
Thank you.
Thank you for your patience.
GoogleNestTeam
16,159 REPLIES 16,159
Cateluna
It dosen't work...
Cambia la fecha de tu android al 9 de marzo y desactiva la fecha autamtica
entra a Home y comenzará la actualización automáticamente después de 10 minutos lo podrás utilizar
Lee12
I already blady reset the Chromecast, what now!!!?
Lee12
What did you guys do!!!!!???
Olivia2019
entra a Home y comenzara la actualizacion automaticamente despues de 10 minutos lo podras utilizar
Anonymous
Not applicable
So how can we setup again if we factory reset..... please
AliArgh
Ok I've revisited this forum today after finding the notification in spam.  Before I'd come to the forum I'd already tried a hard reset that did not re authenticate. I've since removed the Chromecast from my TV will reinstall in a few days and hopefully can access updates when they're available.
Please advise when they're available.
Ulf
Since my Chromecast started to work yesterday and it was connected to the TV, it seems the updates are in process of being sent out. So, I suggest you connect and power-on your Chromecast.
Same i can't even add mine back ( I get to last step & it acts like it's working, but then fails due to incorrect wifi password-WHICH IS ACCURATE & NOT WRONG ). I know it's bc of these issues & bc I factory reset both Chromecasts, but it's very frustrating bc I tried the workaround (changing phone date manually, it let me get to the last step on both, but then fails). If they don't find a fix for those of us in this situation, after a week of not being able to use, I'll be buying something else. I'll never buy a Google product again after this experience, unless they A.) Replace my Chromecasts at no charge, or B.) Compensate me from too many hours lost & time wasted. Which I'm sure GOOGLE will not do either of these. I'm very disappointed overall with how Google has handled all of this. Its 2025 not 1995.
fml848919
so, when are you planning to fix the problem if people have reset the chromecast 2???
Tried so many times on both & it fails
Mohammad83
The solution for those who reset their device Reset your phone date to March 1st Go to Google Home, set up your device, and reconnect it to the Wi-Fi network. It will update and return to work I tried it and it worked
Anonymous
Not applicable
I do all of this but the final step connected to wifi and a problem appear : Chromecast is maybe configured but impossible to comunicate with him from your iPhone.... so boring !!!
Alsie
Set date on phone to 8th March 25 and went through Home add device.
After many attempts it connected and I was able to connect to WiFi. It was very much trial and error - it now seems to work 🙏🏼
Good luck
myatnoe2637
can't access my account
Forget the password and recovery email.
Thank you
Kriszta_77
När tror nu att problemet är löst? Jag har en svart cromecast som inte vill koppla sig till mitt wifi. Kommer den fungera igen eller behöver man köpa en ny cromecast? Vore bra att veta känner jag.
¿När tror nu att problemet är löst? Tiene un cromecast negro que no tendrá conexión a wifi. ¿Kommer den fungera igen o behöver man köpa en ny cromecast? Vore bra att veta känner jag.
Ulf
Min Chromecast hoppade igång igår (fredag) kväll utan att jag gjort något själv. Den satt kvar i TVn med ström på, och jag har INTE gjort någon fabriks-reset. Tydligen är det något som skickas ut (eller hämtas ner) som gör att det hoppar igång.
silviferr9
A correção do Chrome Cast funcionou perfeitamente!!!   Obrigada pessoal!!!
Majozan
Lo restablecí y no funciona
Nessnaylor
I already factory reset my device recently trying to resolve this issue. Please help and advise
You need change an date in your phone in 1 march and after connecting your phone to u device
myatnoe2637
I can't access my account
myatnoe#
Thank you
myatnoe2637
facebook account gmail recevory no phonenumber no passwerd recevory
Facebook recevory
Gigliolamazzon
Purtroppo il dispositivo è stato ripristinato!!! come posso procedere??
ePambos
If your device is connected to the Internet, it will auto-resolve the issue with the next automatic firmware update. Google has heard its users and rolled a firmware update that fixes the problem!
Thank you Google, you did the right thing.
Chromecasts are still great devices and they are well worth at least another decade of lease of life. Keep up the support to the devices, they are not obsolete!
sergiomarkesini
Spero riusciate a risolvere presto. Sono immobilizzato a letto e la tv è il mio unico svago.
Dkarman
We use chromecast  in our business  and had too buy a substitute . When I went too the store they told me it was because  you stopped making chromecast  products.  Now I got a firestick cost me 100$ and 2 days latter google sends a notice that they have issues  with chromecast. Bad support  . You guys cost me 100$ for nothing I'm really  pissed I hope a law suit is started.
Yoyuki
il aurait peut-être judicieux de nous informer plus tôt ,de ne pas reparamétré. moi je l'ai réinitialisé au début de la panne et maintenant plus rein, toujours le même problème. authentification impossible.  Il serrait bien de trouver une solution .
Merci
Celly
Any news about restoration of Chromecast 2nd generation?
