GoogleNestTeam
Community Manager (Admin)
Update 3/20/25
Update 3/17/25:
Update 3/14/25:
Update 3/13/25:
Update 3/11/25:
Hi all,
Thank you.
Thank you for your patience.
GoogleNestTeam
16,155 REPLIES 16,155
Laureano56
Laureano56
Não consigo configurar meu Chromecast diz problema no áudio nos Chromecast 2 geracao
Que merda ser pobre
If you have done a factory reset, then on your phone ( or whatever you connect yo you chromcast with) change the date back to before the problem. I used the 9th March.
Set up the chromecast on goggle home.
Chromecast will then connect and update.
Wait for chromecast to then update and then you can use as normal.
Don't forget to cahenge date again on your phone
Can not casting to tv  what can I do
L E I V I
For those who have factory reset: Change the date of the phone/device you are casting from to March 6th and you will be able to connect to Chrome cast. After connecting you will receive the update and it will work.
Maintenant a quand la correction des googles n'est hub ( écran )
Qui n énonce plus les notifications ( tâches )
Ya esta la solución a los chromecast reiniciados?
Solucionado. La nueva actualización desconfiguró el audio. Lo resolví configurando el audio en la tv. Todo sin problemas.
El mío sí,  desde ayer. Y lo había reiniciado varias veces 😐
Cuando se solucionara el problema con las personas que reiniciaron el chromecast de fábrica y aún no podemos configurarlo
El mío ya funciona desde ayer, y lo había reiniciado varias veces. Creo que progresivamente funcionarán todos. Suerte!!!
I just updated the Google Home app to the newest version that was suggested today and I still can't connect?
I'm having the same issue... read through all the help screens etc but the Google Home app does not see this Chromecast or an older Nexus TV devices on the same Wifi network etc.
939
Great news! It's resolved now and has been working for me as of today.
//Chinna, Sweden, 22nd March 2025
Eu assisti
Anonymous
Not applicable
Bueno, a esperar...
AGA3
Czekam. Będę sprawdzać na bieżąco informacje
Alejandro71
hola, tengo dos dispositivos, dejaron de funcionar ayer y los restablecí a fábrica....fue el procedimiento que vi para resolver fallas de conexión...desde ya muchas gracias.
Estoy en tu misma situación, veremos que habrá que hacer para los dispositivos reseteados.
Hay otro post a bajo en ingles, pero te lo pongo igualmente.
Como workaround temporal puedes cambiar la fecha de tu telefono a antes del 9 de marzo (el 8 por ejemplo) y luego configurar el Chromecast.
Lo hice y funciono: El chromecast ya esta de nuevo conectado a la wifi, pero obviamente sigue sin poderse hacer cast de nada.
Muchas gracias por tu tiempo y ayuda! Lo hare y te comento!
no perca su tiempo, hay que esperar google comprar otro certificado de seguridad
E quanto o horário da rede, não vai afetar a conexão com o chromecast?
Atbinnb
 It really has
Fco1
Sos Crack. Lo pude volver a configurar pero me dice que el firmware del dispositivo está obsoleto cuando quiero conectarlo a YouTube 🤪
no hagas nada, google hizo una tonteria, tiene que esperar que ellos lo resuelvan
CM71
Funcionóóóó gracias lo restablecí, pero no me deja transmitir, espero respuestas . Saludos
Jô
Como o seu funcionou?  O meu não funciona.
nao vai funcionar, a google tem que comprar outro certificado de segurança, o deles expirou 9 de março de 2025 . só espere a google
no va a funcionar, el certificado de seguridad expiró, ellos tienen que comprar otro. No hagas nada pero informe a sus amigos para que nonpercan su tiempo intentando corrigir
FOO_SAYS
This got my Chromecast back on the WiFi.
Thanks, @J_Clark
What did u do
Jô
Como você fez?  O meu não está funcionando.
Dukecito
It works!!! Now i've restored my Chromecast 2 main screen with time and with Wi-Fi connection at least, so now my device is ready again to wait the next Google Update for my Chromecast 2 to fix the outdated certificate of firmware.
Yj_Clark. You are the boss!!! Thanks for this incredible helpp!!!!
lLion
gracias amigo eres un genio, ahora toca esperar a que lo solucionen
