GoogleNestTeam
Community Manager (Admin)
Update 3/20/25
Update 3/17/25:
Update 3/14/25:
Update 3/13/25:
Update 3/11/25:
Hi all,
Thank you.
Thank you for your patience.
GoogleNestTeam
16,147 REPLIES 16,147
TiagoNk
O meu Chromecast está apresentando o mesmo erro. Não consigo conectar, aparece um erro de autenticação aconteceu agora a tarde.
Plinio
Mesmo problemas:
Não foi possível autenticar o Chromecast.
Acesse support.google.com/chromecast para resolver o problema.
Tengo el mismo problema
Me sumo a la misma problematica, y el soporte no presenta ninguna soñucion a ese error
Hi, our chrome cast, think it’s gen2 was working fine this am, then this eve won’t communicate with iPad, iPhones etc.
the logo is showing on the phone and when clicked gives the option of living room to but nothing happens.
So far we have tried
factory reset on chrome cast
deleting google home app and re loading and going through the steps
turning off wi Fi for several minutes then back on
turning off chrome cast for few mins then back on
trying to reboot all devices, Wi-Fi router, chrome cast then reload everything etc etc
trying the 5 steps on the device help page
still nothing.
It’s worked fine for years, nothing has changed, everything in usual places, same tv, phone, iPad etc
it gets through the process, finds the device, ‘connecting to chrome cast’, passwords on screen is the same, set it to ‘living room’, connecting to Wi-Fi….says ‘connected’ then get the dreaded ‘something went wrong, living room tv may be set up, but we could not communicate with it….’
have tried all the steps on iPhone privacy, local network, restarting phone, Wi-Fi etc, tried to connect direct to chrome cast SSID, enabled local settings etc etc etc, all of those steps several times over…. Still won’t work. The logo will show on say bbc iPlayer but if you click on it nothing happens or we get the ‘check local network settings’ message.
The house wifi is working fine, the same thing happens if we try on my phone, wife’s phone, iPads etc.
pretty much ready to give up on it.
any help anyone or is the chrome cast screwed.
Zarieah
I am having the same issue just today
Same, yasterday i used it fine, but now it doesn't work
JR111
I swear I literally tried everything you did in the exact same order! I'm not sure which Gen I have but this things worked fine for years!
JR111
Okay yea I just checked. I've got a Gen 2 as well. Maybe it's Gen 2 thing??
Salve a tutti, il mio Chromecast che non ricordo se è seconda o terza generazione, non riesce più a connettersi ho provato in tutti modi inizialmente mi dava un errore di firmware non aggiornato ma non riuscivo a far l’aggiornamento… Ho provato a cambiare Connessione di ogni tipo, ma niente quando vado a riconfigurare alla fine, mi dà un errore che mi impossibilità alla riconnessione del dispositivo
Avete idee?
grazie
AndyHA
Confermo
AndyHA
Sembra un problema globale viste le altre decine di post con centinaia di risposte
CarolF
Stesso problema 😭
Issue is fixed. Please keep your TV on after connecting to your Chromcast. Google will push the update and system will automatically update and your Chromcast will start working after few restarts.
Thank you Google!
Stesso problema. Tutti e due i Chromecast hanno smesso di ricevere broadcast da app esterne. La schermata sulla TV li dà online e connessi alla rete (verificato dal router).  L'app Home su Android li vede offline.
Ho provato fare il reset di fabbrica ad uno dei due ma la procedura di setup fallisce o perché non trova il device o per errore di autenticazione.
Ho letto sulle pagine facebook di Made by Google che sconsigliano di fare il reset di fabbrica! E questo è male, perché, siccome è previsto dalla procedura, l'ho fatto ad uno dei due. Spero di non essermelo giocato e in attesa di veder tornare al lavoro il secondo!
Buonasera a tutti.
Da questa sera il mio chromecast non trasmette più dallo smartphone ( Samsung galaxy s10+) restituendo l errore sai da YouTube che Netflix:
"Dispositivo non attendibile. Non è stato possibile verificare la chromecast. Il problema potrebbe essere dovuto a un firmware obsoleto del dispositivo".
Prima di tutto ho verificato ed il firmware è l ultimo rilasciato 1.56.275994.
Poi ho provato a resettare la chromecast e restituisce il seguente errore in fase di configurazione: "impossibile autenticare il dispositivo chromecast".
Premetto che ho chromecast e tutte e due danno lo stesso problema.
