GoogleNestTeam
Community Manager (Admin)
Update 3/20/25
Update 3/17/25:
Update 3/14/25:
Update 3/13/25:
Update 3/11/25:
Hi all,
Thank you.
Thank you for your patience.
GoogleNestTeam
16,155 REPLIES 16,155
我也是遇到一樣的問題
WuSi
我也是一樣的問題
相同的問題,不知道是不二代已經停售的關係。不過應該不會這樣,因為舊的andriod系統雖然我無能更新,但還是可以運作。google 應該也沒必要比,把這個商機讓給其他電視棒品牌。
CC116
我的昨晚打開電視後也是突然連不上wifi,如您敘述的一模一樣操作,google home也無法重新設定,一代chromcast 不能用了嗎?
Same here, so sad.
使用中文的各位,相信你們應該也爬文到其他篇文章,似乎是原廠當時出產產品時就在程式裡面埋下了個定時炸彈,我不認為他們會/敢讓舊產品就再也不能用,會被吉死吧,不過確定的是我們重製的這些人後續復原工作會更麻煩.......
Samgo
Me, too.
It has happened since yesterday.
我也一樣的問題,無法驗證,但我另外一個一代的Chromecast,還可以正常運作!
目前已知集中在第二代沒錯,但無論如何就算都遇到了也先不要還原原廠設定
我也遇到了這個問題了,完全無法投影
I did more or less the same as what u did (tried 2 Chromecast, can found them) & eventually stuck at the same step as u...
Yes, facing exact same issue since yesterday
johnbutcheracad
Msg "We couldn't authenticate your Chromecast."!!!! Tried all suggestions and didn't work.
Google, what had you done?? Thousands of people complaining here.
I lost at least two hours of my Sunday trying to fix it!
Firmware?? What's the problem and how to fix it??
I came here to say the same, it worked this afternoon then nothing tonight. Tried all the fixes, thought it was because my chromecast is old, but see the newer ones failing too.
Very similar here. Noticed that is a large issue with maybe, millions affected. That Google work hard and fast to solve.
Is it resolved? How? I'm still struggling
Anonymous
Not applicable
No this seems to be on going I've just tried it again on my Chromecast and saying cannot authenticate this is after a reset as it failed yesterday evening
Same here still not working
I am also struggling here. Still not working.
Zaar
Same here. Is it fixed?
Desde ayer domingo no puedo tampoco autenticarlo y el mio tb es antiguo..no se que generación es pero estuvo funcionando perfectamente el sábado..  y ahora quien nos va ayudar?? Ni siquiera se conunican cuando pones la acción de que te llamen...
Estoy en la misma que vos no me  , funcionaba lo reinicie y ahora no me deja hacer la  autenticación hace más de 3 hs que estoy con esto
Hola Flor, pelo jeito é um problema grande e que está afetando milhões. Que a Google resolva rápido (desculpe, falo português, inglês e francês, mas não espanhol ;), un abrazo.
Hj 10/03/25 Brasil. Estou com o mesmo problema. Manda instalar o app, porém não dá continuidade
É isso mesmo, o problema está ocorrendo com muitos, em vários países, pelo que notei. E tentei receber ligação do suporte da Google, mas tbm não funcionou. Muito ruim.
Same here Monday 03:17am.
Been trying everything, using other Android and iPad and resetting Chromecast. Thought suddenly the old model (black disc) was no longer working, burr see others with the same issue. Next time I won't waste an hour and come here now I've found this community.
Thanks for your post.
Jo98
Same
Same here.
I got the exact same problem. Is there a fix yet ?
Same problem. Wtf!
Same issue, also with 2nd gen chromecast.
Same here. Don't know what is happening.  "HEY GOOGLE" we need answers.
Please and thank you
Help me chromcast it how I watch tv
Same problem here 10/3/25
Same problem here 10/03/25. India
Hi mine stop working yesterday also did you manage to resolve it ,if you did how please
Sine last night, was thrown off Chromecast and not been able to reconnect. I've unistalled HOME app, I've factory reset chromecast...tried everything and about 16 hours later still get this message " not able to authenticationyour chromecast"
Was hoping to waken to it being fixed but alas still not working
