GoogleNestTeam
Community Manager (Admin)
Update 3/20/25
Update 3/17/25:
Update 3/14/25:
Update 3/13/25:
Update 3/11/25:
Hi all,
Thank you.
Thank you for your patience.
GoogleNestTeam
16,146 REPLIES 16,146
For all the people who are factory resetting and wondering “what do I do now?”, this procedure will allow you to reconnect your Chromecast to your Wi-Fi network so that it can receive the firmware update fix that Google started offering on March 13th.
1) Temporarily set the date on your smartphone (or tablet) to March 7th or earlier.
2) Use the Google Home app to set up your Chromecast again. You still won’t be able to cast and the device will be grayed out in the Home app, but that’s okay. You can also change your phone’s date/time setting back to Automatic now.
3) Sit back and wait for the firmware update from Google to install. This should restore full functionality to your Chromecast.
Note: This is supposed to be a “staged rollout,” so it may take a few days for the firmware update to reach your Chromecast. Patience.
Claudietta123
Io sono riuscita mettendo la data  del 6 marzo ho riconfigurato il dispositivo.. perfetto! Grazie
Aletc
La firme met un temps fou pour réparer sa bêtise (intentionnelle?) Cela n'augure rien de bon. Ca sent l'arnaque...
Pedrolothb
Já fiz a reposição e todos os passos porém sem sucesso
Aehebert
When can we expect this to be fixed?? It’s been a week for me.
Atmaram
Still facing this issue from last 3 to 4 days now
Why its taking so long?
Jeetu672004
Thanks all, setting up mobile with old date works for me to authenticate and configure the device.
Nicoly
Espero que seja o mais rápido possível, já não estou aguentando não poder usar mas 😭🥳🥳
Attilio1
Salve, io ho ripristinato purtroppo, in che modo darete informazioni? Tramite mail o altro?
Tramite email ho scritto non posta
Imposta manualmente la data del cellulare al 03/03 e lancia la configurazione dalla app google home
Turkestan
Ahora en Argentina empezó a funcionar bien al fin
MyM91
Si lo restableció, que debo hacer?porque sin saber, yo lo restableci..
IP2
Cambia la fecha en tu móvil.
Pon una fecha anterior a 9 de marzo.
Configurar el Chromecast. Así conecta con la red wifi.
Después ya se actualiza solo.
Maxxxx
Ho seguito anch'io, si è reimpostato, aggiornato, riavviato più volte. É tornato efficace però solo dopo avere reimpostato l'ora corretta sul telefono.
Tripero
Que novedades hay sobre los casos en que se reinicio de fabrica el chromecast? Sigue sin funcionar!!! Espero una pronta solución!!!
Alienplanet11
Has there been a fix yet?
Bander1
Es lamentable que una empresa de tal magnitud deje de dar un servicio de un producto por el que pagué una determinada cantidad de dinero y ahora me siento defraudado y estafado. La pérdida de confianza y reputación de Google espero que sea grande y gravosa para la empresa. Supongo que también será posible incoar una denunciar por negación de servicio...
Yanickhb
I did resetted it before redingote your message.
Wilma2
Ok, put back the date on your device, Lets say 7 March, then try To Open the Google Home App and install the chromecast, it should work. and then reset the date in today, best of luck….
Redroom
Está restablecido de fábrica
johnnyzero2
There is a known fix to recover from a factory reset, and it's ridiculous that Google hasn't pinned that information to the top of this page. 90% of the people posting here are saying "I've done a factory reset, now what can I do?" or " any update on a fix for people who have done a factory reset??".
In the meantime, I've been posting the solution everywhere I can to help those affected:
https://www.googlenestcommunity.com/t5/Streaming/Regarding-an-issue-with-Chromecast-2nd-gen-and-Chro...
Kiki1111
Any news about this?
mtwickenden
When will you have the fix ready for people who have just reset their chromecast. Dammed angry.
Anonymous
Not applicable
Hi, it appears a message showing, cannot authenticate  my chromecast 2 generation
That happened me yesterday, leave it connected until the update rolls on your device, it could be hours. I recover the signal and yesterday I was able to cast, but now I can't even the screen casting through Home app. I'm not going to do a factory reset just in case.
diego_
How can I fix this problem if I reset my device?
Anonymous
Not applicable
You must await for the fix bug , its occurs at world height
Re: Regarding an issue with Chromecast 2nd gen and Chromecast Audio (Google Nest Community Subscription Update) (Re: W sprawie problemu z Chromecastem 2. generacji i Chromecastem Audio (aktualizacja subskrypcji społeczności Google Nest))
Follow simple steps.
1. Just set your mobile date back to 8th March or before manually.
2. Open Google Home app
3. Configure device
Wait until it will configure and update firmware...
4. Once device setup done, change your mobile date back to auto option.
All set.
Gherin
Buongiorno, io come tanti altri abbiamo eseguito il ripristino, attendo di risolvere al più presto possibile.
LewisB2
Here is how to reconnect your chromecast 2nd gen if you had reset it :
1) Change the date on your phone as before the expired date certificate (march 9th 2025)
2) Go on your Google Home App
3) Reconfigure your Chromecast as a new one
4) Once the update is finish on your Chromecast, change the date on your phone as the automatic date
5) You shouls be able to use your Chromecast as before the march 9th.
Here i found a video explaning the differents steps : https://www.youtube.com/watch?v=sT3yWFrzRRo
Aletc
Merci à la communauté pour leurs bons conseils ! Vous devriez postuler chez google pour améliorer leurs services...
BucurescuIonut
Hello
Ivonildo
Me desculpe mas eu eu dei reset no aparelho acho que voltou a configuração original de fábrica
