GoogleNestTeam
Community Manager (Admin)
Update 3/20/25
Update 3/17/25:
Update 3/14/25:
Update 3/13/25:
Update 3/11/25:
Hi all,
Thank you.
Thank you for your patience.
GoogleNestTeam
16,159 REPLIES 16,159
Juliazedi
I’m in Sweden, Gothenburg. Doesn’t work here.
I just have the standard old chrome cast, like 1st or 2nd gen. Really old. Cant find the info in the app from it, but system firmware version is 275994.
thanks!
RomulusM
the same issue for Chromecast gen2 , from Romania, "we couldn't authenticate your Chromecast...."
Joseire
Happening in Ireland. Cast firmware 1.56.275994. system firmware 275994. Chromecast won't reboot either from the Home app.
Redplum
Re-booted router / chromecast, still unable to authenticate. Based UK. Not sure what version or firmware.
morf
Reset all devices...now I can't connect any chromecast to google home. Model RUX J42.
Rodrigo33
When you reset the device you cannot reconfigure it because it throws an error when trying to do so, which means you are unable to use the Chromecast device at all.
I tried factory reset without success.
MariaIren
Primeiro começou falando que o firmware poderia estar inspirado ou que tinha que atualizar ele e aí eu reiniciei o dispositivo e tá falando que não está conseguindo autenticar ele.
Dispositivo: Chromecast 2ª geração (acredito que seja)
Região: Brasil
Versão do firmware: Não sei
alecdiez
Volver el Chromecast a parámetros de fábrica no soluciona el problema...esto es mucho más grave
pnowis
I have restarted Chromecast by disconnecting power but also restarted to factory default (made it on several devices). None of these actions helps.
I am using Google Chromecast v2:
"build_version":"275994","cast_build_revision":"1.56.275994", "locale":"en-US"
Thanks for the support.
If you need more info please let me know how to grab it for you.
Best Regards
Piotr
NiklasG
After factory reset the device cannot be configured again. It fails on the connecting stage and cannot proceed.
Where can we see updates on how and when this can be fixed?
JirkaS
Hi there, restart does not work😒
Anonymous
Not applicable
My Chromecast also as of today stopped working. Restarted, Re-downloaded, Reset everything. Now it says cannot authenticate. Please fix this on your guys' end. My wife wanna watch white lotus tonight. Thanks
This is impacting a bunch of people around the world. Do you have any new information to share?
Fltadm
I am having the same problem, mine is a second generation but I can't find the firmware. I am in Alberta Canada.
On the plus side others from around the world are having the same problem, so it's not a Canada pissed off Trump problem
EduCava
Tentei reiniciar e agora não reconhece a nova configuração
Virak
Bonjour. Il m’est arrivé la même chose chez. Mes 3 Chromecast V2 ne veulent plus rien streamer…
Par contre les chromecast V3 continuent à fonctionner… mais pour combien de temps???
Je pense que Google a banni les Chromecast V2, comme ce fut le cas pour les V1 auparavant…
JE VAIS COMMENCER À BOYCOTTER LES PRODUITS GOOGLE
Goofygdog
Hi Jill
Would it be possible to post a link to where we can see updates re progress on fixing this issue?
Kind regards
Reneaude
Déjà fait rien ne marche, c'est la galère !!! Idem même problème que des centaines de personnes !!!
Anonymous
Not applicable
Eso no funciona ya se intentó y nada
Anonymous
Not applicable
Google Chromecast 2 FHD HDMI Streaming Media Madrid España
Aklindh
Any update on when this will be fixed?
It's the first thing users do when it doesn't work, users all over the world are having issues
FrancisCN
I'm having the same issue here in Brazil.
It was working few hours ago and now no more. After the factory reset it can't authenticate in the Google home app again.
My device is the Chromecast 2nd gen.
Brazil
pgugougg
I've done all that. Nothing helped !
EvaH
Hi Jill, I had the same issue today, factory reset did not help
Dani12
Provato e riprovato e continua a dire che è impossibile autenticare .
Carlosgap
Same here, reseting doesn't work, nothing works
Lu6
Estou usando a segunda geração sou do Brasil Brasília DF e parou de funcionar e não atualiza mesmo fazendo tudo que foi falado pra fazer
Menebrio
Second gen ChromeCast in Euro region.
I was using it normally today; made a pause on my watching, Turning off the TV and when I tried to re cast hours later, I got the Authentication error. The device remained on my Wifi as it was going through the images, but home app showed it as offline (Orange router app showed the Chromecast was still connected and active).
I tried unplugging for 5 minutes (which still went into my wifi but no casting function), factory reset, deleting it from Home app, recreating Home profile, resetting my Wifi + renewed IP.
But it is still unable to authenticate.
wrkbuttes
Any solution yet? Appears a worldwide authentication problem.
BrandiI
I am also having this issue in British Columbia. It was working fine but just stopped. I don't know our model but I think it may be a 2
What's not getting authenticated is the home app. The device itself is working perfectly fine. It gets reseted, it goes to the setup process smoothly, it generates the pairing code and then Home app says it couldn't authenticate!!! 😡🤬 I tried several times already. Also following the hack of connecting directly to the device. It's really annoying!!!!
In the morning working perfectly and in the evening clashing. Could you rollback wathever change you may have released!!! It's really upsetting...
Hidekimmm
I'm with the same issue and factory reset didn't help at all. It's not working
Raut002
I'm in New Zealand and have Gen 2 Chromecast, same error.
g00gl3
How many times?
jaa313
system firmware: 275994
cast firmware 1.56.275994
netherlands
Chromecast gen2 in Argentina.
Sanavio
We did it already... I tried to reset both of my devices, I've even uninstalled my Google Home app... nothing is fixing this problem. This seems to be global, I'm from São Paulo, Brasil.
LeleAcu
Tengo el mismo inconveniente al igual que todos los usuarios que se encuentran manifestando esto en dicho espacio. Hace 2 hs funcionaba perfectamente, de un momento al otro se desconecto y no se pudo transmitir más. Me encuentro en Argentina, Ciudad autónoma de Buenos Aires.
Técnicamente se que es un modelo 2015
