GoogleNestTeam
Community Manager (Admin)
Update 3/20/25
Update 3/17/25:
Update 3/14/25:
Update 3/13/25:
Update 3/11/25:
Hi all,
Thank you.
Thank you for your patience.
GoogleNestTeam
16,134 REPLIES 16,134
Kalam8848
Dining Room TV may be set up, but we could not communicate with it from your iPhone. Make sure that you have enabled local network access in your iPhone’s privacy settings. Then try again.
Armordad
Which chromecast should are the second generation?
27046251827
Gostaria de saber se o Chromecast não está funcionando por problema de atualização ou de certificação da anael?
Beeboue
What is bad/ can happen if I have already factory reset my chromecast
     If you performed a factory reset during your initial troubleshooting, you'll need to do this:
https://www.googlenestcommunity.com/t5/Streaming/Regarding-an-issue-with-Chromecast-2nd-gen-and-Chro
Scat
  • Risolto spostando il giorno di calendario del mobile a febbraio, la riconfigurazione va a buon fine e tutto torna a funzionare
Martin89
Yo digo que entreguemos todos nuestros Chromecasts y Google nos entregue uno nuevo sin más
Ed1992
Is this getting fixed anytime soon
Anonymous
Not applicable
When will this issue be resolved?
BlancaME
No entendía el porqué no me dejaba configurar mi Chrome cast a mi TV, me decía que no tenía prendida la red local y si la tengo, reinicie muchas veces mi celular, el Chrome y nada, ya tengo mas de una semana que no lo puedo usar, y si, esto me afecta Demaciado, háganlo lo más pronto posible Porfavor. Que mala atención.
  >>>> If you performed a factory reset during your initial troubleshooting, you'll need to do this:
RENATA1
Bonjour à tous,
Je viens de lire 1 commentaire positif sur le forum (je n'arrive plus à retrouver du  nom de la personne  pour le remercier.)
Concerne la panne de diffusion par CHROMECAST depuis maintenant 8 jours !!!!
Je pensais que tout était lié : smartphone et PC confonfus.
CASTEZ DE VOTRE PC (si vous en avez un bien sur ) SUR LA TV ET CA MARCHE......
Abandonnez les smartphones pour l'instant (chromecast seulement ).
Me voilà apaisée, je voulais vous faire profiter de la bonne nouvelle.
Un grand MERCI au membre de la Communauté qui se reconnaitra.
ElTacos
Ça marche avec le téléphone également:
_ ceux qui ont fait un factory reset, il faut reconnecter la Chromecast. Pour y arriver, il suffit de changer la date du telephone / tablette manuellement ( plus vieille que le 9 mars) et relancer le setup avec Google home. Ça permet de reconnecter la chrome cast au wifi et de recevoir le correctif de Google.
- ceux qui n'ont pas fait de reset, le déploiement du correctif est en cours. Visiblement débrancher / rebrancher électriquement la Chromecast "forcerait" l'installation du correctif selon d'autres membres du forum.
Psingh77
My device is dead. I disconnected it from google home, does that count as a hard reset or will it self upgrade? It does not show up to WiFi either. Pls help.
ElTacos
Yes consider the factory reset procedure described above.
_ change the date of your phone to march 7th
_ relaunch the setup with Google home to reconnect the Chromecast to your wifi
TheFool
It has been now over five days we have not been able to cast ... from anything at all times for years ... to an absolute backhand.
Tried all the suggestions and tips that, not a google tech, but john does have been so kindly uploading and nothing so far has been working.
Two trillion dollars company that can't fix such nuisance pronto? And one that only seems more interested in finding extra ways to infiltrate the private lives of people even further?
The saddest is that after so many years, using the same device, the same tv and almost the same laptop to cast whatever needed... after only 30 miserable mins of non usage, we had to come back to this frustrating annoying humiliating situation.
How on Earth a device can stop from one minute to the other one to work? This is a problem that has been affecting thousands and thousands of users for quite some time now ...
So why the waiting time at all, when it is very obvious that all these problems have been caused by you. A two trillion dollars company that has not one employee around the planet that able remember to extend the expiry date for device's authentication (whatever) for an other ten years? In the whole company ... not one? And now everybody else, ergo Your Users, are obligated to put up with the consequences?
Customers' service that does not really exist. So far have been the users that have been working hard in trying to help all those thousands and thousands of unhappy frustrated left out customers, and NOT any of those techs that are employed and paid to also sort out problems caused by their and their managers of course, poor care                 😞 😞 :-(. Why have to be always the consumers/users put to be the biggest losers?
On this innuendo ... Thank You Folks for trying to do google's techs job, but unfortunately for thousands and thousands of us ... none of them has helped to solve the problem 😞 😞 😞   ... just yet.
Today's rating:
Not impressed at all. Once again ...  total thumb down 😞 😞 😞
Very helpful thanks 😊
Francisco5
No puedo conectarme
ありがとう!
使えるようになりました!
Gutemberg
Ciente
BurnItDown
Just like the hundreds, if not thousands, of other Chromecast users,  I have been unable to cast from any app to any device since 3/9/25. There is no way to contact Google, so it is unclear to me if they are even aware of the problem.  Clearly, if they are aware, they do not care. I am trying very hard to not to write a long succession of swear words in all caps, mainly because I figure it would get my comment removed.  This company is so unaccountable, so rapacious, so greedy, so undependable, and so untrustworthy. I know they don’t care, but if I am forced to buy another Chromecast-like device, it will not be anything from Google.  DO NOT RECOMMEND ANYTHING FROM GOOGLE.
JillG
***  If you performed a factory reset during your initial troubleshooting, you'll need to do this:
Sandy2107
1 semana sin tener solución
ReallyVeryUpset
Do to previous prompts I already reset mine.    Why is chromecast not working?
* * If you performed a factory reset during your initial troubleshooting, you'll need to do this:
estrela0224
eu não sabia e restaurei o meu começa-se
o que fazer se eu restaurei o meu chomecast
Bttotove
Lo reinicie no bien surguio el problema ya ahora me dicen que eso no se debía de hacer reparen lo rapidooo!!
Dtbull1
Any updates yet? Already factory reset
>> Yes. If you performed a factory reset during your initial troubleshooting, you'll need to do this:
