GoogleNestTeam
Community Manager (Admin)
Update 3/20/25
Update 3/17/25:
Update 3/14/25:
Update 3/13/25:
Update 3/11/25:
Hi all,
Thank you.
Thank you for your patience.
GoogleNestTeam
16,145 REPLIES 16,145
newnikka0412
Tried all the suggestions but it's still displaying "we cannot authenticate chromecast ". What to do??*
Wait for google to fix it... from what I've seen, last time it took a month or so to come up with a fix.
Anche io da ieri sera non riesco più a configurare il mio Chromecast....vedo che il problema è comune a tutti.
Pensate che si risolverà? Da cosa dipende? È la prima volta ,dopo tanto tempo che ce l' ho,che mi capita
I also experienced this issue, all devices working perfectly fine yesterday. Now none of my chromecast devices work!
They want us to buy apple tv instead 😉
Lol maybe they are tired of everything
Same here yesterday my chromecast was working, and I have deleted installation and reinstall without any success
Same here
Same for me. Working yesterday morning and not now.  I've rebooted and now it doesn't even let me install it again.
Same here, I have been using 4 chromecast audio devices for years, and this morning suddenly nothing worked anymore. What happened?
An intermediary SSL Certificate expired on you CC device.  Google needs to either renew that certificate and resign all CC SSL certificates with the new intermediary SSL Certificate or come up with another solution that would be quicker to deploy on those millions of devices.
queiroztfm
That's my main frustration the network audio streaming no working.
Anche a me da Parma non va più e non si collega.. Mi rincuora non essere l unico
Same issue,
One decide works fine the other one doesn't.. so gotta wait for Google to fix it?
I have exactly the same problem I been trying everything!! Happy days
Worked fine yesterday, stopped working tonight. Authenticate problem... Please solve this quick Google. From Sweden
Samma problem här  försökt allt. Tänker att jag kanske går o köper en nyare version  dom funkar tydligen..
Curre
Finns bara Google chromecast för 1399 kr på elgiganten
J'ai le même problème également.
Tout marchait bien il y a 2 jours et malgré un réinitialisation, il n'arrive pas à authentifier mon appareil
What’s really frustrating is the lack of any proper acknowledgement or holding message from Google. Seems to show contempt for a millions of loyal Chromecast and Google Home users. Been considering a move to Amazon infrastructure for a while, this may force my hand.
Io ho anche un Fire Stick Amazon e posso assicurare che è una bomba! Infatti sto pensando di dismettere il Chromecast e passare ad un altro Fire Stick Amazon
So glad I found this community, ive been resetting my Chrome chromecast, phone and WiFi for the last 30 mins wondering what is going on! Clearly it's a google issue 🙄
I feel your pain!  I wanted over 3 hours trying every fix I could think of to get my 14 (yes, 14!) devices working.
Wish I had come here first to learn it was nothing I could fix.
Woulda saved a lot of time and frustration.
All I can say is that they better get it fixed quick.
This is soooo not good.
Haha, I tried earlier today and nothing but didn't worry too much about it until just now. Glad it was on 30 or so minutes of getting angry at it
Curre
Have done the same, nothing is working...!!!
10/3/25
Same problem here in Singapore..tried all ways n feel like crying till i come here..so im not the only one.Google plssss fix these!!!
All my Chromecast stopped working yesterday night. Authentication error. Also after reboot unable to set up device
Same here!
En la misma situación de todos. Pero que hacemos? Nadie da la cara. Demasiado tiempo de mi tiempo probando de todo. Muy frustrante. Hasta ahora cero solución.
problem of Certificate (CA) .. try change date to yestarday (9 march)
How do we do that
Hasta el técnico de Movistar intento acceder pero no funciona 😔
Here's a notification from Google Nest Team... in a few words... we have to wait 💀 https://www.googlenestcommunity.com/t5/Streaming/Regarding-an-issue-with-Chromecast-2nd-gen-and-Chro...
If you did factory reset, please see this article, it served me well, as I also did a factory reset. This only works to get the google chromecast show the google stock wallpapers, but we still have to wait for the issue to be solved. Here's the article: https://www.googlenestcommunity.com/t5/Streaming/Did-you-factory-reset-your-CC-hoping-to-fix-the-tru...
thanks to GiacomoMilazzo | Community Member
Klar
How will you provide these instruction? By email to my linked account?
RonComstock
Where do I go to see the problem fix when there is one. I'm paying by the year for a streaming service I can only see through Chromecast.
Geogandoro
Desde ayer en la noche, el Chromecast no me dejaba enviar nada, ni desde pc, ni desde móvil, lo he reiniciado de fabrica y ahora no es capaz " de autenticar el Chromecast" ya que no me salta la opción para aceptar o no el código que aparece en la pantalla, veo que es un problema global pero, ¿Se sabe algo?
Tenho o mesmo problema , parece ser generalizado
Tengo el mismo problema desde ayer!!!
same probleme in france since yesterday
