Update 3/20/25
Update 3/17/25:
Update 3/14/25:
Update 3/13/25:
Update 3/11/25:
Hi all,
Thank you.
Thank you for your patience.
03-20-2025 10:49 AM
04-12-2025 04:02 PM
Contacted support directly there is still an issue with pixel devices connecting to these devices. I had to use a non pixel device and it worked. In case this helps someone else.
04-13-2025 04:54 AM
I have a Pixel 8 Pro and other devices, and nothing can connect to my Google TV Streamer. My Pixel and other devices can connect to my Chromecast with Google TV and Nest displays just fine. It's only the Google TV Streamer I'm having issues with.
04-14-2025 02:45 AM
Hello - my issue has still not been resolved. My Google Home app is updated. I have performed a factory re-set on the device and re-set up my Chromecast app but when I then try to cast from any streaming app, it says no devices are found.
04-17-2025 09:58 AM
After the problem resolution, my chromecast audio work fine.
From today i have the problem again
04-18-2025 06:38 AM
My 2 Chromecast still doesn't work, so are Google gonna compensate us? It seems like they really don't care about the problem. And want us to buy some new ones
04-18-2025 07:48 AM
If you update your Google Home App. It does work. After several attempts at it I noticed I had more than one home listed in app. I deleted every one and rebooted my Chromecast, it then updated also and I created a new home in the app. Works perfectly
04-18-2025 10:20 AM
Thank you for the answer mate. Just found out it's a problem with my Samsung Galaxy s25 ultra and my Samsung tablet. Anybody else experienced problems adding devices with Samsung products?
I actually had the same issue with a Roborock vacuum cleaner, couldn't connect both the vacuum and my chromecast when I tried to use my Samsung products, but when I got a friend by using there android devices it worked 🙄
04-18-2025 04:01 PM
So today I have issues again. I have a Chromecast Audio device that I have named Tuner to correspond with the name on my multiroom audio controller input button. I have several "automations" that will stream a radio station on "Tuner" than turn on my multiroom audio controller and set it to the Tuner input. If walk up to one of my Google Home devices and tell it to play "automation" it works fine. If I try to run an automation in the Google Home app on my tablet it turns on the multiroom controller but then gives me an error that it can't find "Tuner" even though I can go into devices on that same tablet and bring it up and look at the device info fine. Except for the short time we were all offline due to the security issue these automations have been working fine. Nothing has changed except today the Automations can't find the device. Oh and my phone is telling me that "Some settings are only available when my phone and the device are on the same network." This has been an ongoing issue that moves through all of my devices. I only have one network in my home. I really wish that Google would get these things figured out. It's not good when you are expecting an automation to work and it doesn't.
04-19-2025 02:13 PM
I am just appalled at how bad Google support is for their devices and related services. Zero support! They just decided that community forums are the best way to support their customers. In the end, nothing has worked out. I guess I will sell them to any of them.
04-19-2025 03:12 PM
I agree. I'm starting to replace my Google devices with Amazon Alexa a little at a time.
04-20-2025 12:35 PM
Hi folks, here we are again? Sony bravia Just bought to solve my chromecast 2 certificate update... Same story, no connection and magically changing date connection status ok but not effettive? Same ol story?
04-23-2025 04:44 PM
Boa noite, esse transmitir Chromecast não funciona no meu G8, ele trava meu jogo. Por favor como devo fazer para desinstalar do meu aparelho, meu aparelho não tem memória suficiente. Por favor me ajude.
04-25-2025 10:20 AM
I cannot get my 2nd generation Chromecast authenticated for some reason, my Google Home app is up to date (3.32.69.2).
I performed a factory reset of the Chromecast because I hadn't used it in years and my Wi-Fi has changed etcetera.
When I open the Google Home app on my Google Pixel 6a it tells me that the Chromecast needs to be activated before setup. It tells me that I need to install the Device Utility app, but I cannot install that app on my phone because the Android version is too new.
When I install the Device Utility app on an older phone, that then tells me that it cannot be authenticated and I need to visit the support which is then sending me in circles.
Might it be because my Chromecast wasn't close to being up to date that I'm having these issues still?
04-25-2025 10:32 AM
prueba cmabiando la fecha del dispositivo (pixel 6 o el que sea) a una fecha anterior al de febrero de 2025
04-25-2025 01:49 PM
I set the date on both phones before february 2025 and I could get the Chromecast connected to the Wi-Fi. I still cannot set it up in Google Home, but at least I can cast now!
Thank you for the tip!
04-25-2025 08:17 PM
Yes
04-26-2025 08:22 AM
update the date of your phones now and hope you could set it up in Google Home
04-25-2025 05:53 PM
My 3rd generation Chromecast quit casting. I have tried all of the troubleshooting you suggest. Will there be a fix for this?
