GoogleNestTeam
Community Manager (Admin)
Update 3/20/25
Update 3/17/25:
Update 3/14/25:
Update 3/13/25:
Update 3/11/25:
Hi all,
Thank you.
Thank you for your patience.
GoogleNestTeam
16,160 REPLIES 16,160
Anonymous
Not applicable
What to do for a factory reset, since I already did one and now it can't connect at all.
Edo2
Io ho fatto così, ho cambiato manualmente la data del telefono che trovi in impostazioni data, spostandola indietro al 6 marzo, sono andato in Google home è ho installato il chromecast tranquillamente, ricordarsi poi di mettere la a data giusta sul telefono mettendo di nuovo in automatico il pulsante, per lo meno non è resettato ma adesso si deve aspettare la Google che invii aggiornamento, si spera
NOWO
The least you can do after this is extend the support period. I've spent about  9 hours trying to fix it - before discovering it was a global outage (outrage?!) Ending support is crazy. I don't need a fancier device and why send millions of perfectly functioning devices to landfill? (Oh - because then we'll have to buy new stuff?)
JorgeLavín
Take your time, I have already bought a Roku
Ritesh1
It is already 3 days over & still no fix ... This is really disrespect for customer.. Hope google understand the seriousness & ensure timely fix.
Jen1968
This is all I'm getting
Coxmik
Ok I'll wait for you fix solution then. But be sure that if it's solvable I'll Nevers buy again a Google product at all, and I'll not promote it anymore.
Keep on work guys please.
OvidiuM
Any news on this topic ?
thx
Moisess
The company goo to send an email whyt the solution?
paola2
Espero no tarden mucho en solucionar este problema, y pensé que era mi wifi 😔
Zozo2
I had already factory reset my phone
Mohammmed
المشكلة لها ثلاثة ايام ولم تحل حتى الان
Hareesh
When the issue will solve?
Christopher39
Malheureusement je ne savais pas qu'il ne fallait pas rebooter la chromecast.... j'espère que vous allez vite résoudre le problème car je me retrouve sans tv
Pmehta
I tried to factory reset then how and what is possible solution to update the device with latest firmware?
norulers
I went out and got the new Google TV Streamer immediately, just like they wanted me too.
jeffy18
Please fix this asap
Aschwieterman
Is there an estimated fix date?  Or can we all get an updated Chromecast?
GSiva39
I am facing issue with chrome cast.
mnbvcxz09876
For those of us that have factory reset the Chromecast already, you can do a bit of work on it using https://gist.github.com/interfect/5f68381d55658d334e2bc4619d796476
This will reenable the wifi. So I can now at least cast to the Chromecast using https://github.com/skorokithakis/catt
VLC also works to send videos to it too.
So they're not totally useless until Google gives us a new certificate.
Angelgpd
Hoy jueves 13 intenté de nuevo utilizar los chrimcast y sigo sin poder establecer comunicación . Ayuda por favor
Walmarques
  • Já fiz a restauração de fabrica, este de restaurar já não conectava com o aparelho, aí agora quando tento configurar aparece essa informação.
carrington1221
Oh no!  I thought my chromcast was broken and have trashed it and bought a new one!
MmeCookie
Any updates?
Joy0703
C’est bien de nous prévenir 1 semaine après ! Et si on a réinitialiser notre appareil ça se passe comment ?
Brice2
You have to consider that many users have already performed a factory reset on their Chromecast 2nd Gen. If your team is unable to identify the issue, perhaps you could offer an exchange program by mail or in-store, or provide a rebate for a new device. Thank you for your understanding.
Karl86
Elon Musk can you Bye Google and fiks it to .? This is to stupid ….😡 Time to fiks this **bleep** Google .!
AbrarAliMir
how many more days it will take to fix the issue
Lizardk21
Very late answer , factory restart ist a first thing users do.
Edmilsoncp
Agradeço sobre a informação, tenho 2 chromecast da 2ª geração, infelizmente eu achei que era um defeito interno e resetei os 2 dispositivos. Como proceder agora?
Lucutus
I have 4 Chrome Cast Audio Devices in my House for Multi Room Music Support. This is killing my multi Media Concept....
arugescu
When ? We purchased the devices, now you tell us they are not working anymore? Until when ? When you will solve the issue so we can use what we paid for already ?
AbrarAliMir
I was planning to get extra storage at Google cloud, but if the same thing happens there also and if I end up without access to my important files, then I will be over. It is too risky to trust these things.
Glo27
Gracias estoy esperando
DekoSeneme
O problema começou no Domingo a noite, percebi que não carrega mais as fotos da conta, somente as imagems do google
MalikAwan
hi, team can you please confirm that the issue has been resolved or still persist. Because I am still unable to setup my device. Please advise. Thanks
Regards!
Ummm... the pinned answer at the top of this page will always give you the current status.
Glo27
Lo desinstale y lo volví activar
gapfoldfrog
To  late ... Device factory reset ...
Anonymous
Not applicable
Martedì non sapendo cosa stesse succedendo leggendo dei post sulla risoluzione del problema ho resettato il mio Chromecast...al momento tramite l'app HOME di Google riconosce il Chromecast ma non lo fa abbinare ...la soluzione al mio ed al problema un po' di chi si trova in questa situazione lo pisterete su questa pagina?
