GoogleNestTeam
Community Manager (Admin)
Update 3/20/25
Update 3/17/25:
Update 3/14/25:
Update 3/13/25:
Update 3/11/25:
Hi all,
Thank you.
Thank you for your patience.
GoogleNestTeam
16,131 REPLIES 16,131
Pra mim já deu certo desde 14/03 obrigado Google
Consegui, gente!!!!🔥❤️
Great news! It's resolved now and has been working for me as of today. Thanks team😀
//Chinna, Sweden, 22nd March 2025
Sultanjan
Olá estou com problema no meu Chromecast 1, do nada parou de funcionar. Foi no inicio do mês, a luz acende, mas não fica mais branca ao apertar o botão, somente fica piscando.
O que devo fazer?
Aguardo retorno
Álvaro Dalmiglio
# ou #
Desde ja agradeço
Jjjjhhvhujhhhh
yes, um dure everythimgv
thanssss
531b05400245ebb8
Perfecto
Network error
Cómo puedo saber si está funcionando bien ?
It still doesn't work. Google Home sees the Chromecast but it doesn't authenticate it
I don't own a Chromecast (2nd generation )Nor do I own a Chromecast audio. My Google accounts are HACKED !!!!
I had performed the factory reset on my device when the initial problem occurred. I have the updated google home version above (3.30.1.6 for android), but I am still unable to connect. I get all the way to the last stage, and it says there is a problem connecting to my chromecast. please advise what to do next.
No me funciona 😞
Bi
<top>
បងប្អូននៅបាតដំបង​ ជូយប្រព័ន្ឌនិងកូនរបស់ខ្ញំុផង។
Chromecast built-in is not cast mirror in Google home
Thank you, thank you, thank you. I factory reset my Chromecast just before the announcement and thought I would never be able to use it again, even though it powers up. I begrudge getting rid of something that technically still works, so I'm very happy that you've helped all affected by this, instead of making us buy new stuff and adding to landfill. Big hugs to you all xxx
again, this 'fix' has not improved my situation - it still says my chromecast cannot connect. what now?
I was able to set up my Chromecast Audio after a factory reset. It took several tries but I have it set up and I can cast music to it. However, the device does not show up in the Google Home app. What can I do to fix this? I already tried setting it up from scratch but the issue didn't go away.
Otra vez volvió a fallar, espero que a la tercera vez ya nos van a mandar uno de última generación o no?
in summary i have an ONKYO TX-RZ730 amp with a "chromcast built in" still showing FW 1.36
NOT FW 1.56 like the other 2x now working stand alone chromcasts (thankyou for fixing)
this meens i am still with out an option of how to play audio (cast audio) in my livingroom
after a long chat with yousrselves it looks like the man will have to fix (but this amp is old and onkyo will not)
i would not be against buyin a new chrome cast audio but you do not sell them any ideas?
hello I did the trick to change date to previous 8 march  as many users on both my chromecast, it was working but now since yesterday it doesn't work anymore (picture image chromecast blinking), please tell what should be done
Yo, Solution to change date previous to 8 march, doesn't work anymore longer since yesterday ... Does someone found a new solution ?
WillIV
They released a fix already for it. If you haven't been able to fix through the home app call their customer service.
I am still having problems after reconnecting my chromecast. it connected once and then it stopped working
Hi guys,
I have a Chromecast 2nd generation. I did factory reset and I still cannot connect. I go through all steps and when the Chromecast tries to connect to the WI-FI network I get the message "Connection problem during setup. Could not communicate with your Chromecast."  Any ideas why that might be?
it is impossible to  reach out to customer support for further assistance. how you do that ?
hey Google if you think that blocking old chromecast, will make me buying a new one, you are making a big mistake
emmzone22
It's not working on my new Google TV Streamer either.
hey guys what about a class action against google !!!!!!!
Jr8uup
Was apart of one with a company that's software for landlords to check renters wrongly put millions of people on the deadbeat list. We won and got $20.
to put you in a court !
In France and the EU, planned obsolescence has been prohibited and punishable since the Hamon Law (2015) and the AGEC Law (2020). Since Google has voluntarily discontinued support or made Chromecasts unusable without a valid technical justification, this is considered a form of planned obsolescence. Violation of consumer rights: Consumers have the right to use a product under normal conditions for a reasonable period of time. If a device is rendered obsolete for arbitrary reasons, this could be considered an infringement of their rights. The discontinuation of services has been demonstrated to be a business strategy. Lack of transparency: If Google has not clearly informed users of the discontinuation of support or the consequences for the affected devices, this constitutes a breach of its duty to inform.
Buenas tardes....
Ya han pasado 8 días desde q aseguraron q el 20 marzo, llegaría a todos los usuarios/clientes del chromecast de 2°generación, la actual del dispositivo q permite resolver este problema global, pero yo, q estoy en Guayaquil, Ecuador,  no llega a la play store, la famosa actualización.  Me pregunto  y segurament, muchos más se harán la pregunta:¿ cuando llega la bendita actuación q nos permita utilizar un dispositivo por el q pagamos y confiamos?....
I am at my wit's end.
In early March, it seems like there was some kind of bug that affected Chromecasts gen 2 globally. They were pretty much bricked for 10 days or so... Google "fixed" the issue, and since then I have lost the ability to cast media to any chromecast or speaker in my house. I have restarted each device, I have reset the modem/router, I have updated the app. When I try to factory reset a speaker, it says it was 'set up correctly' but can't connect to wifi.
I can use voice commands to play media, but given the abysmal performance of the Google Assistant, this is like shooting a gun with a blind fold on hoping to have the correct song/show/etc play on the correct device.  Once something is playing, I can control the volume in the devices overview panel, but if I click on that device it claims nothing is playing and I can't connect to it.
So basically, every media player in my house is 75%-90% brick status.
I have emailed the support address that is listed in the Google Play store for the Home App (I received an email saying that Google doesn't monitor that address.... the address listed as a support address in their own store... for their own app), I've been sending feedback from the app daily - and received no response, I have mentioned these issues in a 1 star review and was given a generic support FAQ for the EU (?)...
At some point, I have to just give up and dispose of all of this hardware, which, as a consequence will mean removing my house from all things google. Email, Workspace, Youtube, Android... Why would I continue to use products that can fail catastrophically without so much as a peep from the company.
My device decided that was not going to work today, same issue as several weeks ago, not sure what to do at this point