04-25-2025 08:16 PM
Yes please
04-29-2025 07:35 AM
So is this happening again? I can't see both of my Chromecast Audio devices today.
05-12-2025 05:54 AM
Bkash PIn lok
05-26-2025 04:19 PM
Jag hade ej återställt min ena chromecast och den fungerade i 20 min sen la den också av och detta var i slutet av mars/april. Ni ljög. Nu har jag 2 som ej fungerar och hur ska det gå att uppdatera dem så de fungerar?
06-08-2025 05:08 AM
Jeroen
06-11-2025 02:25 PM
sii
07-09-2025 11:13 AM
មានរឿងចង់សួរតិកបានអត់
07-11-2025 06:18 AM
Is there another global blockage now in july? My chromecast is suuddenly not working again.
07-29-2025 05:37 AM
super
07-31-2025 01:56 PM
Again having a problem casting from YouTube from both the phone and iPad . It isn’t working properly
08-04-2025 02:34 AM
Thank you to the Google Nest Team for staying transparent and proactive throughout this issue. I experienced the exact problem with my Chromecast Audio after a factory reset, and it was frustrating not being able to complete the setup. I'm glad to hear that the update (v3.30.1.6 on Android) has now rolled out for most users — updating the Google Home app did the trick for me.
For anyone still having trouble after a reset, I’d definitely recommend checking the firmware version first and then rebooting to trigger the update. Also, small tip: after re-setting up my device, I took some time to customize my Chromecast backdrop and display — it’s fun to personalize it with visuals like My Melody and Kuromi Wallpaper, which bring a nice aesthetic to the idle screen.
Appreciate the support and detailed updates from the team. Everything is now back up and running smoothly on my end!
10-08-2025 05:40 AM
The World's Best Tool Site
10-05-2025 09:45 AM
Mi chromecast cambia la hora y me dice que no está en la misma red de mi teléfono, antes jamás hubo problemas pero desde hace una semana es horrible no funciona ni por nada que puedo hacer? Aparte de reiniciarlo de barricac encender y apagar y esas cosas casuales
10-08-2025 05:38 AM
10-08-2025 05:36 AM
https://www.saltandroe.com/blog/why-are-boundaries-important-in-your-personal-life
https://www.saltandroe.com/how-to-open-a-restaurant
https://www.saltandroe.com/blog/restaurant-location-strategy
https://www.saltandroe.com/blog/how-to-write-a-business-plan-for-a-restaurant
https://www.saltandroe.com/blog/hospitality-industry-challenges-tips
https://www.saltandroe.com/blog/what-is-the-purpose-of-a-pitch-deck
https://www.saltandroe.com/blog/restaurant-business-pain-points
https://www.saltandroe.com/blog/how-to-start-a-food-business-with-no-money
https://www.saltandroe.com/blog/healthy-boundaries-at-work-hospitality
https://www.saltandroe.com/group-coaching-hospitality-leadership-program
https://www.saltandroe.com/blog/restaurant-content-strategy
10-08-2025 05:38 AM
10-15-2025 12:40 PM - edited 10-15-2025 12:41 PM
Updated my Google Home app to 3.30.1.6 — finally got my Chromecast 2nd gen working again.
Had factory reset earlier, so setup was stuck for days.
Glad they fixed it, but took way too long honestly.
In the meantime, I was playing from https://getnullsbrawl.org/ to kill time.
10-27-2025 02:54 PM - edited 10-27-2025 02:57 PM
My second Gen Chromecast(s) have picture degradation recently, a major loss of pixels and picture quality after a few minutes of operation. I have tried different Chromecasts. TV's and locations in my house. It even happens located 3 feet from my 5G router. I have tried multiple factory resets. Once the picture goes bad it won't comeback without changing channels on You tube TV and most of the time that doesn't help. I've unplugged appliances to rule out interference from my house. Any Ideas or anyone else having this problem? I have newer TV''s and Streamers, but I'd like to continue using Chromecast for a couple of not smart TVs. (I have 30 years previous experience as a Cable TV tech supervisor, so I'd like to solve this with your assistance)! Thanks!
a month ago
Google no longer supports these devices officially — but with the right tools, they can still function reliably.
🔗 Learn more at likesbee.com
a month ago
4 weeks ago
Layanan Halo BCA-WhatsApp:Halo BCA bebas:pulsa 24 Jam. Halo BCA bebas/pulsa 24 Jam (+62, 815/4094/7055.) Layanan:Nasabah Bebas.pulsa 24 Jam.
4 weeks ago