Venerdì è stato l ultimo giorno che le ho utilizzate e funzionava tutto correttamente.
Spero possiate aiutarmi.
Grazie
CarolF
È un problema globale, anch'io stesso identico!
Stesso identico problema anche per me
Giova
stesso problema anche io dal 09/03/2025
Stessa cosa, magari qualche aggiornamento ha rotto tutto.
I have had my Chromecast set up for years and was last connected a few hours ago. When I try to reconnect I keep getting the error “TV may be set up, but we could not communicate with it from your iPhone."
I've tried restarting my router, phone, the Chromecast, the Google Home app several times and nothing's worked. I've checked the local network access and the bluetooth settings, all are fine. I've also factory reset my Chromecast and tried connecting through the SSID as suggested in other threads and get the error "Connection failed. Couldn't connect to Chromecast. Make sure local network access is enabled..." even though it's already enabled!
Help!!
Livh
Me too
worldwide issue it seems
alithv
Same i have the exact same problem
MattQ
Google announced the end of Chromecast: https://blog.google/products/google-nest/chromecast-history/
It looks like TLS security certificates on the devices are expiring and not being renewed by Google. Unless Google is willing to update the certificates there will now be 100 million new pieces of eWaste.
They could help us transition it to the OpenSource community and maintain it ourselves but that's up to Google.
Anonymous
Not applicable
Chromecast won't authenticate
please fix it
Scr3am
Same problem
Jayrup
Same problem, glad it's not just me but still not happy
Yes, please fix it
Old cromecast users always being skipped for testing. Fix your stuff google
Same problem. I literally was casting this morning, and couldn't 3 hours later. I tried removing my Chromecast and re-adding it via the Home app. Now, it says I cannot authenticate.
Maybe same problem, two Chromecasts suddenly won't connect to our phones.
I have restarted, rebooted and changed every setting in router and apps.
My Chromecast just stopped working today, It's either a gen 2 or gen 3.  I tried to reconnect it in the Home app (android), as it was set up and showed on my TV, just not registering my wifi.  Nothing worked from the troubleshooting guidelines, so I ended up doing a hard factory reset. I deleted the old setting from the Home app.  Now, my CC won't even get set up.  When I open the Home app I click on "add device" it will find my CC and then want to establish a temporary internet connection.  After that it thinks and thinks and then says  "I cannot communicate with your CC."
nothing has changed with our wifi
*all connections, tests and other devices work perfectly fine. It’s not the wifi or internet
*privacy settings are all good for Google home
I have done all these steps before and after the factory reset:
  1. Make sure your Chromecast is close to the Wi-Fi router. If you have a dual band router, try to set up your device on both the 2.4 GHz and 5 GHz bands.
  2. Make sure Wi-Fi and Bluetooth are both turned ON on your phone or tablet.
  3. Turn OFF mobile/cellular data.
  4. Reboot your router. Most routers just require that you unplug the power source and then plug it back in to reboot.
  5. Reboot Chromecast by removing the power cable, then reconnect it.
  6. Make sure you're using the latest version of the Google Home app, by checking your app store for any updates.
  7. Restart the Google Home app.
Nothing works.  I do not have an older device that supports the Google Home app (I tried) and we only have 1 TV.   Any tips/advice are welcome.
I also tried to connect to the CC's wifi and open the Google Home App and see what happens then, but it still does not work.   Please help me as I've been trying to fix this for 3 hours.
There are quite a few people (including myself) who have the same issue.  Google is aware.  So far, though, no solution to my knowledge.
Is this a thing that just happened today?
Same here. I don't know why. I can't connect anymore. What is the problem???
If you have Android 10 - try the setup from this phone. I tried but can't move past the authentication.
Same ..suddenly from yesterday I m not able to cast...not sure if gen2 support is there or not from Google for chromcast
I've two Chromecast since years perfectly working.
This evening both stop to be available broadcasting from all apps such as YouTube, Amazon prime, Netflix, even the screen transmit of chrome browser didn't work.
I've rebooted them several times, rebooted to router too and so on.
They appears online showing picture browsed by web, datetime and weather temp. Of course they're connected to wifi, I can see from router interface too
If I look for them by Home app on Android smartphone they appear offline nevertheless on the tv screen I see online.
I've tried to fabric reset one but the configuration procedure fails with a "cannot authenticate" error. The device on tv screen shows is code and the one to setup.
No way to get it.
Considering that this happen to both I suspect some issue outside of my power
 estou com o mesmo problema
