GoogleNestTeam
Community Manager (Admin)
Update 3/20/25
Update 3/17/25:
Update 3/14/25:
Update 3/13/25:
Update 3/11/25:
Hi all,
Thank you.
Thank you for your patience.
GoogleNestTeam
16,160 REPLIES 16,160
I have factory reset, please help with those instructions. Than you
Change mobile to back date. i.e. before Mar 9th and try to reconnect with Google home app.
Has progress been made on the fix for those that factory reset their devices? Thanks.
Nest75
Yes, progress made and it is working
This will work for both with factory reset and without.
¿SIGUE EL MISMO PROBLEMA?
I still waiting 😢
Thank you for fixing this issue. Don’t know how you did it as I was checking every day since your communique above… I was about to go and buy a fire stick today, decided to check for one last time and voila! My Netflix works again  🙏🏼🙏🏼🙏🏼🙏🏼  Sigh, we’re a whole lot of sad first world slicks addicted to our streaming devices.
Pode ser mais rápido com essas atualizações
If you performed a factory reset, you can manually set your phone or tablet date to March 5th and setup your Chromecast. After the setup is completed, it will update by itself with the fix. Just got mine fixed this way today.
Yo lo restableci a estafó de fabricca
Parou de funcionar e resetei e não consigo configurar de volta
Existe alguma previsão de quanto tempo para normalização para utilizar o dispositivo Chromecast?
Quando será solucionado, uma empresa deste porte, com a nata profissional do desenvolvimento, ao menos é o que dizem.
Demorar mais de uma semana para resolver o problema.
Anonymous
Not applicable
Any update how to fix the problem?
preciso do meu Chromecast nao parou de funcionar tando off nao se comunica ..preciso urgente
Anonymous
Not applicable
I deleted the Chromecast from Google home, hoping to reload it.  This didn't work of course.  I've tried since that and it won't find the Chromecast when it scans.  Do I still need to just wait for this fix??
My Chromecast Disconnected from WiFi; I tried reconnecting to no avail; I re-booted both the WiFi and Google Chromecast and get as far as connecting the the error message that something went wrong please check that your device settings are set to Local—which they are.  I even tried using my older iPhone 6s on WiFi and same message.  Nothing happened between the time it was working flawlessly and it disconnected.  What is up Google?  If you ever want my business for ANYTHING again you’d better fix this and fix it now because this is currently my ONLY means of streaming with an older non-streaming Hisense 55” television.  This has gone on far too long; I’m not buying a new television but I can go buy a Roku or Amazon Firestick. For God’s sake get together here; you know you did something—and it was YOU because i hadn’t updated Apple iOS until after this issue—thinking it was Apple’s fault.  Get it fix and please email me when it’s done—I work long hours just as you do and I don’t have time for all this nonsense. I had used Google exclusively for 20+ years as my primary email; I expect more from you.
Nest75
Do you see any Chromecast devices in the Google Home app
Solucionen rápido el problema, sobretodo a los que restablecieron los dispositivos, minuto que pasa más decae la reputación de Google...
eu redefini a configuração de fabrica....como vou fazer para ter acesso ao Chromecast. .
Still not working please fix it
Good evening!!! What can we say about this chaos? The technology company doesn't know how to solve the problem. How could we imagine that a factory reset shouldn't have been done, since every time there was a problem it was solved like this. What a joke, Mr. Google. Please solve this soon.
This kind of issue should be solved already and it never should've been an issue to a company like Google. Last update was on Thursday and still no solution to completely fix this.
Olá, tem alguma previsão para normalizar?
Não estou conseguindo utilizar o chromecast.
Cuando va a estar resuelto? Dejó de funcionar el sábado y recién el lunes pidieron que no se restablezca, es OBVIO que el 90% de los usuarios ya lo había reestablecido entre el sábado y Domingo. Necesitamos que vuelva a funcionar! Si tengo que comprar otro dispositivo, será de otra marca.
O meu Chromecast ainda não voltou a funcionar!!
How much longer do we have to wait for the issue to be fixed for those of us that reset the device. I was told when I rung customer care that this would be resolved in 24 to 48 hours 6 days ago and it has not been. I want a refund of my device replaced please.
Does the supply to Google nest?
Cuando lo van a solucionar? Hace días esta mal quiero una respuesta
リセットした人は、まだダメなんですね。
Mine are back up and working.  Thanks. 👌🏼👌🏼👌🏼
If you are still having problems because you factor reset you Chromecast. Go to the date and time on your phone and set it to before the 8th of March then go back to your home app and try to reset up your Chromecast this worked for me
So any update on fix if you reset your device? It's been a week.
Allyh
Mike, la concha de tu madre all boys
Aqui ainda não regularizou, provavelmente devido ao reset que fiz, pois não estava entendendo! Por favor, dêem uma solução para nós que por desinformação fizemos o reset!
Alguma nova atualização???????
My device still can not to have wifi connection which is very annoying it’s been more than a week already
How about another update on progress?
