Update 3/20/25
Update 3/17/25:
Update 3/14/25:
Update 3/13/25:
Update 3/11/25:
Hi all,
Thank you.
Thank you for your patience.
03-20-2025 10:49 AM
03-15-2025 09:24 AM
Did a factory reset any updates here?
03-15-2025 10:37 AM
Change the date of your phone (earlier than march 9th) then relaunch the Chromecast setup with Google home. The Chromecast will be back online to receive the hot fix . I can use the Chromecast gen 2 since yesterday.
03-15-2025 09:24 AM
This is ridiculous. Over 100 million Chromecast sold worldwide and this is how you treat the customers. Definitely won't be buying Google TV if this is how you treat customers once you decide to retire a product line. Total Fail.
03-15-2025 10:20 AM
GOOGLE DEBERÁ PAGAR POR ESTO...
03-15-2025 09:24 AM
Siguen teniendo el problema..?? Yo desconfigure mi Chrome porque pensé que era problema del aparato.. como puedo volverlo a conectar..??
03-15-2025 09:25 AM
I have an iPhone and can’t just change the date. I did do a factory reset probably 4 days ago and it won’t connect now. Need a fix still
03-15-2025 09:26 AM
03-15-2025 09:26 AM
Scusate,se il dispositivo è compromesso fate prima a dirlo. Giorni e giorni di disservizio mi pare assurdo.
03-15-2025 09:27 AM
Please keep us posted if we have indeed factory reset the device.
03-15-2025 09:28 AM
How is the progress going on making the devices that are reset working again
03-15-2025 09:35 AM
Lo que debe hacer es desactivar la hora automática de su móvil y poner la fecha 01/03/2025 y luego entrar a la app home Google y configurar su Chromecast
03-15-2025 09:28 AM
Do we have only to connect to the device tv and wait for the update?
03-15-2025 09:28 AM
Patiently waiting, thank you.
03-15-2025 09:29 AM
I reset mine and still can’t access it ?
03-15-2025 09:30 AM
Factory reset upgrade available yet?
it’s March 15, 2025…
03-15-2025 09:32 AM
La solución para los que formatearon de fabrica:
En el teléfono donde vas a configurar el Chromecast hay q desactivar la hora automática y poner la fecha del 1/03/2025, entrar a home Chrome app y configurar el dispositivo
03-15-2025 09:34 AM
If you have the solution where can i find it ? Because i reseted my device
03-15-2025 10:46 AM
Set your phone's date manually earlier than march 9th ( march 3rd for example) then launch the setup procedure with Google home. It allows you to reconnect the Chromecast to wifi and receive the hot fix .
03-15-2025 09:35 AM
Hello, I did the factory reset. Please send me a solution when available.
03-15-2025 09:36 AM
Fiz no meu e funcionou restauro a configuração e voltou a transmitir
03-15-2025 09:39 AM
1 SEMANA, VOCÊS DEVEM REPARAR TODOS OS USUÁRIOS, SE NÃO RESOLVER ENVIEM UM NOVO, ISSO QUE ESTAMOS PASSANDO É MUUUITO ABSURDO
03-15-2025 09:39 AM
Its been 5 days now i cant cast on my Tv.. How many times i already put on and off my chromecast its say couls not authenticate
03-15-2025 09:40 AM - edited 03-15-2025 09:47 AM
I did not "factory reset" but I still cannot complete setup. This device was not yet configured for the my new router. When my unit failed I tried this one...but unable to complete setup. Directly upon receriving the "connected" message... I get something to the effect of:
Something went wrong
You may have set up the unit ok, but there is no communication with iphone .
Informed to check "privacy settings" Local Network Access enabled... which it is..
Any help? My first unit now is working!! Thank You Thank You for the effort!! 🙂
...but this other unit as described, is not... do I wait for the factory reset info.. then factory reset my device and follow the soon to be released procedure?
03-15-2025 09:44 AM
If you do factory reset, change your smartphone date to March 8, try to setup the device with a new factory reset, once your device is connected it will receive the last update.
Once it is updated, you need to take back your smartphone's date back to today's date.
Factory reset it again and voila it connect and finish the setup wizard as a new device.
03-15-2025 09:47 AM
Thanks to everyone who replied! Got it fixed. For those still having issues after a factory reset, set your phone's date to March 1st and then set up your Chromecast—it works! Have a great day! 🙌🏼
03-15-2025 10:00 AM
A mí me funciona hoy, he cambiado la fecha para configurarlo a una anterior a que surgiese el problema y de momento funciona
03-15-2025 10:00 AM
When are you expecting a solution to this problem? We did do the factory reset and are left with a beautiful paperweight
03-15-2025 10:07 AM
Um, Hello? Where's the fix?
03-15-2025 10:13 AM
I've done that and I can see my Chromecast screen on my TV but my home app still isn't finding it and it did the update and everything they're just not connecting for some reason my home app can't define the device after it says it was connected help
03-15-2025 10:15 AM
CONTINÚA INTENTANDO
03-15-2025 10:17 AM
Any idea when this will be done, I can’t reconnect my chromecast and unfortunately I did a reset 😣
03-15-2025 10:28 AM
SET temporaly your phone before 8 mar 2025 AND configure Chromecast. Ayer it Will work again
03-15-2025 10:19 AM
I have lost all confidence in Google. Hello ChatGPT as a search engine. Ordered TV box, tossing Chromecast. Duck Duck Go browser installing.
03-15-2025 10:21 AM
Okay…thanks for letting us know. I did a Factory Reset and will need help getting this setup again.
03-15-2025 10:30 AM
SET temporaly your phone before 8 mar 2025 AND configure Chromecast. After that it Will work again
03-15-2025 10:25 AM
* zet apparaat waarop je Google-Home app staat week terug met datum
* installeer de chromecast.
* zet datum terug naar vandaag.
03-15-2025 10:24 AM
eu já havia voltado para aa configurações de fabrica quando fiquei sabendo hoje desse problema. Por favor me envie as instruções para poder resolver o problema. Obrigado
03-15-2025 10:25 AM
Second day and still nothing
03-15-2025 10:25 AM
Quiten de la ayuda la parte que dice que reestablecer el dispositivo a la configuración de fabrica puede solucionar problemas de conexión de esa manera nadie se hubiera puesto a recetear nada
03-15-2025 10:32 AM
Yo reinicie el dispositivo, cuando estará lista una solución 😭😭😭 extraño mi dispositivo
