Update 3/20/25
Update 3/17/25:
Update 3/14/25:
Update 3/13/25:
Update 3/11/25:
Hi all,
Thank you.
Thank you for your patience.
03-20-2025 10:49 AM
03-13-2025 04:19 AM
I was without information for days despite using Chromecast Audio daily still, of course I did a factory reset... any way to make it work with iPhone / iPad / mac? I didn't get an email from you either about it...
03-13-2025 04:23 AM
Io ho fatto reset e comunque non funze ora?
03-13-2025 04:25 AM
ETA for this problem is?
03-13-2025 04:23 AM
03-13-2025 04:23 AM
I already re-set,but still not fiexed...
Please help ASAP @@ Thank you !
03-13-2025 04:26 AM
Io ne 2 ma solo 1 funziona
03-13-2025 04:27 AM
THIS IS ENOUGH NOW GOOGLE!
03-13-2025 04:26 AM
Olá, já tem 10 dias sem poder usar o aparelho, porque tanta demora? Isso é normal?
03-13-2025 04:28 AM
Isso é um absurdo está demora, inaceitável!!!
03-13-2025 04:32 AM
the only thing that frustrated me after my chromecast bricked is my ancient 2012 samsung tv would not connect to my router even after a factory reset lol. all my other tv's work in the house but this one was in the bedroom. i ended up switching to an old 1st gen chromecast and it still works. i love google products. everyone responding to this with a complaint or saying google is trash can gfy. thanks for the updates and letting everyone know you are aware of the situation and actively working to fix it!
03-13-2025 04:31 AM
Buenos días:
Ya lo he puesto de fábrica. ¿Que hago ahora?
Maria Rosa
03-13-2025 04:33 AM
I have done a factory reset well several of them so what do I do now?
03-13-2025 04:32 AM
知らずに、だいぶ前はリセットしたら直ったので出荷時設定にリセットをしてしまっています。
直ることをまっています。
03-13-2025 04:35 AM
Now, I'm using Amazon Fire TV Stick (Since Google doesn't care about your customers)... 💔
03-13-2025 04:37 AM
Do you have any estimated date to resume the conection on chromecast 2gr?
03-13-2025 04:37 AM
Why is that so difficult? I assume that pretty much all users have carried out a factory reset. This means that the device has its own WLAN, which is recognised by the Home app. It should be possible to install a new certificate via this connection.
I can also connect my Chromecast to my Wi-Fi if I reset the system time on my mobile phone. So Chromecast should be able to obtain a certificate.
Thousands of people can't listen to music right now. In my house I use Chromecast in all rooms, I find that really annoying right now. Please solve this problem, thanks 🙂
03-13-2025 04:41 AM
Ok, so I will purchase a new device for streaming today.
This has gone on long enough. Will bring google this device to their doorstep.
A claim would be in place for our money back.
03-13-2025 04:41 AM
I only got this message on one device. Not the other 2 connected that I was using. So I did factory reset as recommended on the support site.
03-13-2025 04:40 AM
What should I do next after I have factory reset the Chromecast? I can't setup the Chromecast in Google home now.
03-13-2025 04:42 AM
There's a workaround I've tried, which works, but it requires you to bypass the device authentication.
Does this not open up the possibility that your chromecast could become compromised?
If so, then does this also have the potential for a whole network of compromised chromecast devices, if everyone applies this workaround?
BTW I have now reverted the Bypass Device Auth setting to 'No'.
03-13-2025 04:44 AM
For a non nerd this is undoable right?
03-13-2025 04:53 AM
Do you have any advice how to do it? What's necessary to use?
03-13-2025 04:43 AM
Date your phone back to 8th march
03-13-2025 04:45 AM
Tried that - but it breaks a load of other apps.
03-15-2025 10:25 AM
Here it is fixed and all works again.
03-13-2025 04:46 AM
Filhos da puta é o que vcs são!!! Lixo de empresa, nunca mais compro nada de vcs...
03-13-2025 04:46 AM - edited 03-13-2025 04:50 AM
I think I factory reset my Chromecast Audio (by holding power button). What should I do now?
03-13-2025 04:49 AM
03-13-2025 04:51 AM
Ich habe bereits den Chromecast auf Werkseinstellung zurück gesetzt, was nun?
03-13-2025 04:56 AM
Hola buenos días por desgracia fue lo primero que hice restablecerlo de fábrica
03-13-2025 04:55 AM
Not register
03-13-2025 04:57 AM
Found this gem. It allows me to mirror/cast to a single Audio device although it still shows offline, but no groups. I don't use for video.
https://www.reddit.com/r/Chromecast/s/HW64HMGKoT
03-13-2025 04:58 AM
Ho resettato! Come ci aggiornerete? Arriverà un’e-mail?
03-13-2025 05:01 AM
any news!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
03-13-2025 05:01 AM
Too late! Troubleshooter has already performed a reset! Needs to be restored somehow.
03-13-2025 05:03 AM
Could you please provide steps after factory reset I can't able to connect my device
03-13-2025 04:54 AM
Gibt's mittlerweile eine Lösung? Ich mußte meinen zurück setzen, war Anordnung eines Support Arbeiter. Dieses Problem besteht ja schon seit über eine Woche!
03-13-2025 05:07 AM
Como sabremos que está solucionado?
03-13-2025 05:07 AM
I did factory reset when chromecast failed
I cannot reconnect
what's next
03-13-2025 05:15 AM
Change providers. That was the fastest way I got the problem solved.
