Update 3/20/25
Update 3/17/25:
Update 3/14/25:
Update 3/13/25:
Update 3/11/25:
Hi all,
Thank you.
Thank you for your patience.
03-20-2025 10:49 AM
03-12-2025 06:02 PM
Is there any option to be updated automatically when the issue is solved?
03-12-2025 06:02 PM
Days and days of this nonsense just because you didn't renew the **bleep** certificate!? When will this be fixed??? At what point should I throw my Chromecast in the garbage and buy a competitor? Can we get some freaking clarity and an answer on where the fix is? Answer us!!!
03-12-2025 06:05 PM
Still not loading it my TV chromecast
03-12-2025 06:04 PM
son unos comerciantes engreídos Debería darle vergüenza Manga de chorros
03-12-2025 06:07 PM
Já restaurei... E agora não consigo configurar.
03-12-2025 06:08 PM
I have several Chromecast and I'm begging to regret buying a Google Nest... perhaps I should have bought an Alexa...
03-12-2025 06:09 PM
Buying a Roku.
03-12-2025 06:09 PM
Quando irão resolver? Aparece o código na tv mas no home não tem como confirmar...
03-12-2025 06:09 PM
How long do we have to wait?
03-12-2025 06:11 PM
Precisamos de respostas objetivas e não apenas bla bla bla barato ,porque não resolvem logo esse problema pra podermos voltar a usar dispositivo Chrome cast .
03-12-2025 06:15 PM
This is why you guys should have hired me when I put in my job application and sent me resume I would have resolved this issue by now.. smh
03-12-2025 06:15 PM
I did a factory reset, and as said I experimented issues where I was unable to re-setup the device. The way I could re-setup my Chromecast was configurating manually my phone's date on march 8th (a previous date to the certificate expiration and failure). That way I was able to connect my Chromecast to the WiFi again. After that I returned the date setting to automatic. Hope it helps someone.
03-12-2025 06:16 PM
Quando será a solução? Continuamos pagando os streams e não temos acesso.
03-12-2025 06:16 PM
It’s so hard to fix the issue? Come on, seems like you’re not a serious company
03-12-2025 06:17 PM
ANY NEWS ON THE SOLUTION ON THIS FOR THOSE DID THE FACTORY RESET ?
03-12-2025 06:20 PM
We alllllll reset our devices as we were told to do so in troubleshooting. Looking forward to knowing what the fix will be for us on that. Thanks team!
03-12-2025 06:18 PM
I had done a factory reset as one lot of instructions told me to do this , nothing seems to work and my phone recognises the chrome cast but not the internet , I have tried 2 different phones to connect the tv and chrome cast in the bedroom and says the same thing , cannot make an internet connection. So frustrating
03-12-2025 06:20 PM
Still waiting for the fix for following your trouble shooting guide and doing a factory reset.
03-12-2025 06:22 PM
I'm in Brazil with the same problem. IT WAS NOT POSSIBLE TO AUTHENTICATE CHROMECAS. Absurd, you know, in a little while they'll sell a solution.
03-12-2025 06:21 PM
Vamos quando?! Dias sem funcionar!
03-12-2025 06:23 PM
I have two second gen Chromecast and both have been factory reset. I need to know how to get them working again.
03-12-2025 06:23 PM
Favor corrigir logo essa falha , q fez restaurações de fábrica favor no informe como instalar novamente
03-12-2025 06:24 PM
Please fix it as soon as possible I don't know why you don't make a newer version
03-12-2025 06:25 PM
Still waiting...
03-12-2025 06:25 PM
Do not factory reset… of course its the first thing we all did. Please patch this its been several days, this looks aweful for google trying to twist our arm into buying newer products, will go for Apple
03-12-2025 06:25 PM
I used this feature about a week ago. I don't understand I miss my chromecast 😞 thank you for info. I'd prefer a text bc there was no notification for this, message
03-12-2025 06:26 PM
03-12-2025 06:26 PM
I have the issue of connecting with chromcast to tv
03-12-2025 06:30 PM
Your apology means nothing, give us a time frame, when will it be fixed and will you reimburse us for lost time and money
03-12-2025 06:32 PM
Hello, i already reset my device. So hope you can solve the issue, and will wait for instructions.
Thanks
03-12-2025 06:37 PM
Still no fix?! Did you delete the software or something? Haha
03-12-2025 06:41 PM
If this can't be fixed soon, everyone might have to switch to the Amazon Fire Stick 🤔
03-12-2025 06:41 PM
Any news regarding factory reset?
03-12-2025 06:41 PM
hey, I factory reset before getting notification from Google. In addition, the email from Google said NOTHING about not resetting.
Is Google going to replace my device?
03-12-2025 06:42 PM
When?
03-12-2025 06:43 PM
Let me know when this issue is resolved. I have one Chromecast with a factory reset and the other without, and neither of them works.
03-12-2025 06:46 PM
Ahh crap I factory reset both of them... it says too. As long as there is a fix I'm cool.
03-12-2025 06:46 PM
Cioè ragazzi sono passati tre giorni 72 ore e non avete ancora risolto!!!
03-12-2025 06:49 PM
Hello, I have reset factory my device, because I thougth doing that, the chromecast should work again, so I appreciate that you could give any solution
03-12-2025 06:49 PM
Has to be the worst experience I’ve had with customer service. They closed the support chat so I transferred though another department. Twice I was chatting with a representative and twice they abruptly closed the chat before I could reply. Basically said sucks to be you watch for a fix . It is ridiculous that a company that sold it self around customer support and service will not even offer an avenue to ask questions regarding there faulty products and garbage support
