GoogleNestTeam
Community Manager (Admin)
Update 3/20/25
Update 3/17/25:
Update 3/14/25:
Update 3/13/25:
Update 3/11/25:
Hi all,
Thank you.
Thank you for your patience.
GoogleNestTeam
16,147 REPLIES 16,147
Marieeee
Genial entonces. Estoy a la espera de una solución. Ya que restaure de fábrica varias veces y hasta lo borré de la app home.
Mi dispositivo es un chromecast 2da g
***** If you performed a factory reset during your initial troubleshooting, you'll need to do this..
https://www.googlenestcommunity.com/t5/Streaming/Regarding-an-issue-with-Chromecast-2nd-gen-and-Chro
Sgyt312
I have already factory reset in this device.now ?
Pavelardi
I downloaded the latest update of Google Home and was able to reconnect my ChromecastAudio to my network. I had reset my device to factory settings but it still connected.
I asssume you're referring to the iOS (iPhone) version of Home, since that looks like it was just updated today.
Is that correct?
Kayzaalencar123
G7V2
Davallec
Sigue sin funcionar...
johnnyzero2
(possible) NewsFlash:
A few users have reported here that Google has supposedly released a new version of the Home app (currently for iPhone only?) that addresses the "factory reset" catch-22 hellscape that so many are experiencing. I can see that there is a new version on the Apple App Store from today 3/16, but I'm an Android guy so I can't confirm that it actually fixes this issue (and the changelog isn't specific about which bugs it addresses). If true, this will be a much simpler solution than the well-known "date" workaround, especially for non-technical users. The solution would be as simple as updating to the latest version of the Home app and then using it to re-setup your Chromecast.
I'd like to hear from other iPhone users here if this is indeed the fix that so many people have been waiting for. Please report results here.
Of course, if all of this is true, I assume they'll also be releasing an Android version soon.
I did factory reset my ChromecastAudio device (iOS). I downloaded the latest Home update and was able to connect to my Wi-Fi.
JohnOPKS
It has been a week, can you provide a fix for the factory reset condition? Thank you.
*** If you performed a factory reset during your initial troubleshooting, you'll need to do this....
JoyceLopes
Assim que ocorreu o erro, redefini o aparelho pois imaginei que era algum erro de conexão!! 😭😭
Resolve isso Google, por favor.
Diegof
Yo restableci la configuración de fabrica ahora como procedo?
Gracias
***** If you performed a factory reset during your initial troubleshooting, you'll need to do this....
Ble2
Please resolve
--->>> If you performed a factory reset during your initial troubleshooting, you'll need to do this..
Koolbeansssbro
What about those of us who have some that we’ve already factory reset and others that we havent
Jvcnd
I'm sure this is all made up to make ppl buy new devices. This is taking sooooo long.. it doesn't makes sense that a company like Google doesn't have resources to solve this right alway.
Smells fishy af...
If you can stop being cynical long enough to do this, it will fix your Chromecast:   🙂
Sc64
Someone on this thread posted these instructions. I tried them and the first time it didn’t work. It updated but didn’t connect. I forgot to change the date back to automatic. Once I did that it’s working great. Amazing the “pros” at google can’t find the solution! Thanks to the person that shared the solution!!!!
Eduardo1516
No me deja conectar a internet mi tele Hisense
Raypitts14
What if you did a factory reset not knowing that you where not supposed to?
Wkaruza
Hola sigue sin funcionar
>>> If you performed a factory reset during your initial troubleshooting, you'll need to do this.....
Jorjane40
Já faz dias que estou sem ver televisão por conta disso quando será resolvido???
-> If you performed a factory reset during your initial troubleshooting, you'll need to do this..
Menezes10
Eu acabei redefinindo de fábrica e não conseguia nem conectar na rede pra atualizar. Troquei a data do meu celular para o dia 06 de março e depois disso consegui reconhecer e atualizar o Chromecast.
Deu certo!
Kde
For some reason my phone (iphone 16 pro) wouldn’t connect the chrome cast to the TV so I tried the IPad, and it worked. So if you are having the same issue try that- Bit stupid!
Radwan_25
Any updates?
robercc14
Hola, ya reestableci el dispositivo a la configuración de fábrica, agradezco la ayuda para configurarlo nuevamente
Natty2611
No me deja autentificar el Chrome hace días como puedo solucionarlo
