GoogleNestTeam
Community Manager (Admin)
Update 3/20/25
Update 3/17/25:
Update 3/14/25:
Update 3/13/25:
Update 3/11/25:
Hi all,
Thank you.
Thank you for your patience.
GoogleNestTeam
16,147 REPLIES 16,147
I doubt it's a firmware issue. If that were the case, chromecast audios would not be affected. They haven't had updates for years. A certificate issue is more likely.
Same happend here, both Chromecasts same issues - untrusted firmware. No warning, I did read Google stopped updating service on them somewhere. If this is the case, might consider staying away from all Google service and products.
Same here!!!! All my chromecast audio devices!!! Reset everything but can't add any chromecast audio to google home!
Ho lo stesso problema, si è verificato subito dopo l'aggiornamento dell'app Home
Same here, gen 2, Sweden.
Anonymous
Not applicable
Lo mismo por acá, la palmó...
As the heading states all 5 audio devices, 1 on wifi and 4 hardwired no longer work as of today. Funny how they sent an email about the Home Max Audio loosing features on 3/9/2025 but crickets about the cast audio devices!
حصل مشكلة منذ الصباح لايمكن تسجيل الدخول على شاشة التلفاز كروم كاست يعثر عليها لكن لا يمكنني الدخول
Same issue, tried everything like the others. Getting message :
"We couldn't authenticate your Chromecast. Please visit support.google.com/chromecast for help troubleshooting this issue.x
Model NC2-6A5. I am in Montreal, Quebec, Canada.
Same here, 2 gen 2 chromecast audios, Oakland CA
No deja transmitir que sucede
I have the same problem
Same problem here.
Same here, worked fine for years till 1 hour ago. Both of them. No authentication error, keeps coming back, whatever I do..
El mismo problema desde España.
Chromecast de segunda generación.
Aqui a mesma coisa. Ate ontem, funcionou normal. Ja resetei e atualizei o aplicativo Home e nada
I also have the exact same issues the chromecast just stopped working tried all the obvious things and eventually factory reset but now the device will not authenticate/verifie so im fully stuck  its also version NC2-6A5  eventually i thought it just broke an ill buy a new one but well there all sold out so im hoping this will get fixed soon
Same here (Gen 2 Chromecast), authentication issues no matter which app I try to cast from, and doesn't show up in the Home app. Saw that many have tried factory reset and got locked out, so I haven't dared to try that in case they roll out some update to fix the issue.
Same here (Italy). I have tried everything to make it work again but nothing seems useful. HELP!
Something is happening 🤔  this isn't a coincidence that at about nearly the same time all our chromecast devices shut down and can no longer be found or connected to!!!
I'm in Australia this issue happened between 4.30am and 6.30am
Same here. There's a Reddit thread for today as well where others are reporting the same thing.
Hi, Im from El Salvador, my parents just gave me their old Chrome Cast (i think is gen 2), did a factory reset bc today i tried to stream Twitch and wouldnt connect to the chrome cast, even tho the name was there, but when i click it, it wont do anything. After I reset it, it gave me an error that it couldnt connect to my wifi, even tho before it was connected to the same wifi, u cant set it up anymore, and mu parents just gave a tv with it lol 😞
2nd gen Chromecast offline as well. Better roll out the hot fix ASAP.
Same issue in Germany. But until yet, I couldn't find any solutions.
Anonymous
Not applicable
Same issue, commenting to follow updated results
I am unable to setup my chromecast 2nd generation device. I tried to apply almost all fix suggest, but still getting the same error. Please suggest if you have any fix.
Same problem, I have tried ALL the possibilities
Same problem in Germany, just across the border from the Netherlands.
I have exactly the same issue here. 3 Chromecasts and today i can't stream from any smartphone (Xiaomi Poco X3 and Pixel 7). I tried Netflix and Youtube on both smartphones. Both apps on both phones list the chromecasts, but when i try to connect to them i get different errors:
Using netflix: "[translated from german]: No session could be created on the selected device".
Using youtube: "[translated from german]: Not a trusted device - Chromcast x could not be verified. The device's firmware may be out of date"
The devices are connected to the internet (They load picture Slideshows, show Weather information)
By the way: on this website (unfortunately only for Germany) users can report problems with all kinds of things. For about an hour now, massive problems with GoogleTV have been reported, in 89% of cases in connection with Chromecast devices: https://www.netzwelt.de/ist-down/1060-google-tv.html
=> there seems to be a very general problem with chromecast devices right now
No se pudo autenticar tu Chromecast. Esto me apareció desde hoy 09 de marzo de 2025. Ayer funcionaba Ok. Uso el Chromecast conectado a un TV LG que dejó de ser Smart hace algunos años y recibir la transmisión desde un movil Android. Ninguna solución descrita en los foros funciona porque no hay forma de actualizar desde el TV por su limitación ni tampoco desde la app Home. Gracias por la ayuda de antemano.
I have the same issue in Greece...
I've been trying for at least 30' reset the device again and again and still cannot communicate! Horrible!! It seems that is a worldwide issue,hope they fix it as soon as possible.....
I have been using my Chromecast for years, even upto yesterday I was casting films through it. All of a sudden, today, I tried to cast prime and it wouldn't connect. I went to the Google home app and its not on my app anymore. So I reset the Chromecast, so I could set it up again. I'm not recieving a pop up message saying "can't authenticate your Chromecast please visit (this website) for help troubleshooting this issue". Any ideas on a solution? I have tried resetting everything, phones, WiFi, Chromecast nothing seems to work
Hay algunas app que si pueden transmitir, como una pestaña de chrome y la app de musica Tidal, otro problema extraño es que ya no me muestra mi galería de fotos, sino que muestra fotos de internet.
A mesma coisa esta acontecendo comigo.(Brasil) Meu Chromecast é do modelo antigo tbm. Apareceu essa mensagem dizendo que não é confiável, desinstalei, reinstalei e não voltou a funcionar. Estão de sacanagem! Parece que estão interrompendo o sinal para obrigar a comprar produtos atuais.
I'm having the same issue. It was working perfectly this morning and 4 hours laters I Stuart having issues.
Same issue here in Sweden.
My Chromecast suddenly stopped working tonight. Was fine earlier in the day. I’ve reset my chromecast, updated my phone, updated my apps, made sure my local network access is on, and I still receive this message:
Livingroom tv may be set up, but we could not communicate with it from your iPhone. Make sure that you have enabled local network access in your privacy settings and try again.
Local network access is definitely on. i don’t know how else to solve this issue. My phone used to connect no problem. Chrome cast light is white, both devices on same wifi
Meu Chromecast não funciona mais , consegui usar pela manhã e do nada parou de funcionar
Anonymous
Not applicable
A mí me ha pasado exactamente lo mismo, ayer lo pude ver sin problema y hoy día 9 de Marzo de 2025 me dice que no puedo autenticar mi chromecast y no encuentro la solución por ninguna parte ,espero que alguien me pueda ayudar.
