Update 3/20/25
Update 3/17/25:
Update 3/14/25:
Update 3/13/25:
Update 3/11/25:
Hi all,
Thank you.
Thank you for your patience.
03-20-2025 10:49 AM
03-17-2025 11:43 AM
Con la actualización nueva del FW. Poniendo el móvil a fecha 8 marzo 2025 y volviendo a emparejar, FUNCIONA!!!!
03-17-2025 11:43 AM
What is the fix for us that already did a factory reset
03-17-2025 11:50 AM
See my post
03-17-2025 11:50 AM
refer to my post
03-17-2025 11:44 AM
I have factory reset please how I setup
03-17-2025 11:49 AM - edited 03-17-2025 11:51 AM
Solition in case of factory reset:
03-17-2025 12:15 PM
Siguem sim funcionar ponganse en contacto conmigo al 629033311
03-17-2025 11:54 AM
I am told that I need to update my Google home app because my Google home app version ends in a five and it should end in a six. So when I go to the Google app store and open up my Google apps ..the Google app says it's up to date. So how am I supposed to update it?
03-17-2025 11:59 AM
Chiedo cortesemente di risolvere il problema al più presto, dal momento che siamo scollegati da oltre 1 settimana. Non e’ giustificabile una vostra risposta interlocutoria dopo il tempo trascorso, senza conoscere i tempi ulteriormente necessari per risolvere il problema. Chiediamo quando prevedete di risolvere grazie
03-17-2025 12:09 PM
Necesito se arreglen los fispoditivod
03-17-2025 12:00 PM
I think a majority of people hit the reset button on the Chromecast as myself. So far, it is still acting the same as of today, which is March 17, 2025. Is there an anticipated resolution time for those That factory reset the device?
03-17-2025 12:04 PM
Demomento sigo sin q me funcionen dos dis positivos esoero que se reduelvs lo antes posible Gracias
03-17-2025 12:09 PM
I have performed a factory reset for my Chromecast audio, because my previous wifi was no longer available. I still cannot re-setup the device. Also tried to tweak with the date, as propised on this thread. After that Google Home did actually find my chromecast audio device, but in the end it claimed that my phone and chromecast audio were not using the same wifi network.
So the issue still exists.
03-17-2025 12:14 PM
03-17-2025 12:24 PM
No news yet concerning when a factory reset has been done ????
03-17-2025 12:26 PM
Still not working what do i have to do?
03-17-2025 12:39 PM
Try setting your Date back to Sat March 8 and then set up your chrome cast. It should update and start working again. You can change back the time after set up is complete
03-17-2025 12:28 PM
Der er automatisk gennemført en opdatering på vores Chrome cast. Vi har dog stadig problemet og vi har ikke opdateret fabriksindstillingerne.
03-17-2025 12:37 PM
FOR THOSE WHO DID FACTORY RESET
I found a loop hole where if you set your time and date on your device to Sat. March 8 and then try to set up your chrome case it will update and start working again. You can change the time and date back to current after the chromecast is set up
03-17-2025 12:41 PM
Unfortunately itdoesnot work for me. My WiFi does not work when I change to a former date
03-17-2025 12:43 PM
I used a tablet when I changed mine.. not sure if that made a difference?
03-17-2025 03:14 PM
Thanks. Youre solution work on my end.
03-17-2025 12:37 PM
Are there any updates for if you did do a factory reset
I was travelling and at a hotel at the time when this issue happened, I thought it was a connection issue like occasionally happens - so unfortunately I did a factory reset & so I can’t update device through google home… it’s really frustrating & id like it fixed please
03-17-2025 12:39 PM
Any news for those who actually did a factory reset??
03-17-2025 12:41 PM
On your device try setting your date and time back to March 8. Then do your set up for chrome cast, it should update. Once it's set up you can change the time back to current. I found this worked for me
03-17-2025 12:43 PM
Tô cheio de ódio é pânico e terror
03-17-2025 12:47 PM
IO ancora nn ho Chromecast e nn posso vedere Netflix che sto pagando!!!!!
Attendo info x risoluzione!!!!!
03-17-2025 10:07 PM
Controlla i commenti, devi dettare il telefono sull’8 marzo, connetterti a chromecast e poi rimetti la data giusta.
03-17-2025 12:51 PM
Still no update?? On Thursday you said the "next few days". STILL WAITING! Meanwhile, I'm still paying for all of my streaming channels, but am unable to to actually WATCH THEM!!!! This is not ok. It's actually BS. I'll give you til Wednesday, then it's Goodbye Chromecast Hello Roku. Not that you actually give a 💩.
03-17-2025 10:09 PM
Check other comments. You can set your phone date to 8 of march, connect chromecast and then adjust date on your phone.
03-17-2025 12:51 PM
still having problems. don't understand what to do. I'm an old man.
03-17-2025 01:03 PM
I hope the Chromecast Audio will be fixed that I can see the devices in apps that I use for music ie mediamonkey 5 and plexamp
Because at the moment - even though I can get them visible in app Google Home, Devices, some are accessible in device information and others advised they are offline when checking Device Information.
03-17-2025 01:05 PM
Ho cancellato il dispositivo, perche la comunicazione è arrivata dopo. E ora non posso aggiungere un nuovo dispositivo
03-17-2025 01:06 PM
Hello, do you have any news?
Thanks
03-17-2025 01:08 PM
Any updates? This situation is really annoying me.
03-17-2025 01:12 PM
most people probably did a factory reset which is the advice on the web page! I did, and still can't use it. When will this be resolved
03-17-2025 01:28 PM
Absolutely agree! Me too.
Fix it please
03-17-2025 01:22 PM
Hi team,
I´ve reseted my chromecast during initial trobleshooting, and now I cannot re-setup it. Please let us know when you have the solution for it.
thanks
03-17-2025 01:26 PM
È scandaloso.
03-17-2025 01:25 PM
I already factory reset my Chromecast. Please help me. What I have to do?
