GoogleNestTeam
Community Manager (Admin)
Update 3/20/25
Update 3/17/25:
Update 3/14/25:
Update 3/13/25:
Update 3/11/25:
Hi all,
Thank you.
Thank you for your patience.
GoogleNestTeam
16,122 REPLIES 16,122
Tereza1
It's been a week now and still not fixed. How much this is gonna take? Not normal...
Emma6T
Set the date on your phone to before 7th March and set up your device(s). Then you can change the date back and everything should be back. It's a pain but it works.
TwoSpaces
For those who have also made a reset of their device: I can confirm what others have said. This approach works: Set the time of your phone to 05 January (for example), connect with Google Home to your Chromecast device. After some time this will initiate the download of the update. After that you may reset your phone to the current time and everything will work as before.
worked for me. Thanks
Dont work for all devices Chromecast Audio!
Sarina85
Avevo ripristinato i dati di fabbrica ancora non accedo è normale? Non mi fa configurare
Creuze
Bjr,
N'ayant pas eu d'informations à ce sujet bien évidement j'ai fait un reset de la chromcast. Quand vas telle refonctionner ?
Merxinde votre retour
Eric. Crz
Realiza lo siguiente: pone la fecha en tu teléfono celular con la fecha 04 de marzo y luego realiza la configuración del dispositivo Chromecast normalmente. Suerte!!!
Quando mudo a data fica dando erro no app home
Akyraaqq
Quando vai voltar a funcionar ??
Ka3pod
Fix in this way if you did a factoring reset. Change date of the mobile pone. I set 3 march. In this way you can perform the search of the chromecast. After this you n
Can see the xrome cast on google.home but still not working then.  Then set bach the date on the mobile on automatic. It shoud then work. At least for me it worked with this procedure. Good luck.
Pip_pill
Error 4045 not working from iPhone. Although can see device in list
Dachi1
Google Nest Mini estuvo conectado a una red wifi que ya no tenemos en casa, y a hora tenemos una nueva red wifi y Google nest mini sigue conectado a la vieja red wifi estoy buscando la forma de cómo arreglarlo, pero no me deja por ningún lado
KarinB60
When do I get instructions for a restart? I did make a factory reset on my Google Chromecast 2nd generation, unfortunately, a week ago. I still can't stream.
Mario15
Siguen sin funcionar los 3 dispositivos que tengo
GoogleNestTeam
Still doesn't work.
Denneh
Oops, read a bit too fast, didn't see the update will take a few days, my bad yall.
Denneh
Actually nevermind, the thing still persist, doesn't work whatsoever.
David67
Same here, doesn’t work, same problem, can’t connect with iphone
Still not working with a factory resetted chromecast, updated app on the version noted.
  1. Nadat u de Google Home-functie op 8 maart hebt geïnstalleerd, is dit een probleem.
  2. Als u Google Home gebruikt, kunt u de normale Chromecast configureren.
  3. Wanneer u de firmware-actualisatie van Chromecast toepast, kunt u deze opnieuw bekijken om de cambio-apps opnieuw te gebruiken.
  4. Eens dit kan gebeuren, kunt u de feitelijke gegevens op uw apparaat met Google Home bekijken.
  5. Johan België
Hola, me sigue sin funcionar y tengo la versión de 3.30. me dice que no hay comunicación. Por fa, vengo hace más de una semana con este inconveniente
The rollout for Pakistan completed or not ???
I have the updated app and it’s still not connecting to my phone after factory resetting. Any further advice? I removed the device from Google home app when it wasn’t working when I reset it in a hope this would work. Now I can not add the device back.
J1103
  5. Johan België
please try this process, hope it helps.
"I did factory reset. So, I changed date on my phone to March 7 (or earlier, as read from other's recommendations) and reconnected for updating. When you reconnected, the system will perform updating.
Once the updating process is finished, change date on your phone to auto date.  Then follow the normal casting process."
TWY
For goodness sake JitSujittra - IT WORKED!! You are a Genius! Many Thanks 😁
Google play has no update yet for home app not happy with all this no tv for two weeks!
J1103
  5. Meerdere hebben dit uitgevoerd al. Allen geholpen ondertussen
  6. Johan België
Fiz como um usuário falou e deu super certo. É só colocar a data no celular dia 05/03/2025 e seguir com a instalação.  Espero que ajude
Sojo1
hmm no updates I to did the normal reset upon release the bug issue I'm now heartbroken if it never works again why so many bugs an time to corect
So the solution of going back in time and setting the date to March 8th worked, the Chromecast reconnected and updated.
I think Google engineers don't want to implement a temporary solution like this.
Pois então a solução de voltar no tempo e colocar a data para 8 de março funcionou, o chromecast reconectou e atualizou.
Acho que os engenheiros do Google não querem implementar uma solução provisoria como esta.
Para solucionar el problema si Reiniciaste de Fábrica tu Chromecast la solución es:
  1. cambiar la fecha del dispositivo donde tienes instalado el Google Home a una fecha anterior al 8 de marzo, que fue cuando sucedió este problema.
  2. Abre Google Home y comienza a configurar el Chromecast normalmente.
  3. Cuando lo reconozca se aplicará la actualización del firmware del Chromecast y reiniciará para aplicar cambios.
  4. Una vez hecho esto puedes volver a poner la fecha actual en tu dispositivo con Google Home.
Espero que les sirva! A mi y a muchas personas más les sirvió.
To fix the problem if you factory reset your Chromecast, the solution is:
  1. Change the date on the device where you installed Google Home to a date prior to March 8th, which is when this problem occurred.
  2. Open Google Home and begin setting up the Chromecast normally.
  3. Once it recognizes it, the Chromecast firmware update will be applied and it will reboot to apply the changes.
  4. Once this is done, you can reset the current date on your Google Home device.
I hope this helps! It helped me and many others.
Klopt volledig
Sigo sin poder conectarme a mi chromecast !! Más de 1 semana sin poder conectarme
The new version maybe isn't compatible with my phone? When I download it it is 3.30.1. 5, not 1.6 - what gives? Android version 11.
I checked & the app update for Google home isn't available for me yet 😢
