GoogleNestTeam
Community Manager (Admin)
Update 3/20/25
Update 3/17/25:
Update 3/14/25:
Update 3/13/25:
Update 3/11/25:
Hi all,
Thank you.
Thank you for your patience.
GoogleNestTeam
16,145 REPLIES 16,145
Oivindjensen
Please fix this.
Mancio82
When you'll fix it, please provide also instructions for whom that made factory reset.
Thank you
Stigers
Set date on mobile to before 9/3 and you will be able to reset.
Si riesco a collegarlo ma non funziona lo stesso per la trasmissione sulla tv
TotiBaradero
Deberíamos haber tenido conocimiento que ante una contingencia de estas con los dispositivos Crhomecast NO DEBIAMOS REESTABLECERLOS DE FABRICA , En mi caso tengo 3 de los cuales uno , el mas antiguo, dejo de funcionar y lo que hice ante la impotencia que sentí fue restaurarlo de fabrica , supongo que ahora le tocara a los de segunda y tercera generación. Se van a hacer cargo de mis dispositivos ? les sugiero que lo menos que podría hacer Google si fue esa Vtra intención , seria que entregando nuestros viejos dispositivos nos recambien por uno nuevo a mitad de su costo. Son demasiados costosos en mi País. Google siempre colaboramos contigo , por eso existes, pues bien , ahora veremos cual es tu limite.
First and third generation ought not be impacted. According to online sources it’s a ssl certificate that ran out after 10 year (since coding I assume) and whereas the first generation supposedly have a 20 year and I am guessing the third generation has not reached 10 years yet.
Anonymous
Not applicable
“don’t factory reset” - This is a joke, right? That’s what troubleshooting says to do.
Hater_chromecas
When will you fix it?
It was Google that said we had to reset our devices. Bow you are saying do not reset your device.....
I guess next time I will go for another product, this is just silly. I have bought a product and within two years the company that sold me the product blocks me from using it.....
Having now experienced the Amazon Firestick as an alternative, I realize just how good the Chromecast is. The Firestick is much more complicated and long-winded compared to the CC.
Spog00
Deadbod
One chromecast work my other doesn't I factory reset doh! What else was I supposed to do I can see the coloured digits just let me add it to the Google home app arghhh
just set your phones date before the 9th allows you to re-add, will have to wait for a forced update for whatever certificate issues they are having to use the device again though.
How do i do that
Thanks Chris for the solution
Spostando la data si riaggancia al telefono ma non ti permette comunque di trasmettere in tv i programmi
Yalls
Try changing the mobile date manually to the 8th. It may allow you to connect to WiFi again. Probably won’t fix the original problem though, but it will likely need internet connection to get a fix from Google
Anonymous
Not applicable
Please start producing this again.  It was quite frankly one of your best products
Mic2412
Has any update been given yet and to when Chromecast will be up and running again as I can not see any in the feeds
Space_grapes
Do not reset to factory settings... well that advise comes a bit late :-S
You can undo the reset. Manually set your phone date to March 6th. Then you can setup chromecast again
but is still useless
BREANT
très honnêtement essayez d'activer plus vite , on n'en peut plus d'attendre
donner nous une solution SVP
PrashantN85
Do you have any ETR ? When this will be fixed ? Are there any workaround ?
If you google I have found a possible android workaround on androidauthority com.
Unfortunately I'm currently an iOS user lol
Mwetzel394
mine seem to be working now , thank you
was going to order some WIIM's tonight
i was just getting my old tv google dongle to see if it worked
sorry i was wrong cc in my workshop must be newer
BarLeDuk
I’m experiencing the same problem. Plz fix asap!
J2TheD
I already did a factory reset.. now what???
Jkxs_y
It looks like a problem affecting many. When can we expect a fix for this ?
try it now mine are all back online
sorry i was wrong must be a new Cc down here , the gen 2's still not up yet
Mine still aren’t working
Diana5
I had problems streaming from my phone to my TV through Chromcast,  so I reset my Chromcast,  removed and now I want to add the device again. I opened the app and Chromcast has been found.  When is trying to connect,  I'm getting the message that Chromcast can't be authenticated. Please help 🙏,  I don't know what I have to do more?
Thanks , Diana Schroeder
Yalls
Try changing the date on your phone manually to the 8th and you may be allowed to reconnect to WiFi. It won’t fix the trust issue error but according to Reddit users it should fix the chromecast  to before it was reset (it will most likely need connection to WiFi to get the fix when it eventually is there)
La_Cicchy
Buonasera, ormai ho ripristinato i dati di fabbrica, non sapendo le ho provate tutte per farlo funzionare. Alla fine ho chiamato l'assistenza e ho saputo di questo problema. Sono rimasta molto male per come siamo stati lasciati tutti in questa sgradevole situazione!
valegc
From Argentina. Of course the first thing you do is to factory reset the device! Y’all have to fix this right away.
Cyphyxx
Now im told not to reset it . Wtf i already did everything
Olby10
Bye Bye Google. I've just sold my Nest and I've all my enterteinment migrated to Apple.
Steve2009
Same problem here
