Update 3/20/25
Update 3/17/25:
Update 3/14/25:
Update 3/13/25:
Update 3/11/25:
Hi all,
Thank you.
Thank you for your patience.
03-20-2025 10:49 AM
03-17-2025 10:17 AM
How many days is a few days? My chromecast audio still doesnt work.
03-17-2025 10:22 AM
Still bricked
03-17-2025 10:20 AM
Vaig reiniciar el meu disposition 🥵🥵
03-17-2025 10:32 AM
When can we expect resolution?
03-17-2025 10:33 AM
Still experiencing this issue, what is the resolve?
03-17-2025 10:34 AM
Gracias por su preocupación. Pero cuando empezó a fallar mi chromecast segui los pasos que recomendaba la aplicación. Y uno de ellos era restablecer la configuración de fabrica y lo hice.
Quedo y quedamos en espera una solución para los que hicimos la restauración de fabrica.
Gracias.
03-17-2025 10:45 AM
I already did factory reset 😭😭😭
03-17-2025 10:46 AM
What is the status for those of us who factory reset? It's almost 2 weeks now
03-17-2025 10:48 AM
If possible, would it be possible to provide an approximate waiting period/date for the factory reset chromecasts to be sorted?
03-17-2025 10:47 AM
Vai demorar?
03-17-2025 10:50 AM
I have been having this problem for more than a week. When will there be a solution for those who have made a factory reset (like me)?!
03-17-2025 10:51 AM
Hace días no puedo usar el Chromecast
No me deja conectarme
Necesito que se solucione el problema
03-17-2025 10:54 AM
Al sabado passdo mi chromecast ha actualizado y ahora funciona bien
03-17-2025 10:51 AM
Unfortunately I did a factory reset. Am enger to get the solution soon.
03-17-2025 10:58 AM
I have reset the Chromecast before I was aware of this. How can I make sure I get those instructions? I can't connect the Chromecast to the internet now....
03-17-2025 11:02 AM
i reset factory and cant set it up again
03-17-2025 11:04 AM
Still waiting!
03-17-2025 11:15 AM
Configurei meus 2chromecast porque não estavam funcionado
03-17-2025 11:23 AM
Can you give us an estimste when these instructions will be public?
03-17-2025 11:22 AM
At today 17/03/2025 my chromecast doesn't work. I did reset of device. I'm waiting for a solution of the issue.
03-17-2025 11:23 AM
Hi! Still having the issue and I don’t understand how and when you’ll be contacting me with instructions on the fix. Thanks for speeding up the process! It’s annoying to not be able to use Chromecast.
03-17-2025 11:25 AM
Still no news for those who factory reset their Chromecast? Thank you
03-17-2025 11:28 AM
Non sapendo cosa fare ho ripristinato le impostazioni di fabbrica, avete novità per la risoluzione del problema?
03-17-2025 11:28 AM
Hi, any resolution for the devices which performed a factory reset during initial troubleshooting?
Thank you and regards, Jarek
03-17-2025 12:13 PM
Setup your chromecast again but first change the date in your phone before 03/09/25 then the new certificate will be downloaded as an update. Good luck!
03-17-2025 11:28 AM
Any updates for the ones who factory-resetted it?
03-17-2025 12:12 PM
03-17-2025 12:12 PM
03-17-2025 11:29 AM
Por favor necesitamos una solución a este problema 😵💫
03-17-2025 12:09 PM
Pablogcsrrssco, el problema ya fue resuelto si no lo reseteaste de fabrica le va a llegar una actualizacion con el nuevo certificado sino podes resetearlo de fabrica y volver a configurarlo pero con la fecha de tu celular previa al 9 de Marzo del 2025. Asi te permite configurar la red wifi y te descarga el nuevo certificado.
03-17-2025 11:30 AM
The problem is still a issue. My cromecast is not working. Google have now 24h to solve the problems or i will throw it out from 5th floor and see then it get crused. So typical american companies, want to buy the whole world but have never done anything with any quality.
03-17-2025 11:32 AM
Still trouble… when will you fix it?
03-17-2025 11:58 AM
Set your phone's date to March 3, 2025, then set it up again with the Google Home app.
03-17-2025 12:04 PM
Thanks just fixed it all is as before 👍
03-17-2025 11:33 AM
Do you have any news !????..please fix asap !!
03-17-2025 11:56 AM
Setzen Sie das Datum Ihres Handys auf den 03.03.2025. Dann mit der Google Home App neu einrichten.
Hat bei mir funktioniert
03-17-2025 12:05 PM
Follow the steps in the comments. The issue was fixed last week.
03-17-2025 11:37 AM
Still no news about this problem ?
03-17-2025 11:38 AM
Big thank you to the whole team involved in this fix! It's working great here.
03-17-2025 11:38 AM
What if i did reset? I was not updated ahout this problem. So i did a reset, but now i cant set up my chromecast to device
